new ignition blowing fuse
Old Nov 3, 2005 | 10:15 AM
mendon99's Avatar
tastey wheat
ok heres the story:
My gf's 99 SE was broken into a little over a week ago, and the guy ripped the iginition out attempting to hotwire the car (i guess?) either way, he failed and ran when he heard someone coming. Now we had a local shop repair the window and order the new ignition and keys from Nissan and program them accordingly.
Ever since then, the dome lights/door lights/map light do not work. I checked the fuse, sure enough it was blown, so i threw another one in there and it blew instantly. Nothing on the car has been changed since the ignition replacement, plus the ring that lights up around the key isn't working. My only theory is that either something is wired up wrong, or there is a bare wire touching metal somewhere and wasn't covered in the ignition area... is it easy to get at the wires so i can see if its just a bare wire? If there isn't one, im just gonna take it back to the shop and make them fix it.
Is there a write up somewhere?
thanks
Old Nov 3, 2005 | 10:33 AM
njmodi's Avatar
Do I get a tax break?
Pull the steering column plastic shrouds off and see if anything obvious shows up... Assuming the work was paid for (insurance or otherwise), I would just take it back to the shop and demand they fix it.
Old Nov 3, 2005 | 10:55 AM
mendon99's Avatar
tastey wheat
yea, thats what i was gonna do, i just wanted to see if there were any other thoughts as to why the fuses go, or if theres another way to take it apart. thanks
Old Nov 3, 2005 | 11:03 AM
njmodi's Avatar
The plastic shrouds are easy to remove... but you are right, in that it's likely a shorted connection somewhere behind the shround. There are a sh*tload of wires back there, including the keyring light wiring, and any one of those could just be hanging loose or wired incorrectly.
Old Nov 7, 2005 | 07:25 AM
packetscan's Avatar
Crossed Wires
My guess is that they crosses a wire.
I'd disco the battrey's negative cable and call them to tow it.
You do now want to risk further damage.
If you must drive it take out the fuse that keeps blowing.
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
