My Maxima is on its last breath!!!
Old Nov 24, 2005 | 02:20 PM
goldtooth's Avatar
So Im going to work and stopped at a red light. Then I start to smell something. It is cold outside and my windows are rolled up and heater is on low. Then some light bucking occurs while I am stopped. Later, the bucking is so nasty and violent that it is unbarable, but the car still never shut down. Then I start seeing smoke; more and more of it. I notice that it is bluish colored. WTF HAPPENED TO THE CAR ??? When I tried to accelerate harder by gunning it, power has been lost tremendously. I tried that only once.
Any ideas??
Old Nov 24, 2005 | 02:23 PM
Bobo's Avatar
Have you checked your fluid levels for starters, eg. oil, coolant?
Are there any noticeable leaks?
Does the car start readily once its cold?
Old Nov 24, 2005 | 02:59 PM
goldtooth's Avatar
The car starts the same as before, before this happened. Leaks I see none. Fluid levels I am going to check now.
Old Nov 24, 2005 | 03:16 PM
pmohr's Avatar
No more Maximas...
So you were sitting there, notice smoke and something smelling, not only do you not pull over and check the car out, you proceed to floor it to see if that would do anything?
Hmm. Interesting.
Where did the smoke come from, tail pipe or engine bay? Blue smoke (IIRC) is oil burning (white = coolant, black = engine too rich, fuel burning).
Old Nov 24, 2005 | 03:21 PM
MaxRolla's Avatar
sounds like somethin that happened to a friend in his camry. i think he blew a cylinder
-Tyler
goldtooth's Avatar
No, I had to get to work(I was like less than 5 min away from work), I didnt floor it then. It was when I was comming home, that I floored it ONCE, and i noticed huge power loss. Smoke comming from tail pipe, I opened hood and no smoke was present.
Old Nov 24, 2005 | 03:23 PM
goldtooth's Avatar
Earlier in the day, my mom was using the car, and she called me and said that she cant start it. I told her to pump the gas pedal 3 times, then start it. The car had started. Later Im sitting at red light and the car just craps out.
Old Nov 24, 2005 | 07:00 PM
SRJesse's Avatar
pmohr - "So you were sitting there, notice smoke and something smelling, not only do you not pull over and check the car out, you proceed to floor it to see if that would do anything?
Hmm. Interesting."
SRJesse - all stock - not for long...
Missing my SR20DET 240sx
FWD for now, RWD for life
Old Nov 24, 2005 | 08:16 PM
MaxRolla's Avatar
thats what happened to my friend. he hardly ever put his foot on it and the car just took a ****. not sayin its the problem for sure but def somethin ta look into
-Tyler
Old Nov 24, 2005 | 08:19 PM
goldtooth's Avatar
Hmm. Interesting."
WTF is the point of this **** ???
Old Nov 24, 2005 | 08:21 PM
goldtooth's Avatar
-Tyler
No **** sherlock, Im just gunna ignore everything that happened. Does it look like I want to know that the same thing happened to your friend. At least say how he fixed it or something ......
Old Nov 24, 2005 | 08:42 PM
MaxRolla's Avatar
y dont u calm the f*ck down smart@ss. like i said it happend to my friend, i'll ask him what exactly happened in the morning and let ya kno
-Tyler
Old Nov 24, 2005 | 09:50 PM
kcryan's Avatar
head gasket?
Old Nov 24, 2005 | 10:31 PM
TurTLe*'s Avatar
yea i'm going with your burning oil some way. Maybe the head gasket is leaking.
Old Nov 24, 2005 | 10:38 PM
eyesack killa's Avatar
this happens to my friend tiffany in her 3rd gen. i'll ask her if she ever got it fixed and when i do, i'll report back. i don't think it's not fixable tho, keep ur spirits up man! have faith in ur maxi, and know that whatever goes wrong, you CAN and WILL fix it if you love your car enough. don't give up hope man.
Old Nov 24, 2005 | 10:48 PM
goldtooth's Avatar
Originally Posted by kcryan
head gasket?
Believe it or not, this was my first thought. Then I thought right away " Oh F u c k, Im gunna need an engine transplant"
Old Nov 25, 2005 | 04:03 AM
lilaclucymaxima's Avatar
Team Ramrod
Could be your fuel injectors, that happened to me about a year ago.
Old Nov 25, 2005 | 04:29 AM
Scope's Avatar
Im izz sexay
Or busted coilpack.
Old Nov 25, 2005 | 07:26 AM
Bobo's Avatar
Well, did you check your fluid levels or not?
Old Nov 25, 2005 | 08:33 AM
kcryan's Avatar
all good recomendations, def. check the levels, esspescially oil and coolant, and look for leaks or anything, my guess is if its the head gasket you blew one hell of a hole in it.
Old Nov 25, 2005 | 09:00 AM
2 Da Max's Avatar
if its smoke its a headgasket. this happened to my boys integra, but only because his timing was off which damaged bent one of the valves
Old Nov 26, 2005 | 11:32 AM
goldtooth's Avatar
Well, my dad just took the car to my uncles shop and we'll see what will happen. Either way I think I should start looking for new engine. Is a 2000 engine a direct fit ? If so, I got the 00vi and all those goodies all in one...YES! I know you will tell me to go to the all motor forum, but I just want to know if anyone will throw something at me here. I will keep this thread updated as soon as I find out what is going on.
Old Nov 26, 2005 | 12:09 PM
chilled's Avatar
Sounds like its time to change your headgasket my friend. Don't get a cheap one, use some High Rev to seal it up also.
Old Nov 26, 2005 | 03:48 PM
ohflguy's Avatar
Check the headgasket. Happened to a friend of mine in his 3rd gen with similar symptoms turned out to be a headgasket.
Old Nov 26, 2005 | 03:56 PM
joosdawg's Avatar
GOLDTOOTH- man screw a new engine when you and your dad can drive up here and pick up a fresh 5spd monster Its the perfect time to convince your rents you need a new car all you gotta do is click the link in my sig and come on up for a brand new whip
-Ryan
Old Nov 26, 2005 | 05:32 PM
goldtooth's Avatar
Iight, heres the deal. My dad told me that one of the injectors was leaking and when they attached something to the engine to manually crank it? there was gas spitting out of the cylinder(s)? after the sparkplugs were off. So he tells me there was fuel in the oil and that one of the injectors is bad. Then when he is at the mechanic already, he cant start the car at all anymore, starter died. He went and got a new one with my uncle for $105 and if we bring back the old one we get $30 back.
Old Nov 26, 2005 | 05:37 PM
joosdawg's Avatar
cmon goldy no love?
Old Nov 26, 2005 | 05:49 PM
goldtooth's Avatar
Originally Posted by joosdawg
cmon goldy no love?
I already talked to my dad, and Im poor as hell .... Sorry man, but I wish you the BEST OF LUCK in your sale hopefully quick as you need it.
Old Nov 27, 2005 | 05:25 PM
Garrick's Avatar
I think your Max needs to cut down to only one pack a day. Sounds like lung cancer. My Max had a problem like that but no smoke. I had an extreeeeeme power loss, it barely even started Ihad to floor it to turn it over, and power steering was ****, I reset the ECU and let my Max sleep it off for a day and it was fine a day later.
Old Nov 27, 2005 | 07:40 PM
DR-Max's Avatar
I'll throw one bone at you....
Yes it will fit but you have to worry about how you'd control your 00vi variable intake. Now hit the all-motor forum!
Old Nov 29, 2005 | 10:42 AM
JUS
Couldent Help U To Save My Life! Sorry.
Old Nov 29, 2005 | 12:23 PM
MaxKlinger's Avatar
The VQ30DE uses electronic multi-port fuel injection. Do not pump the throttle before starting a fuel injected car, it's not necessary and will do absolutely nothing to help you start the car.
Old Nov 29, 2005 | 04:05 PM
NmexMAX's Avatar
dot dot dot ...
Hmm, compression test
CEL's?
Old Nov 29, 2005 | 04:08 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Check your blinker fluid levels. That'll do it.
Old Nov 29, 2005 | 04:33 PM
PandaXpress's Avatar
metal dont start that again....
kcryan's Avatar
Sounds like his ECU's got a virus, you have been updating your norton right?
Old Nov 29, 2005 | 05:06 PM
nismos14's Avatar
§è~® f®ÈÄk
I'm leaning towards headlight fluid on this one. The smoke and all would be the tipoff
Old Nov 29, 2005 | 05:22 PM
Maybe he's running synthetic. Some of the GL-4 is baaaaad news.
Old Nov 29, 2005 | 05:54 PM
nismos14's Avatar
§è~® f®ÈÄk
I'd recommend GL-5 peepee in the headlight reservoir. Maybe some Dot 3 in the coolant, and some Super Tech (Wal-mart special) oil for the housing.
Old Nov 29, 2005 | 07:30 PM
2k3TitaniumSe's Avatar
VQ35 swap???
