Heater Dont Work
Old Nov 23, 2005 | 05:31 PM
Makavelidadon's Avatar
Heater Dont Work
Guys, my heater dont work in my car......... the problem is, when the car is idle it blows out cold air, but when im driving it blows out warm(Not hot) air, and as soon as i stop at a redlight it blows out Cold air...................................anyone have any idea what could be wrong with it?
Old Nov 23, 2005 | 05:35 PM
njmaxseltd's Avatar
Check the anti-freeze/coolant level, both the reserve bottle and the radiator level.
You might have a leak.
Old Nov 23, 2005 | 05:38 PM
i checked it today, and the antifreeze on the reserve was dry!!! i just put some in today, and i hope it solves it!!!
Old Nov 23, 2005 | 09:02 PM
HondaKiller718's Avatar
This has happened to me many times. I have gone thru a few radiators. Check to see where you are leaking from and if you can not tell you can have the radiator pressure tested for around 20 bucks ( or free) at a local auto shop. This will let you know if its a hose, the radiator, water pump and so on.. then you know how much you have to spend to fix it, if its the radiator buy it from www.radiatorbarn.com, got mine all metal , all black for 119.00 shipped. PM me if you need help replacing the radiator its very simple.
Old Nov 23, 2005 | 10:10 PM
oldskooljdm's Avatar
check coolant and also check thermostat.....i had the same problem. thermostat was stuck open allowing to much coolant to flow. Does the temp gauge go up around half way like normal or does it stay on or close to cold all the time?
Old Nov 24, 2005 | 12:28 PM
The temp gauge rised to about close to Hot.
Old Nov 24, 2005 | 12:29 PM
how do i check the thermostat???
Old Jan 18, 2009 | 05:20 AM
jsizzle_at_609's Avatar
i HAVE THE SAME PROBLEM I JUS FILLED MY TANK AND ITS LOW AGAIN
Old Jan 18, 2009 | 08:24 AM
Derek97GLE's Avatar
Sounds like a thermostat to me. Can you smell any coolant inside the car? It will smell sweet, almost like syrup (delicious, but don't eat it.)
Old Jan 18, 2009 | 09:24 AM
DennisMik's Avatar
You have a leak somewhere but there are a lot of 'somewheres'. The radiator could have a leak, any of the many hoses could have a leak, the heater core could have a leak, the water pump, the engine head gaskets could be leaking - just to name a few.
When the engine is cold, remove the radiator cap and fill it with water and put the cap back on. While you're at it, fill the overflow tank too. Start the car and let it get warm (it will warm up faster if you drive it). Then park the car so it is over a clean, dry spot. Leave the car running and look for a water leak, checking all the hoses and everyplace you can, top and bottom. When you find a leak, we can give you more detailed advice.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
