problem with my cornering lights
just noticed tonight that my 99 se's cornering lights (the 1157 bulb in the parking light housing that illuminates brighter with the headlights on when you have the respective turn signal on) dont work. I took both housing apart checked the bulbs with my fluke and both were good. Then took my fluke and checked the voltage in the socket with the headlights on and the turn signals going....one side has 13 volts (obvious) but the other is dead. Am i missing something i went threw the fuses all seemed ok. i saw the relay box on the passenger side and one marked corner lights but there was no relay not even a plug for a relay. im not sure even if the cover was on the right way cause it fits both ways......any help or ideas would be great....
yea i thought i had the same issue when i went to my 98 from a 96...chabged bulbs and everything...then i checked the relay box to see of the really was bad....and there isnt one....its marked on the cover but no relay or anykind of wiring for it
yea i saw that man whys that ? the bulb socket is for an 1157 and theres an 1157 bulb in there. where the heck does the wire go ? can i get a relay to make it work ? thats depressing
then why the heck is there an 1157 bulb and socket instead of an 1156 bulb and socket.....man stuff like this irritates the heck outta me. im gonna wire that suker up. ill make a trip to nissan tommorrow and get the relays.
tsi6001
Oct 3, 2022 10:23 PM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
