Windowgoes down but wont go up!!! Help!
Old Jan 18, 2006 | 02:19 PM
kmb38's Avatar
I need a solution on what the problem is. my driver side window goes down great but does not come up all the time. what do i do?
Old Jan 18, 2006 | 02:20 PM
buttonhook's Avatar
it could be the switch which window is it?
Old Jan 18, 2006 | 03:09 PM
njmodi's Avatar
Do I get a tax break?
Sounds like a bad window regulator to me...
When it doesn't come-up, can you hear the motor or anything else?
Old Jan 18, 2006 | 04:00 PM
DcMaN's Avatar
+1 on the window regulator. The metal wire for the regulator is probably getting stuck or is broken
Old Jan 18, 2006 | 05:47 PM
Mxrider52's Avatar
I support for what?
it the regulator same problem happened in our jeep and we replaced the regulator and it worked fine
Old Jan 18, 2006 | 06:54 PM
kmb38's Avatar
i dont hear any noise when the window goes up. when it does go up, it is fine. but most of the time it doesnt go up. its the driverside window. how would i take the door panel off to check?
Old Jan 19, 2006 | 06:27 AM
buttonhook's Avatar
if the regulator checks out pm me I have a full set of switches
Old Jan 19, 2006 | 06:46 AM
Guinader's Avatar
Same problem as yours
I replaced mine a few weeks ago, not a hard job... also make sure you get a new window regulator forma junkyard (it cost 150 for a new one, and only 25 on the junk)
http://forums.maxima.org/showthread.php?t=447194
