Complete dash removal required to fix side air vent?
Old Jan 21, 2006 | 07:41 PM
amr1776's Avatar
Unfortunately the vanes on my driver's side aimable air vent (left of the gauge cluster) are broken, and after looking at the manual it appears that you have to remove the entire freakin' dash to get the vent out! It's held in by three screws. Anyone here ever replace theirs, and have a better method? Taking the whole dash apart looks like it would be a major pain. Thanks!
Old Jan 21, 2006 | 07:44 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
You must remove the entire dash to fix those vents.
Old Jan 21, 2006 | 07:52 PM
mendon99's Avatar
tastey wheat
wow that really sucks, cus i was planning on painting those..
Old Jan 21, 2006 | 11:59 PM
natty99's Avatar
getting the entire DRIVER'S SIDE vent assembly out without removing the dash is possible (i.e., forget about the passenger side!)....I did it, and man was it a major PIA. However, it's really not necessary. If the vanes are broken, simply get another vent assembly from a parts car (or just the vanes from an intact vent) and use it to replace the broken ones in the dash. The side vents have an outer trim ring that snaps in place; it's tricky to remove, but it's removal is necessary to being able to access the structure that supports the vanes. If you snap it into peices, don't worry, remember, you have the spare vent from which you can scavenge another trim ring. The best way I found to remove it is simply to sneak the blade of a flathead screwdriver between the trim and the vent housing (you can see the seam by looking in by the side of the vent opening) and use your fingers to get enough leverage to pull that sucka out. Once you got that trim ring out fo the way, you can figure out the rest. Good luck!
Old Jan 22, 2006 | 12:11 AM
natty99's Avatar
BTW, I noticed you were in Maryland.....if you need help, feel free to contact me
chris
Old Jan 23, 2006 | 10:21 AM
amr1776's Avatar
Thanks man!
Thanks for the great input...I'm going to try that soon. You were able to get the new vanes in without breaking them? I'll have to make a trip to the Brandywine junk yard in Upper Marlboro - where Maryland Maximas go to die! Take it easy,
-Al
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
dauntlessmax
Aug 5, 2015 10:29 AM
