cold starts....even colder driver!
Old Nov 20, 2005 | 06:17 AM
goobergo's Avatar
Cookin' with Gas!
OK, so I've come to decide as it is starting to get cold outside for the first time since I've had my max, the heater sucks. I've tried letting my car warm up in the morning for ten to fifteen minutes and I still freeze. Anyone else feel the same way? I just needed a place to complain...I hate being cold...maybe I need to move to the coast, there's more max owners out there anyway
Old Nov 20, 2005 | 06:21 AM
FunLovinMaxima's Avatar
From: a charming town in Connecticut first settled in the 1600s
off topic! but uh, yay for my heated seats!
Old Nov 20, 2005 | 06:47 AM
maxgtr2000's Avatar
KH3 by popular demand
Could be a bad thermostat, remote start in your friend, especially in that state. I'm in TN and it's been 25-30 in the mornings now. Remote start? You better believe it. You can even set most of them to start every 3 hours if it gets really cold.
Old Nov 20, 2005 | 06:54 AM
njmaxseltd's Avatar
Getting hot heat could be as easy as changing your thermostat.
Does it take a long time for the temp gauge to rise up to the middle? If so then it's a simple thermostat change that will warm things up for you.
If the temp gauge goes go up to the mid point, but you still don't have hot heat then you need to check for proper coolant flow through the heater coil. There's a water control valve that might be stuck or the heater core itself may be clogged.
Old Nov 22, 2005 | 06:25 AM
macman64's Avatar
Yeah, I would check the thermastat. Is the blower working ok?
Old Nov 22, 2005 | 12:50 PM
4thgenx42's Avatar
It is a bad thermostat. Also it necessarily isnt bad it could be a low temp. thermostat, those are usually used in warmer states. Try going your local Nissan dealer and picking up an OEM thermostat.
Old Nov 22, 2005 | 03:09 PM
Rich1995's Avatar
my max's heater works magnificently im 100% heated within 5 minutes of starting it up early in the morning
Old Nov 22, 2005 | 03:27 PM
RockfordMax's Avatar
Back from the dead
ooh lol then i might have a bad thermostat too! dammit thats why i need to stop reading here. Ignorance is bliss is money
Old Nov 22, 2005 | 03:28 PM
kcryan's Avatar
change the coolant seriously, it helped me
Old Nov 22, 2005 | 05:20 PM
a3gus's Avatar
Check this out, maybe this would help.
http://www.jatan.net/tsbs/042202.pdf
Mar 12, 2020 12:06 AM
03VQMAX
Nov 10, 2015 03:39 PM
msellas
Sep 23, 2015 09:16 PM
95naSTA
Sep 21, 2015 06:50 PM
Bonka
Sep 14, 2015 11:18 PM
