car dies on start
Old Dec 19, 2005 | 12:03 PM
bkmax98's Avatar
car dies on start
Today I started my car, the rpm just dips below 500 and dies.
I tried to started it 2 more times and the same thing happens.
So I decided to start the car and keep the rpm at 1000 with my foot on the gas pedal.
The rpm drops a bit but I kept it at 1000 rpm and the car stayed on fine.
what you guys think the problem is?
Old Dec 19, 2005 | 03:16 PM
dizheafta's Avatar
Idle Air Control Valve???? mine does that too
Old Dec 19, 2005 | 03:22 PM
MDeezy's Avatar
sounds like a vacuum problem.
After keeping the car at 1k for a while does it run fine without you having to press the gas?
Old Dec 19, 2005 | 03:25 PM
DrTySOUFMaX23's Avatar
mine does that too, and yes it runs fine after 1k.
Old Dec 19, 2005 | 03:29 PM
MDeezy's Avatar
if it runs fine without any drive assistance after its warmed up some it wont be a vacuum problem as that would be present wheather the car is warm or not.
I would try cleaning the IACV, and check the sensor on it to make sure they are functioning properly, plus I'd check the TPS and make sure that is functional as well.
Old Dec 19, 2005 | 06:06 PM
2DMax's Avatar
I started to have the same problem. I thought it was the PCV valve, so I replaced that, but the problem persists. I checked the codes, and I have a knock sensor problem. So I'm gonna replace that this weekend.
After that, I am at a loss.
Old Dec 19, 2005 | 06:09 PM
MDeezy's Avatar
KS will not affect your start up. It must be something else.
Old Dec 19, 2005 | 06:12 PM
97MaximaSE97's Avatar
MINE DOES THAT TOO!!!! I hate it its soooooo stupid it only does it if it has been sitting after 10hrs it starts fine then dips to 0 and shuts off after that I have to lightly put my foot on the gas and it starts fine. I'm may video tape it and go to the service center and see what they think.
Old Dec 19, 2005 | 06:14 PM
njmaxseltd's Avatar
Clean your throttle body and the IACV. If that doesn't fix it, then check the engine coolant temp sensor and make sure it's within specs. The Haynes shop manual has a resistance ~vs~ temp table. If that still doesn't fix it, check the cold fast idle circuit on the throttle body. If the plunger isn't working you'll have to replace the throttle body. The cold idle plunger is not a serviceable item.
Old Dec 19, 2005 | 06:21 PM
MDeezy's Avatar
Originally Posted by keb1209
I notice strange behavior w/ my tranny when cold-starting too. Obviously I have to push in the clutch in order to start the car. But when I let up on it, if my parking break isn't set and my foot isn't on the break pedal, the car will actually roll forward a foot or so even if though in neutral. It's been doing it for years so I'm used to it, but I never actually knew WHY until just now.... thanks.
Because your in neutral. You must be on some sort of a incline/decline.
Old Dec 19, 2005 | 06:42 PM
WielkiWaac's Avatar
MaximaDriver
i would say IACV
Chucks98's Avatar
I've had a similar problem on my Altima as well as a toyota. Replacing the coolant temp sensor worked in both cases.
Are you finding yourself getting crapping fuel milage?
Old Dec 19, 2005 | 07:54 PM
projectpete's Avatar
bring it to a mechanic and get the fuel system cleaned, not that **** you add to your gas.
Old Dec 19, 2005 | 08:11 PM
bkmax98's Avatar
thanks for the replies
I forgot to mention, it was a cold start. After starting the car later again tonight it started up fine without the rpm dipping to 0 and the car dying out.
But as chucks98 said I am kinda getting crappy gas mileage. I replaced the coolant temp sensor about 6 months ago. But my Temp gauge acts up once in a while sometimes it would jump to the hot zone for about a minute and go back to normal temp then drops to cold and stays there. If I work the engine above 2.5k while driving it would go back to normal for a little bit then continues this cycle. What you guys think is the problem?
Old Dec 19, 2005 | 08:20 PM
WhiteMax96's Avatar
That's right what you have to do!!
Old Dec 20, 2005 | 05:41 AM
deeloc's Avatar
have a similar problem since last winter with cold weather starting. replaced ects sensor no change, cleaned throttle body no change. next step i will try is iacv. if i have my climate control on auto it seems to start better cold.
Old Dec 20, 2005 | 12:19 PM
jelani's Avatar
I have this same problemwith my car as well, I took it to a shop and ran it through a diagnostic and come up with a Idle Air Control Valve code. does anyone know a price range for the part? Also is there a post about how to replace this part? I dont know alot about maximas but im learning.
thanks for the help.
Old Dec 20, 2005 | 12:25 PM
kaoskustoms's Avatar
alright my first post i am having this problem as well and i am a honda guy. and i bought a maxima, i love it . but i do not know much about nissans so trrow up some pics of the iacv please and maby some showing the cleaning prosses. thanks
Old Dec 20, 2005 | 08:36 PM
maximaxgtr's Avatar
i would actually clean the throttle body first and see if that helps. I had the same exact problem where the car will stall after starting it (only during cold weather below 40 degrees). I cleaned my throttle body this past weekend, and now when i start it, my idle starts at 1500rpm and then it slowly decreases during warmup. I no longer have that stalling problem anymore after doing this!
Old Dec 21, 2005 | 04:20 AM
kc10fish's Avatar
STOP-try the throtle position senser. i know it sounds wierd but hey i had the same problem, took it off, cleaned it and the connectors and BLAM no more problem..... in fact the rpm's jumped from 500 to 1000 up and down real quick and then would die. warmed up no problem right?
Old Dec 21, 2005 | 08:27 AM
so take it all apart and clean it? and where the fu#@ is the iacv at?
Old Dec 24, 2005 | 08:55 AM
2DMax's Avatar
I cleaned my throttle body (embarassingly dirty) and the IACV (took that mother apart) and cleaned that too.
It started right up no problems !!! Now I don't know if that half can of carb cleaner had anything to do with it, or that it's near 50 degrees outside. We will just have to wait for a 20 degree New England morning and see !
Old Dec 25, 2005 | 09:22 PM
triumphD6's Avatar
Ditto. Mine had the problem for 2 years. Mechanics couldn't fix it because the car never did it at the garage, only in my driveway in the morning. I first replaced the coolant temp sensor, hoping that was it, but it wasn't. I cleaned the TB and IACV last week, and problem solved. The valve had about an 1/8th inch of build-up on every surface in it, and the hole where it opens into the intake manifold was about 1/4 obstructed with build-up from inside the manifold.
Now I can finally get a remote starter!!!!!!!
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
