9004-9007 coversion Wire help
Old Nov 18, 2005 | 01:15 AM
hdiggeddy's Avatar
I have read the How To's and it doesnt say which wires are which. I know i need to swap the ground and the low beam but which is the low beam wire? I cannot tell the difference between the high and low.
Old Nov 18, 2005 | 03:28 AM
maxgtr2000's Avatar
KH3 by popular demand
Test light would help.: The low beam wire is the middle wire, ground should be black.
Old Nov 21, 2005 | 10:02 AM
acad26's Avatar
wiring harness?
Where can I buy an upgraded 9004-9007 conversion harness that is specifically for a 98 Maxima???
Old Nov 21, 2005 | 01:59 PM
Linkage23's Avatar
ebay...got mine delivered to my door for only like $13...search eBay! Good luck!
Old Nov 21, 2005 | 02:10 PM
2 Da Max's Avatar
read his how to, its in there
Old Nov 21, 2005 | 03:10 PM
Maxima lover
I’m pretty skilled when it comes to electronics especially with the max and I found it wasn't necessary to get new harnesses. I just cut and resoldered the wires and it works great. I have plenty of light output and have not had one problem with it.
Old Nov 21, 2005 | 03:30 PM
tedo007's Avatar
faster than you think
vqpower.com i did it on my car it is best mod i ever did
Old Nov 22, 2005 | 03:51 PM
RA030726's Avatar
I'm nutty for Nissans
do you guys think i should do it
Old Nov 22, 2005 | 05:09 PM
crowghost's Avatar
I've been out of the loop for over a year. What advantages do you get for the 9004-9007 if any?
Old Nov 22, 2005 | 08:16 PM
Maxima lover
I wouldn't do it again, if I had known how it was going to turn out. It is a mess to make the bulbs fit and I got shavings all in the houseing. Also to not blind other drivers, I had to aim the headlights down so much it caused pretty nasty looking gaps between the hood and headlights. My whole front is F'ed up anyway, so it didn't really matter. I ended up spending near 1 hour a night for 5 nights aiming them and trying to make them even and look right. I also don't like how the high beam really isn't a high beam.
Old Nov 23, 2005 | 08:24 AM
95gxe_vl's Avatar
Here is what you need to do:
Before:
[] low
[] ground [] high
After:
[] ground
[] low [] high
Hope this helps.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
