Gas coming out of the exhaust
Old Dec 11, 2005 | 05:45 PM
NyCzBuBBa's Avatar
I have a major problem with gas coming out the exhaust. Not just fumes but actual gas spraying out. Any suggestions. Major loss of power too
Old Dec 11, 2005 | 05:47 PM
NmexMAX's Avatar
dot dot dot ...
Misfire , and are you sure it's not water droplets?
devilz05's Avatar
Shift_3.0
You sure its gas and no water? That tends to happen when you buy ****ty gas, so the powerloss would be evident as well.
Old Dec 11, 2005 | 05:49 PM
86maxima96's Avatar
I Broke OT
i would put my money on it being condensation. or else, let it drip onto a metal surface, move the car away and try to light it.
Old Dec 11, 2005 | 05:52 PM
Charcoal95GXE's Avatar
HAHAHAHAH, pour some gas droplets on the ground let them sit, then go back and try to light them...they wont light..
Old Dec 11, 2005 | 05:53 PM
NmexMAX's Avatar
dot dot dot ...
Fuel getting that far back in the exhaust sytem unburned is almost unheard of, and very rare.
Old Dec 11, 2005 | 06:06 PM
NyCzBuBBa's Avatar
well we did light it and it did catch fire well we put a bucket behind the exhaust so it wouldnt go all over the floor and sure enough we poured onto the floor FAR away from the car and it caught fire. Can it be a result to having bad coil packs. Definitly cylinders aren't working.
Old Dec 11, 2005 | 06:11 PM
NmexMAX's Avatar
dot dot dot ...
Yes bad coils could cause that, and your sig is too big...
Old Dec 11, 2005 | 06:29 PM
NyCzBuBBa's Avatar
is that true I never heard of bad coils causing my car to shoot gas out the exhaust though? anyone had this experience?
Old Dec 11, 2005 | 06:43 PM
2 Da Max's Avatar
yo bro why the fawk u left your car out on HIllside last night?
Old Dec 11, 2005 | 06:50 PM
NmexMAX's Avatar
dot dot dot ...
Do you have any CEL's?
Old Dec 11, 2005 | 06:55 PM
NyCzBuBBa's Avatar
When it first happened no. But when we started the car after we took apart the dash to do the heater core then yes. I will find out tomorrow if it is still on the battery is now disconnected.
Old Dec 11, 2005 | 06:58 PM
tcrow31's Avatar
you shouldnt be gettin un burnt gas out the tail pipe. the cat is suppose to burn off the un burnt gas
Old Dec 11, 2005 | 07:02 PM
2 Da Max's Avatar
..runing lil rich huh
Old Dec 11, 2005 | 07:06 PM
NmexMAX's Avatar
dot dot dot ...
Or his coils are being and not burning any fuel.
Old Dec 11, 2005 | 07:08 PM
2 Da Max's Avatar
samething with my dads truck, it was sputtering and i check the code and it was a missfire, so yea coilpack or coilpack wired, or fouled plug
Old Dec 11, 2005 | 08:08 PM
2 Da Max's Avatar
Just came back from NYCBUBBAS's crib and checked the codes,
this is what i got
10 8 EVAP canister purge volume control valve
2 1 Ignition Signal Circuit
and
1 2Mass Air Flow Sensor
one of his injectors were making a funny staticking noise, and his plugs were rea wet at the tip
Old Dec 11, 2005 | 08:15 PM
NmexMAX's Avatar
dot dot dot ...
Plugs being wet = coils typically.
MAF is probably why a lot of this is happening too.
Old Dec 11, 2005 | 08:16 PM
2 Da Max's Avatar
what abou evap canister?
Old Dec 11, 2005 | 08:20 PM
2 Da Max's Avatar
its not that i dont believe you, its just that i dont know. How does coils have to do with wet plugs? wouldnt it be an injector problem? one of his injectors were making a staticky noise aswell even when the car was off. im not knocking you, i just want you to explain your answer
Old Dec 11, 2005 | 08:24 PM
NmexMAX's Avatar
dot dot dot ...
If the coil doens't fire, it sends unburned (wet) fuel into the cylinder, and onto the
plug ...
Explain your logic...-->how a dead injector could wet the plug if it's shooting blanks? The plug would be white, poitning to a lean (high heat due to no or lack of adequate amount of fuel) condition.
Old Dec 11, 2005 | 08:28 PM
2 Da Max's Avatar
so he just need a coilpack that is then?
Old Dec 11, 2005 | 08:29 PM
NyCzBuBBa's Avatar
what if the injector is staying open. When the battery is connected the injector is making static noises.
edit* keep in mind that the coil packs and spark plugs are not in right now i connected the battery so we can check the code. The injector keeps making a static noise with the key not in the ignition. we disconnected the injector to check the codes.
Old Dec 11, 2005 | 08:37 PM
NyCzBuBBa's Avatar
[QUOTE=NmexMAX]If the coil doens't fire, it sends unburned (wet) fuel into the cylinder, and onto the
plug ... QUOTE]
would this cause fuel to be dumped out the exhaust?
Old Dec 11, 2005 | 08:38 PM
2 Da Max's Avatar
The CPVCSV is easy to see and reach. It is located in the engine compartment, mounted to the top of the upper intake manifold. Notice the Vehicle Serial number stamped into the firewall. Put your finger on the third-from-last number. Move your finger three inches toward the radiator. That's the CPVCSV. It has one two-wire electrical connector and two vacuum hoses. It is directly above the ignition coil connector for cylinder #5 and has to be removed in order to replace the #5 coil or spark plug.
You may test the valve. This test procedure is performed with the engine off. Remove the electrical connector and both vacuum hoses. Fasten a length of clean rubber vacuum tubing to either nipple. Gently blow through the hose. The valve should be closed and it should be difficult or impossible to send air through the valve. Now use a pair of fused test leads to provide 12 volts to the electric terminals. The polarity doesn't matter. With the solenoid energized the valve should be open and it should be easy to send air through the valve.
http://www.jcn.net/mwest/evappage.htm
Old Dec 11, 2005 | 08:43 PM
NmexMAX's Avatar
dot dot dot ...
Since you have 2 A32's there, swap parts, and see what it needs.
But I forget, 2 Da's Maxima is pretty UNmaintained as well
Old Dec 11, 2005 | 08:44 PM
the_3d_man's Avatar
so... basically the injector is sticking open... or the coil pack is not firing... or both
if you have so much gas pouring out of the exhaust that it's dripping out of the back i would guess the injector is stuck open. Shouldn't you be getting an error code for the rear O2 sensor since the cat obviously can't handle all of the gas?
eh
my 2 cents...
Old Dec 11, 2005 | 08:46 PM
2 Da Max's Avatar
lol, bro my max is very healthy and is very up to par with maintenance...
speaking of maintenance...well has nothing to do with it, i just installed tranny number 3!!! lol
hhm i guess we shouldve swapped parts, wasnt thinking.. Im mad at you now Nmexmax my car is very well maintiained!
Old Dec 11, 2005 | 09:43 PM
NmexMAX's Avatar
dot dot dot ...
I thought you said it needed a MAF etc... Maybe it was someone else..
Oh well, swap MAF's and see what happens.
If that doesn't work, swap coils.
Old Dec 12, 2005 | 08:06 AM
2 Da Max's Avatar
you dont understand, if i swap coils that fawken motor will literally blow!!! especially with all that fuel in the exhaust system..
Besides the coil pack im thinking that the ignition is being left on and the fuel pump is staying on and flooding the engine...
As for the coilpacks, we switched the different posistions, but when we switch it, there is fuel in other spark plug sockets... so its not really helping..
Old Dec 12, 2005 | 10:51 AM
NmexMAX's Avatar
dot dot dot ...
So then yank the fuel pump fuse, run it until it dies ... and then try it.
Old Dec 12, 2005 | 10:54 AM
2 Da Max's Avatar
alright we'll try that, and i think hes getting new coilpacks neways.
im still mad you said my car is unmaintained
Old Dec 12, 2005 | 11:09 AM
NmexMAX's Avatar
dot dot dot ...
Also, fuel evaporates quite easily, so it shouldn't be too bad .. but still a potential hazard.
Old Dec 12, 2005 | 11:57 AM
NyCzBuBBa's Avatar
well my car has been sitting dry for a day with the coil packs and plugs out and ill pull the fuel pump fuse and start it. Lets see what happens. I hope the car don't blow up alot of people keep warning me not to start it
vingodine
45
May 21, 2016 12:46 PM
fastcarny
Oct 28, 2015 11:16 AM
maxinout93
Oct 27, 2015 01:29 PM
Jcof88
Aug 3, 2015 10:43 PM
