next performance mod
Old Nov 29, 2005 | 05:40 PM
VQ30de96's Avatar
I'm looking for another go fast part and i dont exactly have a large bank account. I already have a place racing cai, wsp ypipe and catback, custom enterpirse highflow cat. I thought about oovi, but i dont have 500 bucks to throw out, and another 500 for the chip..prolly not gunna happen. I was wondering if there was something else out there that can get me going a bit faster. thanx
Old Nov 29, 2005 | 05:41 PM
Fast1one's Avatar
Weight reduction=Free
Old Nov 29, 2005 | 05:42 PM
NmexMAX's Avatar
dot dot dot ...
I hate these types of threads.
If you don't have the money, don't ask.
Old Nov 29, 2005 | 05:53 PM
scrhale's Avatar
You don't need ECU to take the advantages of 00VI. Just do it without the ECU and you will still feel the power. Just not nearly as much.
The reason I kinda went against 00VI is because it becomes pointless if you ever go 3.5 since the ports do not match. But then again if you use PathFinder heads they will. No one has tried it yet to my knowledge.
Old Nov 29, 2005 | 05:56 PM
99grnmaxgxe's Avatar
Get a Tornado or an electric supercharger!
Old Nov 29, 2005 | 05:57 PM
NmexMAX's Avatar
dot dot dot ...
He does't have the money for either ... much less both...
Old Nov 29, 2005 | 06:06 PM
hdiggeddy's Avatar
Udp.........
Old Nov 29, 2005 | 06:40 PM
sonicrunch's Avatar
Originally Posted by hdiggeddy
Udp.........
NOT..........
Old Nov 29, 2005 | 06:42 PM
chillin014's Avatar
yeah its the mevi you need to "make up for loss" or so i've read.
apparently the 00VI is fine by itself. more than fine. OR SO I'VE READ.
and uh...i know what you mean. i think i'm about to drop 500 on either an ECU or manifold. probably ECU since it seems to be an easier install plus less hassle when i want to do a 3.5.....correct?
eager to whoop some more ***.
Old Nov 29, 2005 | 06:44 PM
lilaclucymaxima's Avatar
Team Ramrod
There is nothing else you can do.
Old Nov 29, 2005 | 06:45 PM
NmexMAX's Avatar
dot dot dot ...
If you want more power for cheap, get a simple N2O kit.
Old Nov 29, 2005 | 07:01 PM
TurTLe*'s Avatar
aren't most n2o kits about 350-500$ almost in his range of " i dont have money"
If you dont have money, i suggest you save up for some maintaince stuff before you go moding again.
Old Nov 29, 2005 | 07:03 PM
Nissan 6's Avatar
since you cant do many go mods for the price you can spend I suggest focusing on handling. Get a RSB and when time comes some sticky tires.
Old Nov 29, 2005 | 08:32 PM
Flava_24/7's Avatar
Boosted Panda
That would be the best solution for him with the amount of cash he has.
Old Nov 29, 2005 | 08:35 PM
Flava_24/7's Avatar
Boosted Panda
Not too sure on how well that ecu will work with the 3.5
Unless your manual, the 3.5 isnt a huge power adder. yes its faster then the auto 3.0, but a modded manual 3.0 will pull an auto 3.5 I speak from experience
Old Nov 29, 2005 | 08:48 PM
NmexMAX's Avatar
dot dot dot ...
That wont happen in a properly tuned auto 3.5L.. or my 3.5L Auto
Old Nov 29, 2005 | 09:55 PM
2 Da Max's Avatar
get a used n2o solenoid, get a bottle run the lines straigh after the MAF, gets some wires relays and you got a cheap n20 kit
Old Nov 29, 2005 | 10:03 PM
konak85's Avatar
Do some maintenance work, which will increase performance also, for little money. check/change: 02 sensors, knock sensor, spark plugs, fuel filter, PCV, Auto-RX?, synthetic oil?
Old Nov 29, 2005 | 10:31 PM
tcrow31's Avatar
you could also get a grounding kit that will help your car run a little better
Old Nov 29, 2005 | 10:49 PM
PandaXpress's Avatar
send a pm to the the home depot mod king int he 5th gen forums..he can probably think of something if hes not busy of course... irish44j
Old Nov 30, 2005 | 04:52 AM
Flava_24/7's Avatar
Boosted Panda
True, the 3.5 wasnt tuned.
With tunning it would be a better race, but my 5 speed with the 7k redline doesnt do to bad.
Old Nov 30, 2005 | 05:06 AM
Iron Scimitar's Avatar
Tha Snatcher
only go-fast mod on our cars is boost.
Old Nov 30, 2005 | 05:26 AM
chillin014's Avatar
Dude.....what? The 3.5 isn't a big power adder? I thought it was good for like a 40 horsepower difference. Either way, I don't have the money or know how for it right now.
Can anyone tell me what an upgraded ecu would do for my auto? I'm conncerned that ill buy one and won't feel the gain so much.
Old Nov 30, 2005 | 05:35 AM
2 Da Max's Avatar
youll feel it, its like another ypipe.... but if your autp youll definately feel the top end, and the car wont feel as sluggish
Old Nov 30, 2005 | 05:40 AM
NmexMAX's Avatar
dot dot dot ...
My 4AT 3.5L with 7k redline wouldn't either ...
Old Nov 30, 2005 | 06:34 AM
Flava_24/7's Avatar
Boosted Panda
I didnt mean it as if it wasnt worth it, if I had the cash Id definately do the swap.
I was just implying that if your auto dont expect insane HP gains with just the swap. The tunning is a must. The 3.5 is an awesome platform to work from, but its not a cheap mod by any means.
The cheapest big power adder is going to be the nitrous setup.
If you get the ECU, you wont regret it. You just need to make a choice if you plan on staying NA or not,.. that is if you dont mind the wait time to send it back in later down the road.
Old Nov 30, 2005 | 07:24 AM
buttonhook's Avatar
A new ECU???? you mean like a jet chip or what ever?
Old Nov 30, 2005 | 07:53 AM
Team Ramrod
No JET chip... JWT or TC.
buttonhook's Avatar
where do you get info on that??
Old Nov 30, 2005 | 08:01 AM
Team Ramrod
Information is everywhere. Here is an older thread about it. http://forums.maxima.org/showthread....hlight=jet+ecu
Old Nov 30, 2005 | 10:35 AM
chillin014's Avatar
i appreciate the info i thought the swap wasnt too bad. like 1500?
and waht do you mean by tuning?
im pretty sure i want to stay NA. im not really that interested in nitrous right now.
Old Nov 30, 2005 | 11:13 AM
devilz05's Avatar
Shift_3.0
If you are serious about performance, your first thing on the to do list is to open up a savings account. Put whatever money you have in there and start saving. During the meantime start researching supercharging and turbocharging. Instead of spending 500 dollars on some 20hp part, save that money. You know you will end up coming back after you get the new mod and ask us what to add next. It looks like you already have some of the beneifical parts already like a free flowing exhaust. Find a nice kit, used if you wish, get a reputable place to install and tune it, run 9psi or less and enjoy the NOTICEABLE power gains.
Truth of the matter, leaving your car stock or near stock is the smartest option in the end, trust me, lol.
Did people actually mention Nitrous? On a street setup? Im not even going to bother with this one. Cons FAR outweight the pros.
Old Nov 30, 2005 | 01:20 PM
chillin014's Avatar
I'm spending about 500 on my ecu, I think it'll be worth it...I want to stay n/a so that outrules your way of doing things.
And I can Not stay stock. Heh.
Superchargers/turbos are expansive!
Old Nov 30, 2005 | 01:22 PM
sonicrunch's Avatar
They're also expensive.
Old Nov 30, 2005 | 01:43 PM
ryant35's Avatar
Two word... Speed Holes.
Let me know, I've got a pick-axe.
Old Nov 30, 2005 | 01:44 PM
Flava_24/7's Avatar
Boosted Panda
The Homer Simpson Go Fast Mod!
Old Nov 30, 2005 | 01:57 PM
Nealoc187's Avatar
SLOW
Really? What sort of cons would those be?
Old Nov 30, 2005 | 02:21 PM
sonicrunch's Avatar
Yeah, I'd like to know too.
Maybe he means how it's sO mAd TytE tHaT It'LL BlOW your EnGiNe
Old Nov 30, 2005 | 02:24 PM
PTownMax's Avatar
I still miss the max
a big a$$ fine for starts
Old Nov 30, 2005 | 02:38 PM
scrhale's Avatar
Well I can imagine his "con" is engine abuse. Oh well. That is why you go F&F style and race for a wad of 1 dollar bills in the desert to pay for the new engine after 20 races.... JK!
