Best test pipe
Best test pipe
From trial and error, what brand of test pipe have you gone with and had least problems. They should all be basically the same thing, but I don't want any fitment issues. X-Tune sells a cheap pipe on ebay for around $40. Suggestions, comments...
Test pipes give a raspy sound. Id go with a high flow cat but check here
http://maxmods.dyndns.org/index.php?...yticConverters
Damn, conflicting information. The two other boards I read showed gains in the 2-5hp range for test pipe over high flow. Honestly, for what I'm running (basically stock), I might as well not waste the money on either one at this point. Going with the budget Y-pipe first.
Originally Posted by NmexMAX
I'd get test pipe only to have it bunged and slap a wb in there, then strap the car on a dyno, other than that, useless.
I'd get a y before a t for more hp
Leave the stock piece in there unless it's dead.
Go to www.customenterprise.com They have a resinator that will give you a nice low tone.
Originally Posted by Jeff92se
If you are looking for hp, a test pipe is absolutely the wrong place to look. A Y pipe is absolutely the RIGHT place to look. All intake/exhaust mods after that feature less hp gains if any.
The gains from a test pipe do not justify running one. It's not even worth the time it takes to put on.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
