Who has the most reliable 4th Gen Maxima ?
Well my 97 SE just turned 150K today, and I'm really glad that she is holding up pretty good for her age, and healthy dose of abuse she gets on daily basis.
I know that there are owners who constantly have problems with their cars,
and there are more fortunate ones who enjoy years and thousands of trouble free miles.
if you are the lucky one and fall in the second category , please share your experience.
lets follow this simple pattern:
1. Number of years owned
2. Total miles driven
3. Original engine/tranny
4. Number of times the car got you stranded,ie: no start etc
5. Part/component that failed
feel free to add additional info.
1.4
2.70K
3.both original
4.1
5.Starter
Lets see who has enjoyed most trouble free miles !!!
and Happy Holidays BTW
Nick.
1.4
2.70K
3.both original
4.1
5.Starter
Nick.
1. 3 months
2. 1500 miles
3. all original
4. none, other owner never did he drove it 188K, was lease car before him
5. alternator before I owned and waterpump leaking now
1. about 4 months.
2. >6k miles.
3. all original baby!
4. 3
5. first time the clutch went out (well the pressure plate, but it didn't leave me stranded, 'cuz I'm 1337 and I DON'T NEED NO STINKIN' CLUTCH), then the alarm screwed up which was the dealer's fault, then the starter fried--it wasn't OEM. Then the alarm screwed up again, stupid dealer.
I think if the PO hadn't screwed around with the car and installed the funky alarm and aftermarket starter, I would be totally trouble-free/strand-free (well besides the clutch).
I have 157k btw.
2. >6k miles.
4. 3
I have 157k btw.
1. 2 Years
2. 40K
3. Original engine/2nd tranny.
4. Once
5. F**kin Starter
Tranny going out the door again, Other than that just had to change thermo, ECTS, and Driver side Axle.
Happy Holidays!
2. 40K
4. Once
5. F**kin Starter
Happy Holidays!
well, i can sure as hell go for the most un-reliable. total miles. around 200k
owned for about 7 months
driven about 17k
stock engine and tranny
broke an axle, 3 clutches, slave cylinder going bad, stranded me at school(dead battery), intake fell off once when i closed my hood. i love the car to death but next time it breaks im going to sell it. it is a shame to sell it tho. its an awesome car
driven about 17k
Originally Posted by 2 Da Max
80k miles with 3 trannies, o2 sensors, knock sensor, starter, cva, bla bla bla
maximas are garbage
maximas are garbage
this is coming from someone who has posted a few times about doing all sorts of crap to his car...just because you seem to have bad luck, self inflicted or not, doesn't mean every other maxima is garbage...
1. Number of years owned - 6 baught it new
2. Total miles driven - about 110,000
3. Original engine/tranny - yes
4. Number of times the car got you stranded,ie: no start etc - 0
5. Part/component that failed - replaced the coil packs & an o2 sensor
1. 8 months
2. 12k
3. all original
4. 1
5. 6 alignments, flexpipe, starter,front struts, coil springs, ball joints, axles, front brakes, wheel bearings, tires, coolant temp sensor, mass air flow sensor,
and it is still not running right.
It still needs, knock sensor, rear struts, probably a new front end, intake air temp sensor, and maybe more.
I bought this from a maxima.org member and got ******
Anyone have a intake air temp sensor for 95-96 max?
2. 12k
3. all original
4. 1
97 SE 4 years
99.5 SE-L 7mos
46-156k
86k-116k
On 97 trans was replaced 2 times. 1st one because of mis-shift into 3rd. 2nd bad diffy bearings
99.5 everything is stock.
never for either
97: None.. Worn out ALT, clutch, Axles, 1 wheel bearing
99.5: Wheel bearing
97 SE 4 years
99.5 SE-L 7mos
46-156k
86k-116k
never for either
99.5: Wheel bearing
I guess it would be me
4. New trans, New clutch, New flywheel, 2x New passenger-side axle, 1x wing light, 4 new tires, new rotors/brake pads, New engine mounts, New knock sensor, new fuel filter, new tensioner pully, new belts, new cat, new exhaust gaskets, new exterior light bulbs, new under radiator bar, new alternator , soon to be new starter, all new 02 sensors, Alignment done, coolant flush done, a billion oil changes, carbon clean done, lube the hings because they make noises, still need to replace my front wheel bearings, still need to replace my starter. yeah My maxima is pretty much solid don't you think
after all these repairs Im sure I wouldnt see another problem for a lonnnnggggg timmeee...
1. 6
2. 140k
3. Original engine/tranny (once those go, the car goes, period. i'm not dealing with that kind of work)
4. twice, maybe thrice
5. alternator, battery, KS, something along those lines
2. 140k
has 147,000 miles
1. 1yr 3 months
2. 8,000 miles
3. orig tranny/motor
4. once(overheating from loss of coolant from water pump)
5. water pump seal and battery
i don't know how you guys go through multiple trannys like that
1. 1yr 3 months
2. 8,000 miles
UPDATE:
This thread must have jinxed me. I just went to get a few things done. Stopped in town to get gas, started the car and it seemed to be running on only 5 cylinders. I drove to the shopping center next to the gas station, still running on what seemed like only 5 cylinders, shut the car off and went inside to get a card. I came out, got in the car, crank crank crank crank crank.............. NO START!!!!!
Walked home, got my neighbor and my boy and we pushed the thing 2 blocks home. I just pulled 3 codes.
1008 Evap purge volume control valve - maybe because I just got gas?
0802 Crank position POS - thats why It's not starting
0304 Hopefully just a ghost code, it's been running excellent up to now.
Merry Christmas to me.
New member says "WTF??!!"
I just bought my third Maxima yesterday, a 1998 SE from the o/o with 88k, just signed up to this forum and then see this thread --- YEOW!!
My first car was a '91 GXE I bought new and put 250k on it and it was a sweetheart, the second was a '93 SE I got six years ago with 92k and now has 220k. Had it not been for some idiot mechanics who f*cked a few things up it would have been trouble-free. But I'm not liking what I'm reading here ...
What's the deal with these 4th gen's anyway and should I turn it around while there's still time??
Gary in Fallbrook, CA
(It's only 80 degrees today)
1) 11 years 3 months, bought new
2) just turned 62K
3) original engine/tranny/spark plugs
4) never stranded - replaced a battery, 02 sensor on warranty, blew sidewall out of right rear tire
The car is still like new!
2) just turned 62K
1. Number of years owned - 2 years
2. Total miles driven - ~30K miles, at a total of 126K miles
3. Original engine/tranny - original engine, 3rd trans since I've had the car, 2nd clutch
4. Number of times the car got you stranded,ie: no start etc - 1
5. Part/component that failed - damn fusible link
i shouldn't post cause I know I'll jinx myself
1. 1year (5 years my bro (original owner).
2. 81k
4. Never had any major problems. Just routine maintnence.
5. Need to replace brakes (already have pads from GB) and tires.
2. 81k
My 96, which I sold in Aug for my 97 because its manual.
1. 6
2. 146k total/84k by me
3. Original
4. 3 times, 1st starter, 2nd alternator, 3rd my stupid azz deciding to chance driving home in heavy rain with the CAI on and sucking up some water, thankfully didnt do damage and was fine afterwards.
5. Starter, alternator, 02 sensor's.
1. 6
3. Original
1. Almost 3
2. 66,000
3. Yes
4. 0
5. nope
Currently has 157k on it. I'd say that another thing that needs to be added to the list is cost of maintanence/fixes/preventative maintanence
in which case in the past two years I've spent nearly 3 grand.
2. 66,000
3. Yes
4. 0
5. nope
1) 7, 5 by brother, 2 by me
2) 105K when given back to me in '04, currently 135+K
3) both original
4) 0
5) Replaced Alternator from recall, o2 sensor, KS
1. 8.5 years
2. 118Kms
3. all original
4. 0
5. nothing, possibly a RF wheel bearing going
Started every day in either Ottawa or London Ontario winters. This is one of the reasons i'm going to have a hard time getting rid of this car. I've become used to reliability and anything less reliable would anger me.
LEMAR
2. 118Kms
3. all original
4. 0
LEMAR
owned 0.5 years
8k driven
original automagic tranny and motor
one time got stranded because my startered got sticky and won't turn...called AAA tow truck and and that dumb driver cut his own hydro line.
starter, swird control valve (check engine light), clifford remote starter
my battery is about to fail and so are my front lights...so this weekend I got an Optima redtop and some new lights...fun times
8k driven
1) 7 years
2) 89K
3) Original engine/tranny
4) NONE
5) 3 O2 sensors, 3 ignition coils, alternator, knock sensor, moonroof, suspension components due to bad roads
So far, it has been very reliable. Regular maintenance sure does help keep it running smoothly.
2) 89K
4) NONE
