Wire for Kill Switch
Old Dec 12, 2005 | 01:34 PM
PhillyDonut's Avatar
Someone tried to jack my car a few nights back and now I am looking to install a kill switch. Anyone have a link to a how-to or can lead me to the proper wire to put a kill switch? I’ve looked through the FAQs and don’t see anything on kill switches (maybe I missed something?) and I can’t search.
Also, I need to change my power steering pump since it is leaking. I found there’s a link in the FAQs for this but it is broken. Anyone have another link?
Thanks in advance.
pd
Old Dec 12, 2005 | 01:48 PM
Batxel's Avatar
blah
there's a starter fuse that's 15 amps in fuse box thats on lower part of your dash board. The fuse panel cover will tell you which one it is. You could be real tricky and put a blown out fuse in its place.
Old Dec 12, 2005 | 01:54 PM
InsneDrmr's Avatar
That would take time though. Just think everytime you wanna do it you have change the fuse.
Old Dec 12, 2005 | 05:57 PM
this is a daily driver so taking fuse in and out is not a effective option.
still looking for the right wire to put a switch onto.
Old Dec 12, 2005 | 06:05 PM
speed racer's Avatar
If I'm correct I believe its the white wire with the black strip. When you take the cover off the steering wheel you will see I believe 4 wires connected to the ignition switch. Try the wire I mentioned and worse case scenerio just resplice it.
Old Dec 12, 2005 | 06:41 PM
Batxel's Avatar
blah
go to the stickies and get the wire colors if youre not down with fuse idea jeeeeez
or better yet get a 2 way alarm like me and sleep tight
Old Dec 12, 2005 | 07:01 PM
95stillenmax's Avatar
I believe some people wire up a fuel cut with one of the fuel pump wires but im not sure though
Old Dec 12, 2005 | 07:25 PM
MaximaSE96's Avatar
Maxima Owner
splice into ur ignition wires and hide a swtich somewhere the car that only u know of but still relatively easy to get too
Old Dec 12, 2005 | 07:34 PM
RA030726's Avatar
I'm nutty for Nissans
there are just too many ways to do this and posting them all makes no sence and if you post how you did yours then its not a secret and some one could potentially steal your car anyhow.
Old Dec 12, 2005 | 09:51 PM
ImmaSquashYou's Avatar
the only thing is, you can link ur ignition to a lot of things. It doesn't necessarily have to be one switch only. You can do it so that you will need to flip the switch that you put on, while having ur hazards on and turning on your runing lights, headlights, or high beams. need to turn the radio off, step on the brake, or even moving ur seat. Basically nething that can requires power should do the job.
think of it as a train. If you brake the tracks (cutting ignition wires), you need to reconnect the tracks to a different location in order for the train not to crash (complete the circuitry) and remember, the ignition is a lil better than the cutting off the fuel pump because what is you accidently hit the switch? Pain in the butt is if you have to valet it, the guy will never be able to start the car again unless you tell him how to.
This is when you need to create a switch that acts like a short circuit (having another set of tracks so the train can go directly to where it was before you broke the tracks apart) meaning directly connecting ur ignition wires together again without having to press all those buttons. But this switch should be placed somewhere that is very hard to get to and think of. I mean, you're gonna know when you're gonna get valet so it shouldn't be THAT big of a problem
Old Dec 13, 2005 | 12:04 AM
Maxima lover
I think one of the best kill switches I saw was one in the window switch. I think he used the starter. He had to pull the drivers window switch up while starting the car. It was nice because he didn't have to switch it every time he got out of the car and it wasn't easy to find like an aftermarket switch that was hidden hidden. Of course this would only work well with a automatic.
Old Dec 13, 2005 | 02:51 AM
Tyrexx's Avatar
That's pretty cool, A relay would let you do that just fine, and it would work for manual or auto.
Old Dec 13, 2005 | 11:42 AM
Maxima lover
Only problem is with a manual, it can be pop started without the starter. Our OEM alarms are setup with the starter. I have started my car several times while the alarm was going off by just pop starting it.
It would be possible to run it threw a latched relay though and make it on the "run" wire and not the "starter" wire. This would take a little more time to design though.
Old Dec 13, 2005 | 12:39 PM
tcrow31's Avatar
Thanks in advance.
pd
if your car is an auto then al you have to do is put a kill switch on the neutral safety switch wire. just extend the wire to where ever the kil switch is hidden and then back to the neutral safety switch. Or you can just buy an alarm with ignition kill
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
