Trouble Spots for the Maxima
Old Nov 19, 2005 | 09:59 AM
Mxrider52's Avatar
I support for what?
Here are some known problems that can happen to the 4th gen max. I don't know if this has been posted before or not.
Automatic transmission: The original automatic-transmission (model F04) shift solenoids allowed slipping and premature wear. (1997)
Brake noise: Rear brakes rattle on rough road. (1995)
Brake noise: Groaning from the rear brakes is caused by the parking brakes not fully releasing, requiring new brake cables and pads. (1995-99)
Brake noise: Groaning from rear brakes at slow speeds may be due to binding parking brake cable. 1995-99)
Clutch: The clutch may slip when accelerating hard in 4th or 5th gear due to a problem with the friction material. (1995)
Engine knock: Spark knock or ping may result from a defective onboard computer. (1995-97)
Engine noise: Noise from the front of the engine may be caused by excessive play in the timing chain for which a new tensioner and chain guide are required. (1995-96)
Hard starting: Hard starting, stalling, or stumbling under load could be caused by corrosion of the coolant sensor. (1995-96)
Hard starting: If the engine does not start on the first attempt, the engine may crank very slowly on the second attempt because of a problem with the engine-control computer. (1995)
Rough idle: Several problems (no-start, no A/C, rough running, etc.) can be traced to broken wires in the engine compartment where the harness bends near the right strut tower. (1995-97)
Rough idle: Rough running engine accompanied by check engine light may require revised powertrain control module. (1997)
Old Nov 19, 2005 | 10:05 AM
wannaboostbad's Avatar
NOt really a problem but..........
Parking Cables could be pinched when racked up cutting up the plastic housing rusting the cables. possibly sticking ur calipers...
Old Nov 19, 2005 | 10:21 AM
Bobo's Avatar
I have a 95 Maxima and have never experienced any of the above-noted problems.
Old Nov 19, 2005 | 10:28 AM
Garrick's Avatar
Don't forget the knock sensor, thermostat, STARTER, there are many more common problems with our fourth gens. I never experienced any of the above.
Old Nov 19, 2005 | 10:37 AM
NmexMAX's Avatar
dot dot dot ...
is this ... Way to cut and paste
Old Nov 19, 2005 | 03:22 PM
4DRSpeed's Avatar
Project Ruby......
Congratulations, would you like a cookie??
Old Nov 19, 2005 | 03:49 PM
JwaxMax99's Avatar
Yey, he gets a little turkey sticker like my 2nd grader's math sheet.
Old Nov 19, 2005 | 06:38 PM
NmexMAX's Avatar
dot dot dot ...
This thread gets no cookies
Old Nov 19, 2005 | 07:36 PM
goldtooth's Avatar
LMAO....
anyways, ARE U MAD ???
what about the notorious 1999's coil packs ????????????????? and becuase this list is particially completed =
Old Nov 19, 2005 | 07:47 PM
Cosmo459sx's Avatar
Originally Posted by goldtooth
LMAO....
apparently we have a saturday night thread flamer, how special. Besides, you must post nothing short of a dissertation. If anyone has any idea of what you are talking about, they will put it in your face that it is already known.
carguy96
20
Feb 6, 2021 06:21 AM
Slamrod
Apr 10, 2016 05:24 PM
Finkle
Sep 27, 2015 09:53 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
laparka66
Aug 6, 2015 09:36 AM
