Quick help please!
Old Jan 14, 2006 | 02:18 PM
rich96max's Avatar
Quick help please!
Just removed the MAF sensor housing and sprayed tb cleaner through while running. Got a MAF code after putting everything back together. I'm guessing that this is because we removed the MAF and then put it back. I removed code and now it is not coming back on.
Also, put new rotors on my front wheels. When putting the pads back on, on the left front wheel I couldnt remember if the clip on the one pad went on the inside or the outside . The right wheel had it on the inside so I put it on the inside the same. No problems since ( just recently) and not sure if it even matters, just checking. Thanks for any help.
Old Jan 14, 2006 | 02:41 PM
NmexMAX's Avatar
dot dot dot ...
Spraying the MAF w/carb cleaner may not have been too smart, but if any problems arise you can always get a cheap one from www.car-part.com
Old Jan 14, 2006 | 02:46 PM
njmaxseltd's Avatar
I spray my MAF clean with TB cleaner every time I clean my TB.
(every 6 months or so)
Clip or ware indicator is supposed to go on the caliper piston side. (inside)
You done well!
Old Jan 14, 2006 | 05:56 PM
rich96max's Avatar
That's good. Brakes working fine. Now the code being thrown is 0505 (no problem) after resetting the ECM. kick ***.
Mar 12, 2020 12:06 AM
NewMax03
Oct 7, 2015 08:27 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
