Adding an extra (1 or 2) cigarette lighters
Old Jan 20, 2006 | 03:23 PM
nwmma's Avatar
I have a 98 maxima, and I think I only have the one power plug in the front below the stereo. I have looked at splitters at radio shack, but is there another way where I could run 1 or 2 more to the console or somewhere easy to access. (Both front seats are power.)
I have a GPS and my cell phone that I would like to power; and I am getting sirius, so that will need power too. Would it be possible to directly run cable off the stock plug into an additional one?
What do you guys recommend?
Old Jan 20, 2006 | 03:28 PM
Dubbya's Avatar
VK56 Inside
Interesting idea. Very interesting. This will be my next junkyard project. I would think you could just tap power off the existing power plug (cig lighter) and run wires to where ever you wanted the plug to go. Im thinking inside the center console for me. I have a 1 to 2 adapter, so I dont see why this wouldnt be basically the same.
Old Jan 20, 2006 | 03:38 PM
nwmma's Avatar
Im pretty sure i could hardware one off of the existing cig lighter, but i have never done it so im not sure how.
Ill have to google it see if i can find anything....
http://www.radioshack.com/product/in...entPage=family
If you know the types of parts i need let me know.
thanks
Old Jan 20, 2006 | 03:41 PM
Dubbya's Avatar
VK56 Inside
You will need wire, red and black, and a extra cig lighter or 2. after that is just stripping wire and soldering. then you will have to create a place for the new cig lighters. most likely just drilling the right sized hole. worst comes to worst you will just blow a fuse assuming you dont cross ground to power.
Old Jan 20, 2006 | 07:56 PM
Vagabond's Avatar
I have a computer and shiz for my car. I dont smoke so i spliced into the cig lighter and add in however many connections i need and inline fuses. For instance, snip the connector off a radar detector and solder/shrink to the cig wires. throw a fuse in for safety. If any of that makes sence to you.
Cant move the stuff out but, i plan out the locations for my items then just deal with it.
Old Jan 20, 2006 | 08:50 PM
fatboyslim86440's Avatar
most electronics have different voltages too soo you will have to watch it if you tap in to it
just buy a socket from radio shake and tap it into your stock socket
Old Jan 20, 2006 | 09:14 PM
maximaman10's Avatar
Just tap into the cigg. lighter wire and hard wire everything.
Old Jan 20, 2006 | 10:06 PM
ryant35's Avatar
I bought another lighter from Kragen and wired it to the back of the factory cig lighter, but I used it for my sirius so I taped it up and left it behind the stereo.
The factory cig lighter is really easy to pull out to tap the wires, just pull up the plastic surrounding the shifter and there it is.
Miket2006
Mar 1, 2021 03:55 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
jaydot901
Sep 29, 2015 01:18 PM
Redfox
Sep 28, 2015 10:41 AM
