alignment needed after new wheel bearings?
Old Jan 17, 2006 | 02:28 PM
racin89lx's Avatar
the title sums up the question i have, so a simple yes or no should be good for this one. thanks
Old Jan 17, 2006 | 02:36 PM
MDeezy's Avatar
Yes.
10letters
Old Jan 17, 2006 | 03:24 PM
Dubbya's Avatar
VK56 Inside
I disagree. Toe will not change, and camber is not adjustable. I have taken off my spindles several times and noticed absolutely no driveable difference in alignment. I havent seen any signs of uneven tire wear due to alignment either.
Old Jan 18, 2006 | 06:51 AM
MDeezy's Avatar
in the interest of saving money I will try this out when I change my driver side spindle. In my case my camber is very adjustable (D2s with camber plats up top).
then, the only time an alignment would be needed is when your put on new suspension, or adjust the height of your suspension (coilovers). Aside from that, any wheel bearing, spindle swaps, axle changes, etc you wouldn’t need an alignment?
Old Jan 18, 2006 | 07:12 AM
njmodi's Avatar
Do I get a tax break?
See the discussion here: http://forums.maxima.org/showthread.php?t=451000
Old Jan 18, 2006 | 07:21 AM
suicidalspd99
Did you chnage the races when you changed the bearings? I find alot of people don't do that. If you don;t your looking for a problem. No yu do not need an Alignment. I guess if you wanna spend the money and have the peace of mind, Sure go ahead. Otherwise I wold not waste the time.
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
