Weird vibrating noise coming from rear right passenger wheel/rotor area
Old Dec 28, 2005 | 09:42 PM
maximaxgtr's Avatar
Hi all.
I was wondering if anyone had an issue like this before and whether you could determine what the problem is. I may eventually just bring it to a shop and see what they will say. The weirdest part is that it started happening right after I had a shop to mount and balance some snow tires onto my car. I don't think I'll ever go back there even though it may not be their fault.
Anyway, here's what happens.
I start the car when its cold and drive around with no noise (at least 5-10 mins on the road). Eventually, over a period of time, I will hear a metal vibrating noise from my rear right passenger wheel/rotor area. This vibrating noise happens without braking, but it does get a little worse once I brake every now and then.
The weird part of it is that when the car is steering to the left, the noise goes away. When I steer right, this grinding noise becomes extremely obnoxious!
Also, sometimes when I pull up my e-brake and pull the e-brake down (while the car is stopped), the noise will go away for a little awhile.
So I have no idea whether this could be bad wheel bearing? a bad brake caliper that isn't releasing correctly? a warped rotor? a defective e-brake cable? overtorqued lug nuts?
I am pretty sure my brake pads are perfectly fine and should have plenty of life left.
Any suggestions on what this could be? Thanks guys.
Old Dec 29, 2005 | 05:29 AM
maximaxgtr's Avatar
anybody have any expertise in the brakes/rotors department?
Old Dec 29, 2005 | 05:31 AM
nismomax98's Avatar
My guess is ur rotor is warpped or ur rear hub is going bad ???????
Hondarydr
Dec 30, 2024 06:15 PM
carguy96
20
Feb 6, 2021 06:21 AM
george__
Aug 18, 2015 07:06 PM
egali045
Aug 16, 2015 01:19 PM
follyburr
Aug 7, 2015 09:50 PM
