oil change ... please help me (97 max)
Old Nov 24, 2005 | 02:14 PM
safari2005's Avatar
I am trying to remove the drain plug (ofcourse first time oil change) by using
14mm wrench, but it's not loosen at all, even i use lot of force. I am trying to loosen the plug in the clock wise direction.
am i doing something wrong.....please help me.
(the plug was tightned by the dealer)
Old Nov 24, 2005 | 02:16 PM
MaDMvD's Avatar
Ummm...righty-tighty lefty-loosey?
Old Nov 24, 2005 | 02:19 PM
mendon99's Avatar
tastey wheat
WD-40? it cant be THAT tight
njmodi's Avatar
Do I get a tax break?
Clockwise is correct... (i.e. lefty-loosey). Just get a rubber mallet and tap the rachet/wrench and it will break loose. Most likely it's just overtightened. Or get a breaker bar and a 14mm socket...
99grnmaxgxe's Avatar
^lol, but if you can't get it out at all, take it to the dealer and tell them to loosening for you.
Old Nov 24, 2005 | 02:54 PM
maxspeed96's Avatar
Counter clockwise is to loosen it.
Old Nov 24, 2005 | 03:12 PM
pmohr's Avatar
No more Maximas...
...Are you serious?
...you've already got your answer, I'm just wondering whether or not you're serious about this question.
Old Nov 24, 2005 | 03:16 PM
MorpheusZero's Avatar
c'mon guys.
Old Nov 24, 2005 | 03:20 PM
Nissan 6's Avatar
you need muscles
Old Nov 24, 2005 | 03:32 PM
kormax97
lefty loosey... you have to turn it left... meaning oppsite of the clock's hand movements... like 12...11...10...9... last time i checked... that's counter-clock wise...
Old Nov 24, 2005 | 05:59 PM
njmaxseltd's Avatar
I don't think he should be working on his car at all.
Please step away from the vehicle and go directly to a quick lube center from now on.
I can't even imagain whats gonna happen when he gets to the oil filter.
Old Nov 24, 2005 | 06:02 PM
pmohr's Avatar
No more Maximas...
Old Nov 24, 2005 | 06:40 PM
RA030726's Avatar
I'm nutty for Nissans
"Heh heh heh, you said 'Quick Lube'."
Beavis & Butthead
Old Nov 24, 2005 | 08:28 PM
95jr6708's Avatar
I am having trouble deciding if this thread is a joke or not?
Old Nov 24, 2005 | 08:34 PM
JwaxMax99's Avatar
Get your ratchet, turn the switch to 'off ' No thinking then!
Better yet, use your impact wrench!
Old Nov 24, 2005 | 08:46 PM
MaxRolla's Avatar
eat some spinach
-Tyler
Old Nov 24, 2005 | 09:25 PM
konak85's Avatar
you sure your turning the right bolt?
Old Nov 24, 2005 | 09:31 PM
Fr33way™'s Avatar
Wild for Width
http://forums.maxima.org/showthread.php?t=441902
This is where I answered this duplicate thread 7hrs. ago . . .
Old Nov 25, 2005 | 12:52 PM
RockfordMax's Avatar
Back from the dead
Lol mine was a 13mm....
Old Nov 25, 2005 | 12:56 PM
2 Da Max's Avatar
i hope hes not loosening the bolt on the tranny pan
Old Nov 25, 2005 | 08:11 PM
the_3d_man's Avatar
wtf... you gotta be kidding...
lol
Old Nov 26, 2005 | 10:40 AM
rdbaron9's Avatar
Counter-clockwise. when in doubt, take your right hand point your fingers towards the sky. Curl your fingers in a counterclockwise direction and your thumb points "out" toward you. If you turn your arm and curl your fingers in a clockwise direction your thumb points "in" as in a bolt going into a hole. Difficult to explain on paper, but before you go using a breaker bar or impact you better know know what direction to turn it.
Old Nov 26, 2005 | 03:12 PM
MaxMateo5's Avatar
There should not be more than one person on this site that doesn't know how to losen a f&ckin bolt...
If you losen it counter-clockwise and it doesn't come off-take it to a shop and tell them to hand tighten it because they should not tighten an oil bolt with an airtool...
Old Nov 26, 2005 | 03:21 PM
maxima_kid's Avatar
This thread is getting dumber and dumber with wrong info everywhere but I can stop reading on for some reason ...
Old Nov 26, 2005 | 03:38 PM
joosdawg's Avatar
wow what is with this thread? i want my last min back that i wasted
Old Nov 26, 2005 | 03:41 PM
(_8*(l)Homer's Avatar
I've seen mechanics use impact wrenches to install drain plugs at the local 10min oil change joint.
Old Nov 26, 2005 | 03:45 PM
joosdawg's Avatar
Then you better stay far away from that place, thats the stupidest thing ive heard anyone doing in a while. the damn things are only supposed to be like max 30 ft lbs. Using an impact wrench would clearly rip the threads right out of the pan. -Ryan
Old Nov 26, 2005 | 08:22 PM
maxima_kid's Avatar
Even if the limit is 10 minutes, it takes 2 seconds to screw on with your hands and an extra sec to tighten. The pan is extremely thin compaired to the rest of the car. Just wait til they strip it with the impact.
Old Nov 26, 2005 | 08:46 PM
venturous's Avatar
It is clockwise if you are looking down from above thru the engine.
Old Nov 26, 2005 | 08:50 PM
joosdawg's Avatar
ITS NEVER CLOCKWISE EVER!!!!!!!!!!!!!! unless your small enough to fit inside your oil pan and see it rotate outwards or have xray vision from the drivers side
Old Nov 26, 2005 | 09:56 PM
maxima_kenny96's Avatar
technically you COULD loosen it turning it clockwise...I just dont recommend that way, cause then u might need a press of some sort....oooorrrr be smart and invest ina breaker bar for future expierences such as that
Old Nov 26, 2005 | 09:59 PM
future's Avatar
this tread is crazy
Old Nov 26, 2005 | 10:03 PM
maxima_kid's Avatar
Seriously, how do you get to your drain plug from the top of the engine bay? You guys are just confusing the poor kid.
Old Nov 26, 2005 | 10:07 PM
nahhhhhh he'll get it lol. it takes practice, oh and while ur under there make sure ur horn fluid and blinker fluid are good to go, I hate when mine run out.
just playin man.
Old Nov 26, 2005 | 10:17 PM
loverholic's Avatar
iAMIXAM!
have you all realized that the kid ask a dumb question and left you all to fight over it, but if he was serious.............THATS ONE DUMB@$$ KID!!!!
i cant possibly see how someone can not loosen that bolt no matter how tight it is, use ur head bro, try something, ir else u will just continue being a wasted batch of sperms.
Old Nov 26, 2005 | 10:20 PM
its not really a batch, it only takes one....
Old Nov 26, 2005 | 10:22 PM
loverholic's Avatar
iAMIXAM!
thanks for the correcting, then he's a wasted sperm lol
Old Nov 26, 2005 | 10:42 PM
skoobahead's Avatar
Drill a 1/2 inch hole into the bottom of your oil pan. (Do not remove drain bolt because it is welded shut at the factory). Once oil starts pouring on the ground, immediately tap oil filter with large mallet. This will loosen all solids in the filter. Sometimes a sawzall will be needed to remove the oil filter. Remember to put sawzall in reverse to loose the filter. Once oil and shavings are on ground, flush out oil system with cold tap water. This water will cool your bearings and prep them for the new oil. Finally tape closed the hole you just drilled into oil pan and add 5 qts of 75w-90 gear lube to crankcase. Thicker is always better. Just think of when you eat pancakes...thicker syrup taste better right?
Now fire up the engine and hold at redline.
That's it! Your done.
Old Nov 26, 2005 | 11:25 PM
Sharp's Avatar
way to welcome someone to the forum....
Old Nov 26, 2005 | 11:26 PM
joosdawg's Avatar
i love it!
