Leak what could it Be? Trans????
Old Nov 25, 2005 | 10:24 AM
MAXDADDY98's Avatar
Maxima.Org Bishes
Today I moved my car out the garage and there was red Fluid on the ground I'm thinking it's Trans Fluid or Power Steering. Not to long ago I had a trans flush and 2yrs back I got the rear main seal changed so I'm not sure why i'm leaking trans fluid is there something else that can cause the leak?
And if there is and Links to were to locate the Trans Plug so I can make sure it's tight.
Old Nov 25, 2005 | 10:28 AM
RA030726's Avatar
I'm nutty for Nissans
ATF and PS fluids are practicly the same. check the PS lines where they meet the steering box (behind the tranny). the drain plug for the auto is in the lower pan, you cant miss it.
Old Nov 25, 2005 | 12:37 PM
MAXDADDY98's Avatar
Maxima.Org Bishes
Ok I jacked the Car up it looks like the inner Tire rod Boot lost it's sealand the Red oil was dripping out I'm not sure but I will Post a Diagram up to pin point it out. The Boot is Fine but the boot is separated from where it was connected
Old Nov 25, 2005 | 01:16 PM
MAXDADDY98's Avatar
Maxima.Org Bishes
If the Pic is too small please go to my cardomain to Look.LINK
So when I go to Pep Boys or whom ever what should I ask for a Seal for inner tie rod boot?
Old Nov 25, 2005 | 03:22 PM
DR-Max's Avatar
What do you mean about "boot is fine but the boot is separated"? If you meant that the inner end of the boot (closest to the rack and pinion) is undone exposing the rack and pinion gears, then all you have to do is get a heavy duty zip tie and close it back up. Put some high temp heavy duty grease (red color) in there before you close it.
Old Nov 25, 2005 | 04:03 PM
MAXDADDY98's Avatar
Maxima.Org Bishes
What i means is that the boot is not torn or anything its just not connected because the Clip that was holding it is gone
Old Nov 25, 2005 | 04:04 PM
MAXDADDY98's Avatar
Maxima.Org Bishes
Thanks your saying I have to put ATF and close it up
Old Nov 25, 2005 | 04:41 PM
DR-Max's Avatar
Nope......it doesn't use ATF. It uses heavy duty grease.
Old Nov 26, 2005 | 03:49 PM
MAXDADDY98's Avatar
Maxima.Org Bishes
The Diagram that I put up says ATF
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
