Should wheels spin in neutral?
Old Dec 18, 2005 | 01:06 PM
NCSU_MAX's Avatar
Maximoneypit
yea i know it sounds stupid but anyway, i had my car up on stands and when i started the car in neutral (5spd) the wheels began to spin and kept doing so for about 15-20 seconds. Why would this happen? thanks guys
Old Dec 18, 2005 | 04:34 PM
MaximaSE96's Avatar
Maxima Owner
because ur in Neutral....Neutral means that ur car not in a Foward or Reverse gear and able to spin freely
Old Dec 18, 2005 | 05:08 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
I think he means that they were spinning by themselves. i think thats norma.
Old Dec 18, 2005 | 05:17 PM
thisisausername's Avatar
probably because the tranny oil was cold. in synchromesh transmissions the gears are always engaged, they just spin freely on the shaft until they are locked unto it by a collar when you put it in gear. when the oil is cold there could be enough friction between the gears and the shaft itself to tranfser some power. Still kinda weird tho, woulda freaked me out.
Old Dec 18, 2005 | 05:40 PM
NCSU_MAX's Avatar
Maximoneypit
good info - thanks! yea it did freak me out a little. this may sound weird but i thought it maybe that something was not lined up correctly within the transmission causing unwanted gear selection and thus the spinning of the wheels. However not a full engagement of a certain gear bc this would obviously cause stalling.
Old Dec 18, 2005 | 05:45 PM
keb1209's Avatar
I notice strange behavior w/ my tranny when cold-starting too. Obviously I have to push in the clutch in order to start the car. But when I let up on it, if my parking break isn't set and my foot isn't on the break pedal, the car will actually roll forward a foot or so even if though in neutral. It's been doing it for years so I'm used to it, but I never actually knew WHY until just now.... thanks.
Old Dec 19, 2005 | 04:35 PM
rushinrio12's Avatar
VQ POWER
Actually I had mine up on jacks just the other day myself and I revved it in neutral and the wheels spun. The guy next to me told me that there is always a little power going to the tranny, just not enough to matter when there's weight on the wheels. Interesting...
Old Dec 19, 2005 | 05:50 PM
whitemax21's Avatar
I think, but I'm not sure, it has something to do with the weight being removed from the axles...or something like that.
Old Dec 19, 2005 | 06:56 PM
Haibert88's Avatar
I work in a mechanic shop and I can tell you that it's normal for the wheels to spin for a COUPLE of seconds...not to keep spining in neutral
Old Dec 19, 2005 | 07:05 PM
NCSU_MAX's Avatar
Maximoneypit
^^^^ ok good, thats what happened - thanks
Fbana41
Aug 29, 2016 12:18 PM
James92SE
Oct 8, 2015 04:57 PM
Andy29
Sep 29, 2015 05:32 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Lilfatz301
Sep 18, 2015 08:06 AM
