High Pitched Whistle?? help!
Old Jan 10, 2006 | 09:08 PM
sean05's Avatar
hey guys. well i noticed this high pitched whistle/whine the other night coming home. its a 5 speed. when it happens it stays in tune with the engine and its only noticeable at like 3,500rpms and up. or if you let it wind down from like 4k. It sounds like when you have the air on and there is that whistle coming from the motor. the car has been running fine.
since its in tune with the engine speed i thought tranny. but the tranny was recently rebuilt like last year and also had a spec stage 1 clutch installed.
can anyone shed some light on this or point me in the right direction?
thanks
Sean
Old Jan 10, 2006 | 09:17 PM
86maxima96's Avatar
I Broke OT
do you have an intake? i noticed something similar to what you were talkin about when i installed mine, and it is normal with an intake.
Old Jan 10, 2006 | 09:19 PM
Neif's Avatar
I have a whistle / hissing noise coming from my recently installed Y-pipe. I've heard it goes away after a while, but if you just had yours installed, could be that..
Old Jan 10, 2006 | 09:22 PM
s0ber's Avatar
My intake has a high pitched turbo like whistle from 3K on.
Old Jan 10, 2006 | 09:31 PM
Poowill's Avatar
Could be a dumb suggestion, but its not alternator whine is it? I thought i'd at least rule it out.
Old Jan 10, 2006 | 09:36 PM
sean05's Avatar
lol my friends just said something about that and that coukd possibly be it. would that be in tune with the engine speed?
Ive had an intake and ypipe for a while and never heard this noise.. good guess though...
Old Jan 10, 2006 | 11:14 PM
Poowill's Avatar
Well, the higher the RPM's get, the higher pitch the noise gets. Its quite annoying actually. I need to do a grounding kit.
Old Jan 11, 2006 | 05:59 AM
sean05's Avatar
hummm so it defiently could be the altenator?
Old Jan 11, 2006 | 06:39 AM
Poowill's Avatar
Check by turning off all accessories. Like turn off your stereo and see if it still happens. See if it gets louder if your lights are on too. That way you know if the problem has to do with some sort of draw from your battery.
Old Jan 11, 2006 | 06:46 AM
MDeezy's Avatar
It could be an alternator whine. Do you have the stock head unit?
When I put in an aftermarket head unit (rather cheap) I later developed an alternator whine, It was in sink with the rpms. I'd push the clutch in and the noise would go away, come back as rpms rise.
Old Jan 11, 2006 | 11:13 AM
sean05's Avatar
nope the headunit is not stock. the whine does go away when the clutch is in.
thanks ill defiently try that out.
Old Jan 11, 2006 | 11:44 AM
MDeezy's Avatar
you'll need a suppressor to get rid of the whine. I cant explain better than, as I dont know too much about it.I was told that from an audio shop about mine, I ended up selling the head unit and screen, and went back to stock.
I know if your alternator is acting up/dying/starting to die/ any type of change to it could cause the whine. I wouldnt get worried thinking your alternator is going to die, but try cleaning the battery terminals, terminals on the alty and see if that helps.
Old Jan 11, 2006 | 01:26 PM
BlackKnight's Avatar
I have a similar whine on my I30, except that I know it is not electrical, but maybe is coming from the Alternator or Belt tensioner pulley. I thought it was the tranny as well, but it will do it when in Park as well if I slowly pull the accelerator open. It really sounds like a bad bearing in either pulley. This might be the same situation for you. I really need to get an automotive s***hoscope to verify, but its something to look at. Good luck.
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
maxinout93
Oct 31, 2015 02:04 AM
