Spray-Painting pros step in *PIC*
Old Dec 17, 2005 | 01:41 PM
mendon99's Avatar
tastey wheat
hey guys, im painting the girlie's dash silver, and im having a problem:
the center piece that houses the climate control is giving me trouble..I washed it, de-greased it, and wet sanded it, [dried] then painted... EVERY other piece is coming out great, but this one has what appears to be deep scratches or something, only visible when the paint is there. I've wetsanded the bad areas thoroughly a few times and i keep getting the same results... i don't see the marks until i paint... looks like this:
what should do?
Old Dec 17, 2005 | 02:00 PM
X-Vert's Avatar
Are you using primer? Does it show those "cracks" when the primer is applied?
Old Dec 17, 2005 | 02:15 PM
MrEous's Avatar
^ Jeff™
How 'heavy' of an application are you using? Hopefully you are letting each coat dry fully before applying another coat.
Just my .02
Old Dec 17, 2005 | 02:19 PM
mendon99's Avatar
tastey wheat
no, im not using primer, but like i said, the others look fantastic, without primer also... same steps different results on just this piece
putting on light coats, and waiting at least 10 minutes between each coat...whats recommended on the can...(so yes they're fully dry)
Old Dec 17, 2005 | 02:40 PM
X-Vert's Avatar
I suggest you wait longer than 10min, to get nice quality, scratch proof surface, I'd suggest you waiting a good 2-3hrs before applying another coat.
Put primer... let it dry for about 30min, put another coat of primer, wait another 20min, then apply your first coat of paint, let it dry for about 3hrs... apply 2 more coats w/ 2-3hrs in between and let it sit over night, then spray about 2 coats of of clear coat, let teh first coat dry for about 1hr
If you want perfection, you can sand between each coat of paint.
Old Dec 17, 2005 | 02:46 PM
2 Da Max's Avatar
yea get some primer.. or maybe spot puttey? its like 3 dollars for a small tube. apply a little and sand it down and your good to go
Old Dec 17, 2005 | 03:04 PM
MDeezy's Avatar
Sandable primer.
Old Dec 17, 2005 | 03:13 PM
mendon99's Avatar
tastey wheat
alllrighty, primer it is. ill pick some up tomarrow. thanks fellas
Old Dec 17, 2005 | 07:07 PM
Flava_24/7's Avatar
Boosted Panda
Id wait longer then 10 minutes.
Old Dec 17, 2005 | 09:13 PM
Black Maxima
Yea, sand that biyotch.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
