Radio shut off, headlight shut off, hesitation, then back to normal
Old Nov 27, 2005 | 10:12 AM
Shoooter_j's Avatar
It been a long time since I posted here - good to see the max community still up and strong
Well, back to the original problem in the topic title - WTF? These are the symptoms that my dad's experiencing on his '96 max. Alternator is 5 years old, battery is 3 years old.
The scenario happened as so - my dad is driving along when all of a sudden the radio shuts off, then the headlights shut off. He then tries to pass someone and experiences hesistation after going WOT. He comes back home, only to drive it again around the block and it seems all the issues went away. Currently, the car starts up perfectly, with everything functioning as it should.
Thanks in advance for any advice/pointers
Old Nov 27, 2005 | 11:30 AM
BlkMaxPower's Avatar
The same thing happene to me a few weeks ago. The battery was on it's way out. I replaced it and haven't had a problem since.
Old Nov 27, 2005 | 11:32 AM
santiagomax97
clean the terminals.makes sure your battery is made for that car.
Old Nov 27, 2005 | 12:22 PM
Maxima lover
It does sound like it is the battery terminals. You might have a corrosion problem. Also check the battery voltage. If you had a bad connection at the terminals, you battery might not be recharging correctly.
I had the same thing happen when I didn't tighten my negative battery cable very tight. It would shut off the lights, radio, etc. while I was driving and then come back on.
Old Nov 27, 2005 | 12:42 PM
Shoooter_j's Avatar
Thx for the tips guys, I'll have a look at the battery
JRod28
Dec 29, 2023 09:56 PM
vingodine
45
May 21, 2016 12:46 PM
egali045
Aug 16, 2015 01:19 PM
acw
Aug 7, 2015 04:20 PM
