Nissan factory OEM clutch disc made by Exedy
Old Jan 18, 2006 | 06:32 PM
eng92's Avatar
It is well known that Exedy makes factory clutches for most of the import car manufacturers as well as some of the domestics. But usually when a company is name branding their goods for use by an oem, they do not put their own name on as well.
Here is a picture of a clutch disc I just received from Pinnacle Nissan.
Sorry if this is a repost, but up until now the only name I have ever seen on a Nissan clutch disc has been Unisia.
Old Jan 18, 2006 | 06:34 PM
njmodi's Avatar
Do I get a tax break?
Interesting.. is that a 4th of 5th Gen clutch...
Old Jan 18, 2006 | 06:42 PM
southeast_first's Avatar
weird, i always thought our oem clutches were made by valeo.
Old Jan 18, 2006 | 06:46 PM
eng92's Avatar
That is a 5th gen disc (p/n: 30100-2Y920).
Old Jan 19, 2006 | 06:20 AM
KRRZ350's Avatar
They are, and apparantly the 5th gen. must be made by exedy, interesting.
Old Jan 19, 2006 | 10:42 AM
my 5th gen clutch was made by valeo, i mean. so was the old clutch i took out. (i checked the part numbers, too, the valeo WAS a 00-01 clutch).
Old Jan 19, 2006 | 03:39 PM
eng92's Avatar
5th gen clutch disc p/ns (by prod. date)
April 99 - Oct 2000 - 30100-2Y904
Nov 2000 - June 2001 - 30100-2Y920 (Exedy unit pictured above)
5th gen pressure plate p/ns (by prod date)
April 99 - Oct 2000 - 30210-89F00 - 635 kg clamp force
Nov 2000 - June 2001 - 30210-2Y920 - 750 kg clamp force
The 5.5 gen (VQ35) also use a 750kg pressure plate but the clutch disc diameter was bumped up to 250mm from the 240mm that was used from 95 thru 01.
Old Jan 19, 2006 | 05:44 PM
well that would explain it.
Old Jan 19, 2006 | 05:50 PM
Stagnet04's Avatar
Hey Southeast First, How did you get your grill like that? did you paint the side chrome bars and left the nissan emblem or is that a special kind of grill?
Old Jan 19, 2006 | 05:51 PM
Stagnet04's Avatar
Stagnet04's Avatar
Old Jan 19, 2006 | 05:53 PM
s0ber's Avatar
quit thread jacking.
Old Jan 19, 2006 | 05:59 PM
Stagnet04's Avatar
Old Jan 19, 2006 | 06:00 PM
Stagnet04's Avatar
Old Jan 19, 2006 | 06:02 PM
Stagnet04's Avatar
Sorry about that to much traffic online right now....
Old Jan 19, 2006 | 07:45 PM
crazy97's Avatar
Dammit! I just had a 5th gen clutch put in(Valeo) and didn't realize there was a BETTER 5th gen setup.
Old Jan 19, 2006 | 07:46 PM
crazy97's Avatar
Old Jan 19, 2006 | 07:51 PM
crazy97's Avatar
What the hell? My posts are reproducing!
Old Jan 19, 2006 | 08:05 PM
Fr33way™'s Avatar
Wild for Width
It's a speacial kind, AN SE.
Old Jan 19, 2006 | 09:05 PM
oldskooljdm's Avatar
ok so 30100-2y920 is the correct number for the clutch disk? i want to do the 5th gen. setup on mine. what are the correct numbers. i have this:
release bearing:30502-41u20
clutch disk:30100-2y920
clutch cover/pressure plate:30210-89f00
Old Jan 19, 2006 | 09:12 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
I emailed DAVEB about 30210-2Y920 and he said it was smaller in diameter and he recommended the former one instead.
Old Jan 19, 2006 | 10:24 PM
stock se...
Old Jan 20, 2006 | 06:01 AM
eng92's Avatar
There is an error in the Nissan FAST database. It lists the 30100-2Y920 disc at 225mm but it shows it to be used with a 30210-2Y920 pressure plate which is listed at 240mm.
It wouldn't make sense for Nissan to use mismatched sizes so I figured it was an error. I ordered the 30100-2y920 disc and it matches up perfectly with the 30210-2y920 pressure plate.
Matt93SE
May 24, 2019 02:58 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
KGMtech
Aug 18, 2015 09:21 AM
