5 speed flywheel removal
Old Nov 21, 2005 | 10:46 AM
dgeesaman's Avatar
Maintenance Monster
When I did my clutch job in the spring I didn't remove the flywheel since I didn't have a good stopper or an impact wrench. This time (tranny rebuild), I intend to resurface it.
Any tips on making/finding/borrowing a flywheel holder? I'd rather do that than buy an impact wrench for just this job.
Once the bolts are out, is it easy to remove? (My RX-7 flywheel needed hours of beating it with a dead-blow mallet to pop loose!) I sure hope this isn't as punishing.
Dave
Old Nov 21, 2005 | 10:58 AM
GodFather's Avatar
Made in Taiwan
good luck with that, i still think you'll need that impact wrench to ease out this operation because i never heard of a flywheel holder yet on this org. i know what it is, but i never heard of one here. good luck.
Old Nov 21, 2005 | 11:01 AM
Jeff92se's Avatar
I'm needing a caw
Impact wrench is the easiest. You can try a good electric one. Even if you have to rent one, it's worth it.
Old Nov 21, 2005 | 11:08 AM
dgeesaman's Avatar
Maintenance Monster
So you're saying once I have the bolts off, it pretty much comes right off? That's good to hear.
Well I have a kickass air impact, (IR 600ft-lb), but I don't yet own a compressor and last time I used it I drove across town to rent one for $80. Then I have that massive thing clogging up my tiny workspace. I've heard such good things about electric impacts I might need to buckle up and buy one.
Pity though, as a flywheel holder might cost $20 and it's the only thing I anticipate needing the impact for.
Dave
Old Nov 21, 2005 | 11:12 AM
Jeff92se's Avatar
I'm needing a caw
The holder might be a good investment. I've ghetto rigged something to hold the flywheel and it's always a hassle. If you have the holder, you can just put a breaker bar on the bolts and get them off. But make sure you use a 6 point socket
Old Nov 21, 2005 | 11:17 AM
VQ2fast4U's Avatar
When I removed my flywheel it really wasnt that bad. I didnt need to use an impact wrench, just a little more muscle and liquid wrench. Maybe I was just lucky.
Old Nov 21, 2005 | 11:18 AM
dgeesaman's Avatar
Maintenance Monster
How did you keep the flywheel from rotating? Does anyone know where to buy a flywheel holder?
Dave
Old Nov 21, 2005 | 11:27 AM
VQ2fast4U's Avatar
What I did was spray the bolts with liquid wrench, wait for it to seep in. Put the socket wrench on and tap it with a brass hammer. Once the bolts broke loose i just racheted them out.
Old Nov 21, 2005 | 11:30 AM
dgeesaman's Avatar
Maintenance Monster
I think I'll try that, and if it doesn't work, I'm headed to Sears for an electric impact. Much as I like new and useful tools, that money needs to go elsewhere right now.
Dave
Old Nov 21, 2005 | 11:48 AM
mtrai760's Avatar
'Trynna' is not a word
The flywheel on the maxima is TOO easy to get off, Ive never had a problem with 4 or 5 Ive pulled. Just use a screwdriver with a square shank... there is a hole you can wedge the screwdriver in, then stick the body in the flywheel teeth. It won't damage anything, and it holds the flywheel so you can break the torque, or apply it, when removing and installing a flywheel. Too easy.
Old Nov 21, 2005 | 11:59 AM
tavarish's Avatar
fwd gone rwd cr00
or you can turn on the car and just hold on for dear life.
-get a screwdriver, wedge it in (there's a little slot)
or you could get an electric impact gun, should work very well.
-Freddy
Old Nov 21, 2005 | 12:00 PM
dgeesaman's Avatar
Maintenance Monster
Hmm, I looked for a place to try something like the screwdriver trick but didn't see it the first time. Anyway, I'll look harder this time - thanks for the idea.
Dave
Old Nov 21, 2005 | 04:33 PM
ThurzNite's Avatar
Yeah, I used my 3ft long flat screwdriver. I went through the top, near the iacv, and stuck it into the teeth. The bolts aren't on too tight, maybe 75lb/ft.
Jae
Old Nov 22, 2005 | 03:50 PM
RA030726's Avatar
I'm nutty for Nissans
buy the tool and do it right http://www.justoffbase.co.uk/s.nl/sc...t.A/id.7469/.f
Old Nov 22, 2005 | 04:35 PM
dgeesaman's Avatar
Maintenance Monster
Well, I'll be cowkicked?! I've never seen that tool before. If I get stuck, I'll order one from a state-side tool supply like this one.
Old Nov 22, 2005 | 04:50 PM
RockfordMax's Avatar
Back from the dead
Haynes recommends using a screwdriver, If it worked for them it should work for you.
James92SE
142
Jan 2, 2024 09:23 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
Djsmaxima
Sep 14, 2015 11:58 PM
Maxxx10
Sep 13, 2015 03:16 PM
I<3 A32's
Sep 10, 2015 11:07 AM
