Reverse Glow Gauges question pls help
Old Dec 8, 2005 | 11:08 PM
culejoe's Avatar
Ok so i want to get some reverse gauges like some of you have... and i have been trying to figure out whats involved in installing them.... when putting them on do u have to take the needles and stuff off? i mean what exactly do u have to do it install them? anyone have a write up? thanks
Culejoe
Old Dec 8, 2005 | 11:10 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
No you dont take off the needles, you slide them under them. Its one of the easiest things you can do but if you absolutely need a write up there is one in the how tos.
Old Dec 8, 2005 | 11:21 PM
culejoe's Avatar
yea i was looking at the write up and i dont understand... does the old black gauge face come off? or does the reverse ones go over the black gauges? i have a gxe if u didnt get that by now......
Old Dec 8, 2005 | 11:22 PM
dariod's Avatar
I did it on my Toyotas. I did not do it on my Maxima because the SE gauges are white from factory and they are nice . You don't have to take the needless off you just have to be carefull when sliding the indiglo gauge over. Then you put everything back together and take the black wire (ground) tampered it on one of the screws and take the red wire (positive) and rewire it into headlight relay switch and you are done enjoy the world of the indiglo colors.
Old Dec 8, 2005 | 11:23 PM
Vlasic's Avatar
No you leave the stock guages on and the new ones just slide over.
Old Dec 8, 2005 | 11:30 PM
culejoe's Avatar
huh intersting.. hope the black doesnt through off the color or anything to that extent....
Old Dec 8, 2005 | 11:58 PM
l3ftonm3's Avatar
it wont throw off the color because the indiglo is above the black gauges. Just make sure you have some 3M double sided tape incase they stick up on ya
Old Dec 9, 2005 | 12:18 AM
supadupa6's Avatar
gauges are so simple to install. However, just like any mod you do, make sure you take your time and to not break anything. Like everyone else said, you take your gauge cluster out, open it up (it usually has little clips for the plastic covering), and then you put the gauges over the stock ones and over the needles. Be very careful not to play around with those needles cuz they may break, and you'll be reading FULL when you're really empty, lol and vice versa.
now that your gauges are installed onto the cluster, all you have to do is the wiring. Run them through your firewall and remember that BLACK is negative and RED is positve.
RED WIRE hooks onto a source that is always on when your parking lights are on..IE. your turn signal. Find the turn signal wire (should be RED), and tear a little bit of the plastic off of it to reveal the copper wiring, then just wrap the RED from the gauges and electric tape that off.
BLACK WIRE can go onto any ground source. IE. onto metal or under a bolt and washer.
Once you do that..just turn ur parking lights on and presto...you've got urself som indiglos. Hope that helps.
Old Dec 9, 2005 | 12:26 AM
culejoe's Avatar
ok sweet thanks for the help one more question since i will be in there doing this.... anyway u can get non red/orange needles? like clear or something? because if i decide to not do that for a while i was going to though some blue lights for color and red and blue arnt very cool looking...
Old Dec 9, 2005 | 12:39 AM
supadupa6's Avatar
hmmm...
well in my car i can replace the bulbs for the needles with led's. not sure how it works on maximas. don't you have a dimmer control for your dash? you can try dimming it and it reduces the brightness of the needles as well.
Old Dec 9, 2005 | 03:56 PM
culejoe's Avatar
its not that..... i want to replace the white lights with blue and the needles are redish color so blue will throw off the color and i wanted to know how hard it is to replace.... or where can u get some?
Old Dec 11, 2005 | 06:19 PM
culejoe's Avatar
anyone know?
Old Dec 11, 2005 | 06:21 PM
Vlasic's Avatar
Are you saying you want to change your needle color? You need to take some sand paper or a nail file and sand off the red form the needle, then what ever color youw ant will show through there. Is that what you were asking?
Old Dec 11, 2005 | 07:54 PM
culejoe's Avatar
ya for the most part thanks... i didnt know it just had a little red on it.. i havnt really taken a close look at them......
Old Dec 11, 2005 | 08:54 PM
l3ftonm3's Avatar
yes you can sand the color down then just get some led 194 bulbs and put them in the back for whatever color you choose. Another tip when installing I used in addition to 3M double sided tape is to take some sandpaper and sand off some of the bottom of the nub that that the needle is connected to. This way the nub wont get stuck on the new overlayed gauges
Old Dec 12, 2005 | 06:49 AM
StygianMax's Avatar
I took some pics while I installed mine. I hope they help you out a bit.
See bottom for photos of indiglo install
Old Dec 12, 2005 | 07:00 AM
moogotzskillz2's Avatar
installing the reverse gauges are easy to install. just need to be patient.
kormax97
how did you connect your indiglos?... looks like yours have some plugs on the ends of each gauge... does that plug into something?
Old Dec 12, 2005 | 07:03 AM
StygianMax's Avatar
Are you referring to the plugs in this pic?
it should plug in to an adaptor.
Old Dec 12, 2005 | 07:05 AM
kormax97
on that picture... the plug that's sitting on the ground... top right corner
Old Dec 12, 2005 | 07:06 AM
StygianMax's Avatar
It's been a few years that I installed the indiglos. I think there's a transformer that I tucked behind the gauge cluster and the plus connect to it. Power is tapped off one of the hot leads. I "teed" off an existing power wire to feed the indiglos.
Old Dec 12, 2005 | 04:35 PM
culejoe's Avatar
i noticed on your gauges that the fuel one is facing the wrong way compared to mine... do they have reversed ones? i totaly forgot to look at that when i have been shoping around....
Old Dec 12, 2005 | 04:57 PM
StygianMax's Avatar
That plug is part of the tach connection. That plug came with the car.
Old Dec 12, 2005 | 04:59 PM
StygianMax's Avatar
I really don't know culejoe. What I'd suggest is that you check carefully with the vendor. I bought my gauges off someone from eBay. I've found that if you ask detailed questions, you should get detailed answers in return. Have you bought yours already?
Old Dec 12, 2005 | 07:33 PM
culejoe's Avatar
no not yet so im ok i just never thought that there were some cars with the fuel facing the other way.. never looked that close.
Old Dec 24, 2005 | 04:14 PM
Sloppy Snood's Avatar
SE Gauge Swap: Is This a Possibility or Even Advised?
I realize this thread is referring to Indiglo gauges but can I just swap my current '97 I30t gauge cluster for a Maxima SE gauge cluster of the same year? -Sloppy
Old Dec 24, 2005 | 09:55 PM
plate's Avatar
Just a heads up on the aftermarket gauge faces themselves. If you live somewhere where's extreme temperature changes from summer to winter then you could see bubbles form over time under the new guages. This is from the constant cooling and/or warming of your cabin.
Also some of the aftermaket kits have ballasts/transformers that can hum (high pitch squeal) when you turn them on. Sometimes this is due to a poor ground but most of the time it's because of cheap electronics.
Old Dec 25, 2005 | 06:34 AM
sharkulator's Avatar
Like everyone said, very easy mod.
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
lrb6805
Sep 17, 2015 04:49 PM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
