Replacing manual shifter boot/bezel
Old Dec 1, 2005 | 09:08 AM
SkiDaddy's Avatar
Hey guys, I need to replace the shifter boot as the black outer fabric is peeling away a bit at the top. While I'm at it I want to replace the plastic bezel around the shifter boot. Is there any place that carries these at a decent price?
Any tips to remove/replace the bezel? And do I just grab the shift **** & twist counterclockwise? Do I need to hold the shift shaft with a pipe wrench or something to prevent damage to the mechanism?
TIA!
Old Dec 1, 2005 | 09:13 AM
Akumachan's Avatar
I never narc'd on nobody.
I got my new bezel from the stealership, I think it was like $80 for the bezel and boot, so not THAT bad in my opinion. As for the ****, just crank it off, you wont damage the shifter.
Old Dec 1, 2005 | 09:50 AM
sickmax's Avatar
aaron lavigne FTG
as for taking the bezel out......there are to clips in eaither bottom corner just reach through where the shift boot is and pull in an upward direction and it should come right out
Old Dec 1, 2005 | 12:04 PM
SkiDaddy's Avatar
Okay, thanks guys.
If anyone knows where I can get them for less please LMK. Thanks.
Old Dec 1, 2005 | 12:09 PM
86maxima96's Avatar
I Broke OT
check for sale section. they are a hot item as they can easily get cracked by a hard shift on a poorly adjusted sts. if you're lucky, though. you can get one for decent $$
Old Dec 1, 2005 | 01:53 PM
BigLou93SE's Avatar
Pull on the rear of the bezel first, then after those break free, slide the bezel down and outward away from the front of the car. You will need to unplug the ciggy lighter to remove it completely, and as said before, the **** just turns counter-clockwise off.
Old Dec 1, 2005 | 01:57 PM
SkiDaddy's Avatar
Thanks, I appreciate the tip!
CorollaULEV
30
Aug 9, 2021 08:11 PM
vingodine
45
May 21, 2016 12:46 PM
Fakie J Farkerton
Oct 14, 2015 06:25 PM
robtroxel
Aug 21, 2015 05:41 PM
Trin1j23
Aug 12, 2015 08:31 PM
