advanced posters beware
Old Nov 23, 2005 | 07:17 PM
Rich1995's Avatar
this is a noob question that you can probably solve in one redirection of a link but
i can literally see NOTHING at night...the stock headlights never were bright enough for my mom when she just bought them and even changing the bulbs recently fixed nothing....what is the cheapest option eg: what "halogen" looking bulbs will fit in the stock casing or how easy is it to get totally new headlights and install them yourself..if so..what are the best ones and how much am i looking at spending
plus..can an idiot like me install them himself?
thanks in advance
Old Nov 23, 2005 | 07:22 PM
95jr6708's Avatar
Dont know if i know why you can't see. But a suggestion for some brighter headlights are silverstars for about $20 a bulb. They are bright. Couldn't tell you either if an "idiot" like yourself could do it. But if you have any knowledge on a screwdriver and patience you can. but goodluck.
Old Nov 23, 2005 | 07:28 PM
Rich1995's Avatar
haha im not THAT bad of an idiot ive just never worked on the engine itself only on the stereo and exterior but i just dont want to make a bad move and get zapped switching out a whole headlight case
what i mean by not being able to see is that the yellow light just doesnt go very far and creates a horrible glare where i cant see the lines of the road right after it rains...its kinda hard to explain but i know i need something better than the stock yellow lamps
Old Nov 23, 2005 | 08:20 PM
rsly33's Avatar
reaim your headlights
Old Nov 23, 2005 | 08:21 PM
NYC_Maxima97's Avatar
9007 bulbs
Old Nov 23, 2005 | 08:26 PM
RA030726's Avatar
I'm nutty for Nissans
sylvania extra visons
Dave H.'s Avatar
They are bright in good dry conditions, but i can't see well at night when it rains with them. You should try Sylvania XtraVisions. I hear they are the best for poor weather conditions in the 9004 stock form. THese aren't too expensive either, a two pack for around $18. Worth a try. I am as soon as my silverstars burn out.
You could do the 9007 conversion, but you might not want to attempt that, since you aren't too familir with things yet.
Old Nov 23, 2005 | 08:31 PM
DragonMaxima's Avatar
You can always drive around with your High Beams on until somebody flashes you.
Old Nov 24, 2005 | 12:07 AM
sook's Avatar
im gonna second the reaiming. if you cant seen anything, sounds like no light is hitting the road. obviously, the lights are on. must be pointing in the air.
if you were just making a point, get better bulbs. and fogs.
Old Nov 24, 2005 | 05:14 AM
njmaxseltd's Avatar
(Xtravisions)
They are the best stock replacement halogen bulb you can put in your 9004 headlight housings.
You will see the differance.
Old Nov 24, 2005 | 05:15 AM
dgeesaman's Avatar
Maintenance Monster
Maximas have plenty of lighting. Something isn't going right in your car.
1) Make sure your headlights are getting enough power. I think they get a full 12v - you'll need to carefully test this with a multimeter. If it's low, clean up and/or replace grounds and wiring until you get a full 12v. It may be that your alternator is dying if this dimness is relatively new.
2) Use some fine-cut car polish and polish the glass bezels on the headlamps. They should polish down to crystal clear with little effort.
3) If you replace the lights, find a bulb with the SAME WATTAGE as stock. Otherwise the wires will get very hot and melt or start a fire. I'm very serious about that.
Dave
Old Nov 24, 2005 | 10:17 AM
Rich1995's Avatar
thats what i normally do
im gonna go with the xtravisions and see what that does for me...ill probably re-aim them too i think its actually pointing too low to the ground or something i havent really fiddled with them very much...
its not a problem with cleanliness the glass is already crystal clear i take very good care of the outside and interior..
can i pick these bulbs up at like NAPA or is it better to order them online?
p.s. it could very well be that my alternator sucks i was driving around too long with two 15inch subs without a capacitor but like i stated earlier my mom had trouble with it when she bought the car brand new from the dealership
Old Nov 24, 2005 | 10:50 AM
NismoGTR's Avatar
i see u have a 95....Get 97 headlights.....the plastic is more clearer, so that should help a little...Plus it looks good, try aiming like every 1 else said
Old Nov 24, 2005 | 11:33 AM
RA030726's Avatar
Originally Posted by njmaxseltd
(Xtravisions)
hehe i speeld it rong i tink i has a bit 2 mush to drunk lats nite
Old Nov 24, 2005 | 03:58 PM
Rich1995's Avatar
nice Jsutter glad to know im getting advice on my headlights from a drunk guy jk ill definately fork over the 20 bucks for xtravisions but im gonna go downstairs and try aiming them and drive around a little tonight
Old Nov 24, 2005 | 04:18 PM
LeVeL's Avatar
I have a 97 and I see fine in the dark. Thing is, when I turn my high beams on, everything gets darker because they are pointing in the air. I'm guessing I just need to reaim them?
Old Nov 24, 2005 | 04:34 PM
goldtooth's Avatar
With High Beams, you see further, the light is hitting the ground much further. The light is spread much farther than the low beams, thats why. Try this on an empty highway.
Old Nov 24, 2005 | 04:50 PM
LeVeL's Avatar
I can see my high beams lighting objects way too high... like fence tops and stuff so I'm pretty sure that they are pointing up
Old Nov 24, 2005 | 05:40 PM
Loe max's Avatar
Have you been flashed at at night?
Old Nov 24, 2005 | 06:42 PM
RA030726's Avatar
Once, by this hot chic.
Old Nov 24, 2005 | 07:45 PM
99grnmaxgxe's Avatar
I think the cheapest I've seen the Xtravisions is at Wal-Mart for like $16.
Old Nov 24, 2005 | 09:09 PM
matty's Avatar
(Xtravisions)
I cant find these anywhere online...they're not even on ebay listings.
There not silver stars are they ??
-matt
Old Nov 25, 2005 | 08:31 AM
LeVeL's Avatar
Nope. I dont drive with my high beams on normally, only on empty roads when its really really dark. Well that's what I tried but then noticed that high beams on is worse lol
Old Nov 25, 2005 | 12:51 PM
RockfordMax's Avatar
Back from the dead
Well I think he meant that if your lights are aimed too high, its basically the same effect as hi beams and youll get flashed. Happened in my dads BRAND NEW 6TH GEN...nissan quality......yeah the headlights came aimed too high and it was the most annoying thing on earth.
Old Nov 25, 2005 | 12:58 PM
dko's Avatar
dko
duck and cover
do you see fine in other cars? maybe it's just your vision. if you wear contacts a lot of the time that affects your vision at night.
Old Nov 25, 2005 | 03:06 PM
LeVeL's Avatar
Hmmm.... well either way I haven't been flashed. As for my vision, I dont wear contacts/glasses and I do see fine in other cars. It's fine with the low beams on but it just seems like the high beams dim the low beams... not enough power maybe?
Old Nov 25, 2005 | 06:01 PM
toyick's Avatar
Old Nov 25, 2005 | 06:59 PM
loverholic's Avatar
iAMIXAM!
the watage on the bulbs at walmart are 64/45 or 60/45 i think, u need ot get them from the street or the flea markets if there are any in your area, the ones from the street are 100/65. so u get as much light on your low beam as u would have gotten on your high beam when compared to stock or teh ones at walmart.
Old Nov 25, 2005 | 08:34 PM
^^^Don't listen to this guy, higher wattage lights makes your harness melt, so stay within stock standards for light wattage.
Old Nov 25, 2005 | 08:38 PM
loverholic's Avatar
iAMIXAM!
my friend has had them on for over a year, i dont seehis wires melting, mine has been on for a few months and its still in tacked so i dont know what you talking about.
Old Nov 25, 2005 | 08:43 PM
If you don't believe me read this:http://forums.maxima.org/showthread.php?t=442054 or find the other several threads related to it.
Old Nov 25, 2005 | 08:50 PM
loverholic's Avatar
iAMIXAM!
ok cool. well i dont know my friends own hasnt melted yet, ask for mine i''ve been wanting to do the 9004-9007 conversion anyway, i dont think i wanna find ou tif mine will melt or not. lol
Old Nov 26, 2005 | 03:58 PM
ohflguy's Avatar
9007s did wonders for me in my rural area, lots of curves
Old Nov 27, 2005 | 10:21 AM
Rich1995's Avatar
i have 20 15 vision...there aint nothin wrong with me
i can see perfectly fine and far when its perfect conditions out
its only when the rain starts or its that one hour when the sun is just about to be fully gone that i have trouble with my headlights showing up the reflective material on road paint and i cant see the lines at all
Old Nov 27, 2005 | 12:13 PM
maxgtr2000's Avatar
KH3 by popular demand
That's normal then. Where I live it's the same way, the city at the time was too cheap to put in road reflectors and they didn't use reflective paint. Better be right with God when driving at night in the rain.
Only one org member said your 95 lights sux. because the lens is not clear. 10 year old lights probably have alot of haze inside and outside probably alot of scuffs, etc. I would try to improve in order of finances.
1. 9007 conversion with upgraded wattage bulbs AND harnesses (ebay)
2. 97-99 headlights
3. Projectored hids
Old Jan 15, 2006 | 02:25 PM
Rich1995's Avatar
i know this is a very old post and im thinking im just as big of a noob as i was back then but
http://www.amazon.com/exec/obidos/tg...=UTF8&v=glance
or
http://cgi.ebay.com/ebaymotors/BRAND...29884495QQrdZ1
im guessing they are the same bulb...different vendor...is this what i need?
Old Jan 15, 2006 | 03:15 PM
arrrghhh's Avatar
Originally Posted by maxgtr2000
2. 97-99 headlights
3. Projectored hids
+1 for that, this guy knows what's up. of course, he does retrofitting for HID setups, so he *should* know. i highly recommend it, but be prepared to pay $$$. as for those two links, the amazon one was 9004 ST and the ebay one was 9004 ST/2. so i don't know what the diff is, but i'd assume that the ebay ones are newer. i'd just goto my local auto parts store and pick up bulbs, no sense in waiting for shipping & what not, then you can easily return the item if you are dissatisfied with it.
Old Jan 15, 2006 | 04:36 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
ive got a 99 with the stock driving lights. i reaimed he stock headlight and driving lights a smitch higher and replaced them with silverstar bulbs. there is PLENTY of light i dont need hids or anything like that. there is excellent light on my car.
Old Jan 15, 2006 | 05:27 PM
Rich1995's Avatar
i appreciate all the life stories but come on can someone answer my origional question?
i dont want anything to start melting on me after i spend 40 bucks on new bulbs
whats the difference or can i get a link or part number or something to make this easier
Old Jan 17, 2006 | 11:50 AM
incognito903's Avatar
my $.02 dude dont buy silverstars. i put them in my 323i, they burnt after a few months ive seen many other posts on here before i signed up talking about short lived silverstars just a tip for u.. try xtravisions ive seen them in person
and ur rite about the life stories haha
