Please Help! Please!
Old Nov 29, 2005 | 01:09 PM
JUS
I Changed The Spark Plugs On My 95 Maxima Se. I Used Bosch Platinum Spark Plugs (made In Germany). The Ones I Took Out Said Made In Japan, I Dont Know If That Makes A Difference. The Gaps Are The Way The Are Supposed To Be, Because I Measured Them So Thats Not The Problem. My Problem Is That Now My Car Seems Like It Is Misfiring, I Can Feel It When Im Driving And When I Have It In Park. It Was Not Doing This Before I Changfed The Spark Plugs, It Was Running Fine. It Seemed To Get Worse As The Day Went On, So Now I Jus Parked It, I Dont Want To Drive It Like That. Has This Happen To Anybody Before, Or Does Anybody Know What The Problem Could Be?
Thanks Alot In Advance!
Old Nov 29, 2005 | 01:11 PM
njmodi's Avatar
Do I get a tax break?
You need to take out those Bosch plugs and put in NGK platinums or NGK Vpower coppuer plugs.
By The Way, Why Do You Type Like This?
Old Nov 29, 2005 | 01:12 PM
DrTySOUFMaX23's Avatar
yea, u gotta get rid off it..BOSCH PLATINUM for the max is a big NO NO i think the reason why it's doin that is because your getting too much sparks but yea.. just get some NGK's and u be ight!!!
Old Nov 29, 2005 | 01:16 PM
nissandrvr's Avatar
i had the same problem with bosch....definitely go with ngk they're much much better.
Old Nov 29, 2005 | 01:25 PM
JUS
Will It Mess Up The Car If I Drive It To My House To Change The Plugs, Its About A 15-20 Min Drive On The High Way, Right Now I Have It Parked At My Girls Apartments?
Old Nov 29, 2005 | 01:27 PM
it's possible..
Old Nov 29, 2005 | 01:28 PM
njmodi's Avatar
Just drive home and swap the plugs... it's no big deal.
Old Nov 29, 2005 | 01:31 PM
Dubbya's Avatar
VK56 Inside
Make sure you plugged all your coil packs back in.
Old Nov 29, 2005 | 01:37 PM
JUS
Thanks To Everybody That Responded! Yall Have Made My Day!!!
Old Nov 29, 2005 | 01:43 PM
d00df00d's Avatar
Old enuf to pick his own gears
You don't get any more spark with a Bosch Platinum plug than you do with a good NGK or Denso plug. You still only get one spark, no matter how many tips there are; the spark just jumps to whichever tip is nearest, even by the most microscopic amount.
The only reason for multiple tips is that it makes it easier to manufacture a longer-lasting plug for less money that way. I'd give more details but somehow I don't think anyone really cares about the technicalities...
As I understand it, the problem with those Bosch plugs is that they can disrupt airflow in a combustion chamber that isn't designed to work with them.
on the NGK suggestion. Denso Iridiums work fine too, but they're expensive.
Old Nov 29, 2005 | 01:50 PM
ajcool2's Avatar
I've had my Bosch sparks plugs in for a about a year now and havent had any problems with them. Could it be something with the installation? Because if it is even if he does switch back and installs the NGK's the same way he would have the same problem.
Old Nov 29, 2005 | 02:05 PM
JUS
SO R U SAYING THAT EVEN IF I SWITCH TO THE NGK'S, I WOULD STILL HAVE THE SAME PROBLEM? WHAT DO U SUGGEST?
Old Nov 29, 2005 | 02:23 PM
njmodi's Avatar
JUST SWITCH TO THE NGKs and you'll be fine AND STOP SHOUTING. Make sure you seat the coils properly and make sure you hear each connector "click" for the coils - so you know that they are all plugged in properly.
Old Nov 29, 2005 | 02:24 PM
Dubbya's Avatar
VK56 Inside
I suggest you look at your coil packs and see if one is unplugged. I did the same thing when I changed mine last time.
Old Nov 29, 2005 | 03:54 PM
NmexMAX's Avatar
dot dot dot ...
That's the Difference Of Typing Like This, And LIKE THIS...
Quick reply > with shouting problems.
Old Nov 29, 2005 | 04:26 PM
phenryiv1's Avatar
Mod her. Ate her.
I banned him. He has re-registered more than once and was whoring to get to 15 posts to ask a question that is covered in the FAQs...
Old Nov 29, 2005 | 04:38 PM
the_3d_man's Avatar
god i wish people from texas would stop saying yall...
Old Nov 30, 2005 | 07:51 AM
Dubbya's Avatar
VK56 Inside
What do yall have against me saying yall? I dont understand why it annoys yall? Please help me out so I can get past this yall thing.
Old Nov 30, 2005 | 08:21 AM
sonicrunch's Avatar
how 'but Minnesotans who say yall
figure that one out
(you betcha)
Old Nov 30, 2005 | 09:50 AM
I30tMikeD's Avatar
Not using NGK's is not really going to cause a major misfire, as long as they are gapped correctly. I agree that NGK's are the best to use but if a person swaps out plugs and uses Bosch instead of NGK's and has a major misfire problem it is a most likely a coil pack that was not plugged back in. Some of you guys think not using NGK's will make your car blow up or something. I would guess half the 4th gen maxima's driving around in the US are not using NGK's.
Old Nov 30, 2005 | 10:20 AM
rdbaron9's Avatar
I don't like to tell people this but I used to drive a Geo Metro... yes it sucked and I am 6'-4" but i got it for free. I replaced my plugs with Bosch plugs once also and it ran for ****. Changed them out and it was night and day difference, I'll never use Bosch plugs in my vehicles.
