99 PCV valve- hard to get out?
Old Jan 23, 2006 | 06:46 AM
edwardh1's Avatar
The pcv valve on the 99 is connected to a short rubber hose that connects to a metal pipe- the rubber hose looks almost so shiort that it would be hard to get the PCV valve out? what to do / bend the rubber hose?
And use new aftermarket pcv or get from dealer or just clean the old one (63000 miles??) I got an advance auto pcv for my other car and it fit poorly
Old Jan 23, 2006 | 06:53 AM
FormorAccordMan's Avatar
I had a friend of mine do it for me, but it didnt look too hard. Just remove the hose carfully and use some pliers to take the old valve out, Replace it with a nissan OEM one. They are cheap enough like 5 or six bucks if mem serves me right.
Old Jan 23, 2006 | 06:54 AM
amimaxima
a new pcv is $3
Old Jan 23, 2006 | 07:20 AM
konak85's Avatar
i did mine, you just gotta struggle with it a little, not hard.
Old Jan 23, 2006 | 07:28 AM
njmodi's Avatar
Do I get a tax break?
Nothing hard about the PCV valve.
Just get some long-reach needle nose pliers and you'll be all set. Just undo the 10mm bolts holding the metal tube/bracket and it makes life a lot simpler.
Old Jan 23, 2006 | 08:02 AM
cardana24's Avatar
Blown
I have done this several times and I have found it easiest to take off the whole set up from the valve back to where it plugs into the rear of the manifold. Once you have all the bots out you can just wedge a screwdriver in there and pop it out.
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
fx4five
Oct 1, 2015 04:58 AM
jaydot901
Sep 29, 2015 01:18 PM
