96 GLE Auto ****s Hard From 1st to 2nd
Old Dec 12, 2005 | 05:12 PM
djdirtyrice's Avatar
my car shifts hard and i dont know what i should do anybody know what needs to be done to fix it?
Old Dec 12, 2005 | 05:56 PM
loverholic's Avatar
iAMIXAM!
how many miles u got on it?
Old Dec 12, 2005 | 06:08 PM
CRiME's Avatar
oem ftw!
I have a similar problem, 127k miles, but was told not to worry about it. I've noticed if I'm going easy on the gas, when my car shifts from 1 - 2, I feel a very minor thump / jerk. If I'm accelerating hard, and the car shifts at higher RPM's, the 1 - 2 shift is perfectly smooth. Changed my tranny fluid, cleaned the screen to no avail. I'm not really sure what could be causing it...
Old Dec 12, 2005 | 07:46 PM
147 thousand
Old Dec 12, 2005 | 07:47 PM
yes thats it, i havent been able to get a straight answer on the org yet.
Old Dec 12, 2005 | 08:09 PM
LudeAEM's Avatar
Sounds identical to my car. I have 209,000 on mine. I added a tranny cooler to just to be nice.
Old Dec 13, 2005 | 07:21 AM
loverholic's Avatar
iAMIXAM!
is it still giving that jerk? afetr u changed the fluid and cleaned the screen i mean.
Old Dec 13, 2005 | 07:28 AM
Jepht20's Avatar
Custom User Title...
my car suddenly started doing that and shifting pretty hard, not every shift, but many. then i got a code and my od light was blinking. i replaced my drop resistor with a low mileage one from a junkyard and it went back to shifting normal. (knock on wood)
Old Dec 13, 2005 | 10:12 AM
plate's Avatar
Took my car once to a tranny shop that specialized in imports (that i trust)once my 97 hit 300KM and they said it's normal. As long as your not getting
codes and the hard shifts don't happen on higher gears you're ok.
They went into a complicated explanation about shift solenoids and about 5 minutes in they completely lost me. :/
Old Dec 13, 2005 | 10:18 AM
BlackCat's Avatar
RIP '98 Maxima SE
Once you notice that the gears aren't engaging as they should that's the time you'll know that means $$$.
Old Dec 13, 2005 | 11:41 AM
MaximaSE96's Avatar
Maxima Owner
if its hard shifts and they were talking about shift solenoids.....transtarindustries.com
sells the solenoid pack for about 150 bux....ps BLACK CAT ir car looks so []D [] []\/[] []D
Old Dec 13, 2005 | 12:21 PM
jvienneau's Avatar
There are two likely causes of a hard 1-2 shift. First check the 12ohm resistor on the driver's shock tower. It has an aluminum heatsink on it and a connector with two pins. If that's not it and your CEL light isn't on, you'll need to check and see if the temp sensor is open.
Old Dec 13, 2005 | 12:46 PM
CRiME's Avatar
oem ftw!
Yep, I've still got the jerk after doing the change.
Old Dec 13, 2005 | 12:48 PM
CRiME's Avatar
oem ftw!
Even though this isn't my thread, thanks to everyone for posting up these repllies, it's much appreciated. I'll check out that resistor, thanks again.
Old Dec 13, 2005 | 03:30 PM
LudeAEM's Avatar
I tested my drop resistor and it read 13 ohms. Does it need to be replaced? Or is it enough in the 12 ohm range where i can leave it alone?
Old Dec 13, 2005 | 06:11 PM
loverholic's Avatar
iAMIXAM!
i just wanted to know because i thinki used to get that to and my tranny fluid is fine but someone told me to change it and change the filter inside the tranny to be safe, so seeing that u did it and there was no change i will forget about doing it....lol
Old Dec 13, 2005 | 06:13 PM
loverholic's Avatar
iAMIXAM!
by the way does anyone know about a filter at the bottom of the tranny, they said that i have to remove the bottomof the tranny and the filter is right there, is this true.....
Jime i think you are needed on this thread
Old Dec 13, 2005 | 08:03 PM
jvienneau's Avatar
There is no filter per se. There is a screen and it's designed to last the life of the trans. The best think to do is to flush it every 60K or so. If you can't do that, then at least change what you can get out of the drain plug every 30K. It's really pretty easy to flush if you just disconnect the pressure like (one with the bango fitting) and run it into an empty gallon jug (you'll need a few feet of 5/16 line for this). Start the car and let it fill the jug (takes a minute or two). Refill the trans and repeat until you have bright red fluid being pumped out.
As for the 13 ohms, that's fine. Does it still shift into OD? When the temp sensor fails it will shift hard 1-2 and won't shift into OD. See if your OD button still makes the RPMs jump.
Old Dec 13, 2005 | 08:07 PM
CRiME's Avatar
oem ftw!
Yeah, I was hoping it would go away too, lol, but I guess it wasn't a bad idea to change it anyway since my fluid was pretty dirty. From what I understand, the tranny filter is sometimes referred to as a screen, and you can usually get by by just cleaning it. I didn't change the fluid myself, but the guy who did it told me the filter was in good shape, just needed a little cleaning.
Old Dec 13, 2005 | 08:09 PM
CRiME's Avatar
oem ftw!
Good info, thx jvienneau
Old Dec 14, 2005 | 07:36 AM
highoctane79's Avatar
if it doesnt shift into OD u gotta change the temp sensor, right. Where is the temp sensor. I think my tranny is screwed cuz its not shifting into OD, but it could be this sensor?
Old Dec 14, 2005 | 05:23 PM
LudeAEM's Avatar
the car shifts into overdrive just fine. The only thing is hard shifts from 1-2. EXCEPT when the tranny is dead cold. It shifts normal until it warms up (which isn't long).
Old Dec 14, 2005 | 05:46 PM
zander's Avatar
weird, mine shifts hard till it warms up. And I noticed it shifts alot smoother with O/D off, is this a sign of more crap to come?
Old Dec 14, 2005 | 06:55 PM
mine shifts hard when its cold to so i guess ill check into that resistor thingy
Old Dec 14, 2005 | 07:04 PM
i havent found anywhere to get a drop resistor online, but i did find people talkin about a drop resistor mod that disconnects the drop resistor sayin it makes the shifts more tighter. so i dont know what to do.
Old Dec 14, 2005 | 07:24 PM
ok i found something it atleast shows me where it is and what it looks like but on the site they tell u how to rig it so u can turn it on and off either allowing the transmission to shif at full line pressure (whatever that means) or normally.
http://jime.homeip.net/DR%20Mod.html
Old Dec 15, 2005 | 12:51 AM
Jepht20's Avatar
i bought one from a junkyard from a low mileage i30 for $15. go to your local dealer if you want new, they're only about $35 there.
Old Dec 15, 2005 | 11:22 AM
CRiME's Avatar
oem ftw!
Cool, I was wondering where to get one myself. Does anyone have a general idea of what resistance reading would warrant a change of the resistor. ie, should I change it if I get 10ohms, 14ohms, or is that within an acceptable margin? Thanks
James92SE
142
Jan 2, 2024 09:23 AM
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
