(pics) leaking...oil?
Old Nov 10, 2005 | 01:27 PM
chillin014's Avatar
I noticed spots in the driveway, and finally found what i think is the culprit.
can anyone tell me what this is, or how i could fix it?
Old Nov 10, 2005 | 01:42 PM
njmodi's Avatar
Do I get a tax break?
camshaft position sensor... pop it out clean it, inspect the rubber washer/o-ring - I popped mine out a few weeks ago, but don't remember how it "seals".
Old Nov 10, 2005 | 01:44 PM
chillin014's Avatar
so thats oil leaking? and why'd you pop yours out did you have the same problem?
i guessed it would be the o-ring but didnt wanna mess with anything just in case. i'll go check it out rightn ow
thank you
Old Nov 10, 2005 | 01:45 PM
njmodi's Avatar
I just popped mine to clean it out - help with starting/timing accuracy etc.
It's oil vapor seeping.
Old Nov 10, 2005 | 02:01 PM
chillin014's Avatar
yeah i didnt see a washer or anything , the sensor was just itself like a cylindrical plug. how did you clean it? and did you clean the sensor or inside that hole. i've been having starting issues but..i mainly just want it to stop leaking for the most part.
Old Nov 10, 2005 | 02:04 PM
njmodi's Avatar
I just wiped it down - with a soft rag and cleaned up the edges of the hole in the timing chain cover.
I'm not sure what you can do to stop it from leaking - just clean out the hole, and the part of the sensor assembly that seats on the timing chain cover - so you get a nice seal. And retighten the bolt - that will probably do it. also just clean up the stains/seepage on the chain cover so you can tell if it's still leaking.
Old Nov 10, 2005 | 02:06 PM
chillin014's Avatar
i'll do it, thanks man i appreciate it.
Old Nov 10, 2005 | 07:10 PM
matty's Avatar
There should be a rubber washer on it. I have mine turned in place to accomidate room for my S/C braket, and mine seems very tight and does not leak. Take it out, get the Washer out, and see if you can go find one at a local auto parts store
-matt
Old Nov 10, 2005 | 07:47 PM
chillin014's Avatar
i was thinking thered be a washer too...then i looked and didnt see it, you think it coulda fallin inside the timing chain area?
Old Nov 10, 2005 | 10:33 PM
kbmaxima's Avatar
man u just reminded me about mine leaking. but from wut i've heard, just get a new o-ring for the sensor and should be fine.
Old Nov 11, 2005 | 03:56 AM
PLUMMAXSE's Avatar
Yep,
Their is an o-ring in a groove around the sensor that keeps the oil from seeping out all over the place. The o-ring gets brittle and leaks. Just match up the o-ring and reinstall. I replaced mine last year I think.
Old Nov 11, 2005 | 10:22 PM
chillin014's Avatar
Originally Posted by PLUMMAXSE
Yep,
i see what your talking about...its about even with the rest of the sensor, im gonna have to find a nother one i donno where to look i guess home depot...
Old Nov 12, 2005 | 08:35 PM
PLUMMAXSE's Avatar
I would try Napa if you can't find one at Home Depot.
Old Nov 12, 2005 | 10:41 PM
chillin014's Avatar
i just dont know how big its supposed to be in diameter and waht not.
Old Nov 13, 2005 | 03:54 AM
PLUMMAXSE's Avatar
Just take the old one into Napa and the salesperson will match it up. See if you can take the entire sensor in the store and explain what you need. It should be a pretty close fit around the sensor.
I think I matched mine up at home depot so it's not too hard.
Old Nov 13, 2005 | 09:02 PM
sodie14's Avatar
i have an oil leak in that general area as well, but i havent investigated it much yet...any other noteable problem areas for oil leaks in that vacinity? also chillin014...what kinda horn is that? and how does it sound compared to the woosy nassan oem ones?
Old Nov 13, 2005 | 09:12 PM
matty's Avatar
Nothing else should really be leaking up that high on the cover other than maybe the Water pump cover. Thats the black plate below the crank sensor. That horn is one of two Hella's...One goes in the grille and one where he has it. I painted the front one red so it cant be seen from the front. I like the sound they make, loud but not too loud
Old Nov 13, 2005 | 09:15 PM
chillin014's Avatar
I'm pretty sure that's where its leaking from.
Those horns are hella horns I got them from the group deal in the gd section. Cost like 60 bucks. They are better than stock, definently louder but have a sort of note, like european (they are european horns). Kind of a "toot" there are 2 horns, with 2 different tones. I'm going to try to put them together behind the grill to get the sound more "together" but right now it rattles when I honk because its touching the bumper behind the grill.
Anyway, in my opinion they are better than oem although I'd rather the tone of those big gmc suv's.
I kinda like the one being partially visible behind the grill like almost revealing that there's been things altered under the hood.
Old Nov 14, 2005 | 06:36 AM
SkiDaddy's Avatar
Also check to make sure your PCV valve is functioning correctly.
Old Nov 14, 2005 | 09:52 AM
chillin014's Avatar
i'll check up on that thanks (as soon as i figure out where its at/ what it is)
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
