98 Trany Problems
Old Dec 30, 2005 | 02:11 AM
iceman82's Avatar
98 Trany Problems
Alright need a liitle help. My trany is messed up. When I put it in drive and start driving everything sounds fine until the trany needs to shift to 2nd (it doesnt) revs up to about 4 or 5000 RPMs then shifts (sometimes I have to let off the gas so it will shift) then it doesnt shift again. Ran it up to 80 MPH but still nothing. Running 65 MPH at 4 or 5000 RPMs, at 80 getting to close to 6500 RPMs. Is it my tranny? My knock sensor is also bad this wont cause it though.........right?
Old Dec 30, 2005 | 04:14 AM
njmaxseltd's Avatar
Your tranny is toast.
Old Dec 30, 2005 | 10:08 AM
HarrisH's Avatar
It's probably your solenoids or valve body.
Old Dec 30, 2005 | 10:27 AM
tavarish's Avatar
fwd gone rwd cr00
Your tranny is missing gears. There is no reason for you to be at 5k at 80mph.
Check your ECU, yu most likely have a CEL.
-Freddy
Old Dec 30, 2005 | 10:31 AM
iceman82's Avatar
-Freddy
Whats a CEL, and how do i check
Old Dec 30, 2005 | 12:23 PM
jvienneau's Avatar
What year and miles? CEL=check engine light. Sounds like it might be new trans time.
Old Dec 30, 2005 | 02:58 PM
iceman82's Avatar
98 with 80655
and is there a way to reset my ecu?
Old Dec 30, 2005 | 03:04 PM
NmexMAX's Avatar
dot dot dot ...
Check the top of the forum for ECU related ?'s ...
Mine's doing the same thing
Old Dec 30, 2005 | 07:28 PM
jvienneau's Avatar
Is your speedometer working? 80K isn't a lot for a Max. I assume you've changed the fluid at least once by now. You made sure it's full, right? Is your check engine light on?
Old Dec 31, 2005 | 12:44 AM
iceman82's Avatar
yes spedodometer is working, i have changed the fluid when ever this started about a year ago but i dont drive it much now because of this, and yes cel is on
Old Dec 31, 2005 | 01:00 AM
siballiance's Avatar
have you changed trany oil latley? after 100k is not recommended.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
