slight oil leak! where is it coming from ???(Pics)
Old Nov 5, 2005 | 06:40 PM
DcMaN's Avatar
Well i went to go change my oil today and i found some oil dripping down onto the bottom of the transmission as seen in these pics. http://photobucket.com/albums/v374/DcMaN341/Leak/
Anyway i did some investigating and i noticed some type of golden ring on the axle was popped out so i popped it back in and "Hopefully" thats what was causing the leak. If anyone can help me determine the oil leak i would be truly grateful thanks.
Old Nov 5, 2005 | 07:01 PM
RA030726's Avatar
I'm nutty for Nissans
it seems to be the axle seal letting gear oil out of the tranny. you may need a new gasket.
Old Nov 5, 2005 | 08:08 PM
PAREDLINE's Avatar
ahh the infamous golden ring fix.... That little dirt cap (golden ring) on the end of the axle is so dirt doesn't get into the seal. It doesn't hold back anything else. You'll probably need new axle seals.
Old Nov 5, 2005 | 08:30 PM
DcMaN's Avatar
so how hard is it to replace the axle seals ?
Old Nov 5, 2005 | 08:36 PM
PAREDLINE's Avatar
not very hard. Follow instructions to remove the axle. There's a rubber seal inside the transmission when you remove the axle- right where the axles goes in. Replace that.
rtirbany
Sep 8, 2015 11:46 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
acw
Aug 13, 2015 12:50 AM
acw
Aug 7, 2015 04:20 PM
