need some help
Old Nov 16, 2005 | 08:20 AM
mjb95maxse's Avatar
need some help
my cel came on about a month ago i pulled the codes from the ecu and got a 0303 and a 0304 which is front left heated 02 and the ks. ok i reset it after i pulled the codes(didnt have the money to fix right away) and it came back on this mourning so i checked the codes again and got a 0304 and a 0806 whick is ks again and evap canister purge control valve/solenoid valve but did not get the 0303(front left 02) i am confused as to what this code(0806) means and why the 0304(lfront left 02)code didnt show up again.can anyone give me some insight as to whats going on here and what i should do to correct this? i have a 95 se 5 speed
Old Nov 16, 2005 | 09:02 AM
ronin22357's Avatar
It is probaly the KS making the other codes show up, I have seen it before. Replace that and clear the codes. It will probaly be ok, unless the other stuff really needs to be replaced
Old Nov 16, 2005 | 09:52 AM
mjb95maxse's Avatar
thanks... could the ks also cause 02 sensor code or is it likley that is bad to?
what is the evap canister purge control valve/solenoid valve anyways i cant find any info on it?
Old Nov 16, 2005 | 12:23 PM
ronin22357's Avatar
it might, you should check out your sensors with a DVOM. If you dont have a haynes manual you should get one. lots of good info in there
