Failed Smog (NOx), EGR Solenoid Prob
Old Nov 12, 2005 | 07:56 PM
dmg's Avatar
dmg
My EGR Control solenoid is not getting enough juice to activate the solenoid (to open the EGR valve). Solenoid works fine when I apply direct power from battery, but the harness doesn't carry enough juice to activate it (it does read 12 volts, but doesn't have enough power to even run a test light). Looks like one lead goes to a power source, and the other one goes to the ECM.
Any ideas? Does the ECM just complete the ground in the circuit to activate? Sound like a bad connection or an ECM problem (or a sensor that the ECM uses to activate the solenoid circuit)? Any help is appreciated...this is a tricky one...
Thanks in advance !
Dave
Old Nov 15, 2005 | 03:54 PM
RA030726's Avatar
I'm nutty for Nissans
you should do a continuity test on the wires.
Old Nov 15, 2005 | 05:22 PM
Mishmosh's Avatar
It's been a while, but I believe 12V is the default voltage feed. When the ECM drops that to 0V, the EGR system is activated.
Old Nov 15, 2005 | 11:44 PM
greenmax95se's Avatar
i had same problem, make sure all your vacum hoses are connected right, mine were wrong and it fixed my problem and i pased emmissions the 2nd time
shilov
Feb 19, 2024 09:40 PM
homeofbacon
Sep 23, 2015 07:17 PM
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 19, 2015 01:07 AM
Jay556
Sep 12, 2015 05:50 PM
