Help need fast reply 96 vlsd tranny will fit in to 99 nonlockin?
Old Jan 16, 2006 | 11:09 AM
Mymax97's Avatar
Hi
I am about to order the part and the guy told me that the 96 might not fit into the 99 so i am just making sure that it will fit. I will need a new driver side axle. I want to have this part ordered today so it will be at tilleys shop by sunday. Thanks for thoes that can reply.
Old Jan 16, 2006 | 11:14 AM
s0ber's Avatar
It will fit fine. Just as you said, driver side axle.
Old Jan 16, 2006 | 11:30 AM
Mymax97's Avatar
Hi
ok thanks alot for the fast reply. And it wouldnt matter what year (4th gen) the axle is from as long as its the driver side from the locking with abs.
Old Jan 16, 2006 | 11:52 AM
MDeezy's Avatar
doesnt matter what year axle, just as long its with out without abs
Old Jan 16, 2006 | 11:55 AM
Zack342's Avatar
i have a 1996 I30 drivers axle and VLSD Tranny in my car, Fits like a glove
Old Jan 16, 2006 | 01:14 PM
Nealoc187's Avatar
SLOW
If your car has ABS then you HAVE to have an ABS axle, but if your car DOESN'T HAVE ABS then you can use either an ABS or NON ABS axle.
Old Jan 16, 2006 | 01:39 PM
tavarish's Avatar
fwd gone rwd cr00
Actually, you can have it either way, as I'm using non-ABS axles, but my car has ABS....i just can't use it...oh well...All you really have to do is take the abs rings off an abs axle, and put it on your non-abs axles...and bam...abs axle!
Old Jan 16, 2006 | 05:13 PM
Nealoc187's Avatar
SLOW
Don't confuse the issue. You know as evidenced by your post that you have to have an ABS ring on the axle if you want your ABS to work. Your post will do nothing but serve to confuse people.
Old Jan 16, 2006 | 06:20 PM
Mymax97's Avatar
Hi
Thanks for the information. I ordered the tranny and now i just have to get the abs axle. Then after sunday the car will have VLSD thanks to tilley.
Old Jan 16, 2006 | 09:25 PM
grey99max's Avatar
LandShark has Cosworth
I've got a '99 Infiniti VLSD in my '99 max - worked wonders on the strip this past season. That is one tough transmission...
Now if you installed a high-stall Edge torque converter at the same time as the VLSD, your launch would be awesome! Imagine launching at 3000!
I got mine working 3 weeks ago, and there is a world of difference. Good luck.
Old Jan 17, 2006 | 08:53 AM
Nealoc187's Avatar
SLOW
Is your car 5spd or auto... I assumed you were 5spd but then gray99's post made me think he might know something I don't because his torque converter suggestion obviously only applies to automatics. If your car is auto then I don't know if the info I gave is true. I believe it is true, but I haven't done any work on an auto myself so I can't say from firsthand experience.
Old Jan 17, 2006 | 11:03 AM
grey99max's Avatar
Actually, I might be totally wrong - no mention was made of an automatic or manual. Possibly wishful thinking on my part - wanting to see a supercharged automatic Max w/Edge high-stall converter = dreaming.
Sorry if I read too much into the original post.
Old Jan 17, 2006 | 11:46 AM
Mymax97's Avatar
Hi
Yea you read alittle too much into it. This car has been and always will be a manual.
Old Jan 19, 2006 | 10:36 AM
Mymax97's Avatar
Hi
just an update for thoes that commented, the tranny that i was supposed to be getting turned out to be a non-locker so im ending up with what i started with just one that works now.
James92SE
142
Jan 2, 2024 09:23 AM
spencerwh1
Jun 30, 2016 05:44 AM
jchronis2552
Sep 23, 2015 04:57 PM
catalinvint
Sep 16, 2015 07:48 PM
pktaske
Sep 4, 2015 08:40 AM
