OBDII on a 95?
Old Nov 23, 2005 | 08:48 AM
cardana24's Avatar
Blown
OBDII on a 95?
So can you not use an OBDII scanner to get codes off a 95? I am reading a bunch of adds for them and it seems as if 96 is the first year you can use this on.
Old Nov 23, 2005 | 08:54 AM
njmodi's Avatar
Do I get a tax break?
This question comes up over and over again - i.e. where 95 Maxima's OBD-II compliant. I think OBD-II compliance was mandated for ALL manufacturers/models from 96-onwards. That doesn't mean that manufacturers didn't support it in 95. If you can pull codes at Autozone from your Max using their code reader, then you are OBD-II compliant.
I think this is answered in detail in the FAQ sticky... i.e. whether or not the 95s were OBD-II compliant. IIRC, they are.
Old Nov 24, 2005 | 12:30 AM
BigBadBen's Avatar
I have the Auto Enginuity scan tool and used it on my 95'Max to diagnose a faulty Bank 2 O2 sensor so in answer to your question, it is OBDII compliant and has the D shaped connector in the passenger side footwell on the center console side.
Hope that helps.
Ben
Old Nov 24, 2005 | 05:10 AM
njmaxseltd's Avatar
There are early build 95's that are not OBDII compliant.
Old Nov 24, 2005 | 06:30 AM
Tatanko's Avatar
Bacon Lover
D-shaped? Mine is just square
I have an early build '95. Perhaps I don't have OBD-II compliance? Odd...I use the OBD-II scanner at Advance Auto all the time and never have problems.
Old Nov 24, 2005 | 07:09 AM
pmohr's Avatar
No more Maximas...
Is that documented somewhere on the org? I can't see them possibly changing something that large part way through a model year.
Old Nov 24, 2005 | 07:14 AM
Jason R's Avatar
aka UNCDooD
omg....yes ALL '95 maximas are OBD-II. the plugs are just in a different place than the 96-99s.
Old Nov 24, 2005 | 07:21 AM
pmohr's Avatar
No more Maximas...
Also, what would you consider 'early build'? My build date is 02/95, and she's got OBD-II.
EDIT: Here we go - http://forums.maxima.org/showthread....arly+build+obd
All OBD-II. But seriously, to stop this **** - the plug in the fuse box next to the steering wheel is CONSULT, the one on the passenger side is the OBD-II connector.
Oh god, if people would just search/read.
But there was one nice little quote from that thread:
Originally Posted by MIXXMAX
The connector for troubleshooting DTC codes is located on the right side below the fuse block cover plate. As far as that connector on the passenger's side, that is the connector for the transmission computer. I had a Nissan technician once riding with me and he plugged the consult tool into this connector plug on the passenger's side. Here, when the car is driven, he can monitor the RPM's and how the car shifts.
Old Nov 24, 2005 | 08:17 AM
njmodi's Avatar
That might be true on the 95s. On the 96s and newer the OBD-II port is right near the fuse-box on the drivers side.
Old Nov 24, 2005 | 08:23 AM
Jime's Avatar
I have an 03/94 and its still OBD-II. The OBD-1 95's are similar to the Saskquatch, people claim to have seen one but forgot to take a picture.
Old Nov 24, 2005 | 08:41 AM
SMX95's Avatar
ALL 95 maximas have a OBD2 port. My for example is an early 95 made maxima. Built in 94. Go to your passenger side, duck underneath where your feet usually are, look towards the inner side (ECU, RADIO, Shifter SIDE) There is a plastic cover with 2 plastic clips. Remove the clips and towards the back side (towards the shifter direction) on the top corner will be the port.
Old Nov 24, 2005 | 10:15 AM
Supermax95's Avatar
+1 everyone tends to disagree, but my 95 WAS odbI.....I am very mechanically inclined and i remember specifically i had an obdI.
Old Nov 24, 2005 | 10:18 AM
pmohr's Avatar
No more Maximas...
Do you have a picture of where the OBD-II port is supposed to be? And when was it manufactured?
Without proof, I call
Old Nov 24, 2005 | 10:26 AM
SMX95's Avatar
womp womp, I can get a digi camara from my girlfriend.. My car is broken its not going anywhere anytime soon... You can also step outside and open up your passenger side door, crouch down to look underneath your dash, Locate the ECU remove that plastic cover and bingo there it is................. But you want proof anyway, sooo give me an hour or so
Old Nov 24, 2005 | 12:16 PM
99Automagic
I've used my obd2 scanner on numerous 95 maxs, and up, including my 99. So unless I see some actual proof of a 4th gen max being equipped with obd1, this theory will be tucked away in the dark part of my brain, where rarely accessed data resides comfortably with Santa, the Tooth Fairy, and the Easter Bunny.
Old Nov 24, 2005 | 12:18 PM
SMX95's Avatar
In 95's under the steering wheel there is a 0bd1 connector BUT! passenger-side by the ecu is the ob2 connector. Don't ask me why I heard its like obd 1.5 or something.
Old Nov 24, 2005 | 12:22 PM
Tatanko's Avatar
Bacon Lover
I'll have to look when I get home.
So what you're saying is...perhaps it's an OBD-I architecture but with OBD-II stuff implemented and useable, more than likely preparing for the following model year.
Old Nov 24, 2005 | 12:24 PM
SMX95's Avatar
Yeah man, obd1 is in the fuse box there is a connector in there, obd2 connector is on the passenger side right next to the ECU, Ive scanned my car with my obd2 scanner and my schools ob1 scanner from both of those ports. I wish i had my camara i would run outside and take pics
Old Nov 24, 2005 | 12:26 PM
Tatanko's Avatar
Bacon Lover
I never even knew I had an OBD-I port. I've always used the OBD-II when I wanted to pull codes.
Old Nov 24, 2005 | 12:27 PM
SMX95's Avatar
this is only for 95 maximas. I have the early made 95. pull out your fuse box on the drivers side duck down look in there to the side somewhere there is a obd1 connector port, its not held in place its like hanging unless someone broke my braket to hold it?!
Old Nov 24, 2005 | 12:40 PM
Tatanko's Avatar
Bacon Lover
Pretty sure I saw it hanging there the other day and wondered what the heck it was for.
Old Nov 24, 2005 | 12:56 PM
Jime's Avatar
That is the consult port, pull off the cover on the drivers side on the floor and you will see the obd-II connector.
Old Nov 24, 2005 | 01:14 PM
Tatanko's Avatar
Bacon Lover
My OBD-II connector is on the passenger's side
Old Nov 24, 2005 | 01:35 PM
Jime's Avatar
Sorry passenger side you are correct. Consult is in fuse box and obd-II is on the pass side right beside the ecu. This only applies to 95's.
Damn don't you just love it when a 16 yr old is right. Hey I have no problem with age, we are never to old to learn. We just have to be adult enough to admit when we are wrong.
Old Nov 24, 2005 | 03:18 PM
Tatanko's Avatar
Bacon Lover
...and that is what's wrong with the world today.
I'll be 17 on sunday, btw
Old Nov 24, 2005 | 06:45 PM
SMX95's Avatar
Never knew it was called the consult port, my school did hook up the obd1 scanner in that port.. Makes more sense now. But yes, I have been right in this thread, Most people don't bother to realize that pics dont justify everything, just get on your back and check lol.
Old Nov 24, 2005 | 07:52 PM
99Automagic
Maybe I didn't check enough, but I never saw another port to connect my scanner. The first 95 max I ever attempted to use my obd2 reader on, I checked under the steering wheel for a port, which is where it is on my 99, and when I couldn't find it there, I looked around the ecu and found it on the passenger side. Since the port I found on the passenger side worked flawlessly with my reader, I assumed it was obd2, and looked in the same two spots for a port everytime I hooked up a reader to a max, which there always were. Regarding the Consult port, IIRC, my 99 has one right next to the fuse box. I haven't looked in there in a while.
Old Nov 24, 2005 | 08:15 PM
SMX95's Avatar
Yes I did connect a OBD1 scanner to the consult port, I did assume that was the OBD1 port, but it didn't make sense why there was an OBD2 port on the passenger side next to the ECU. Not sure if in 96-99 they relocated the port for OBD2 under the steering wheel. OBD2 was manditory for every vehical in 1996. The codes and ports would be the same in every asspect. Over some time as OBD2 got more advance more codes were added. Now for when OBD3 comes out and what will it feature will be another story for itself. All I can provide is that it will monitor and record live data, it can also be used to send information back to a dealership. Kinda like on-star your whole life is being recorded. As for codes im not sure will be added to the list.. Im not sure if the ports will be the same. I will have to talk to my co-worker who is taking classes on OBD3, so he would know best.
Old Nov 24, 2005 | 08:49 PM
Jime's Avatar
If any of you are interested you can buy a consult interface that will do much more than the OBD-II readers. http://www.plmsdevelopments.com/consult_if.shtml
I have one of these and it works great. You can even do 0-60, 0-100 tests etc. You can turn you radiator fans on and off, change timing and a bunch of other stuff. However the readings will revert to stock when you turn the car off.
Old Nov 25, 2005 | 12:16 AM
Nealoc187's Avatar
SLOW
How do you know your car was not OBD-2?
Old Nov 25, 2005 | 12:32 AM
Supermax95's Avatar
it might have been both as stated earlier, but i used obdI for both my smog and once when i had my cel code checked....
Old Nov 25, 2005 | 11:41 AM
Nealoc187's Avatar
SLOW
What was the build date on your car?
Old Nov 25, 2005 | 02:27 PM
Tatanko's Avatar
Bacon Lover
What do you mean you "used" OBD-I? Where was the plug located that you used, and what did it look like?
Old Nov 25, 2005 | 02:32 PM
Nealoc187's Avatar
SLOW
The plug location is why many people "think" they have OBD-1 in the first place. OBD-2 was not MANDATED until 1996 model year, in that year is when they STANDARDIZED where the plug HAD to be located. Before 96 model year, cars could have OBD-2 plugs in other locations, they didn't have to be in the "standard" location until 1996 model year. In 1995 they could have put the OBD-2 plug in the trunk if they wanted to. That doesn't mean the car is not still OBD-2, it just means it was made before OBD-2 was mandated and standardized.
Old Nov 25, 2005 | 04:13 PM
Supermax95's Avatar
it was an obdI plugi believe it was next to or in the fuse box., thats all i remember. When you get a smog check done in california they connect a comp up to your car through odb. as for the build date i have no idea i sold that car over 2 years ago...
Old Nov 25, 2005 | 06:11 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
the "obd1" plug in the fuse panel is not true OBD-1 it is just a diagnostic port to connect to. from an aftermarket scan tool or OEM scantool. i believe the adapter for snap on is called NISSAN-1. I believe in an article i read you can reset the pcm by jumping two pins in that port, and you can also read ABS codes.
You cant have 2 computer systems. You either have 1 or the other. If you have the 16pin connector (obd-2) then you have obd-2. If you have both connectors, then your car is still OBD-2.
Old Nov 25, 2005 | 06:18 PM
Jime's Avatar
The other connector is the Consult port which you can hook a consult interface to. They are available for purchase and do much more than an OBD-II reader. I have both and there is a URL in my previous post where you can buy them for approx $100.
Old Nov 25, 2005 | 07:26 PM
Tatanko's Avatar
Bacon Lover
Why don't people ever take the time to read the whole thread anymore? This is the reason people STILL insist 95's had OBD-I...
Old Nov 25, 2005 | 07:40 PM
Supermax95's Avatar
well i dont know whether or not it had an obdII connection or not, but i do know that the odbI was used for my smog check and diagnostic.....
Old Nov 25, 2005 | 07:49 PM
Tatanko's Avatar
Bacon Lover
It had no OBD-I. I will place money on it. They probably used the CONSULT port, which people have claimed earlier in this thread that they have used the same way as an OBD-I port (i.e. it's not a true OBD-I port, but OBD-I scanners still make use of it).
