Maxima speed question
Old Jan 23, 2006 | 05:19 PM
ethnic6's Avatar
I was just curious, and I'm sure everyone's results are different, but what is the compared results of a Max's HP when stock compared to that of a hooked up Max w/out turbo or with off the wheel... not how much the engine can put out, but how much overall HP considering the weight of the car, drivetrain, etc...
Old Jan 23, 2006 | 05:21 PM
s0ber's Avatar
eh?
not sure what you're asking here...
Old Jan 23, 2006 | 05:24 PM
ethnic6's Avatar
well I just want to know how fast is the maxima when u put in weight and all that other stuff together. Because statistically its 190 HP, but thats only how much the engine "itself" puts out isn't it, that HP doesn't take in account of when the engine is put into the car and the weight of the whole car is effecting the total HP
Old Jan 23, 2006 | 05:26 PM
Nismo's Avatar
Basically you want dyno numbers to the wheels.
http://forums.maxima.org/forumdisplay.php?f=48
Old Jan 23, 2006 | 05:27 PM
ethnic6's Avatar
ya basically... dyno of a stock, compared to that of a hooked up max with or without turbo
s0ber's Avatar
You mean Wheel Horsepower? WHP........
Depends if your auto or 5spd, I think stock 5spds do 165-170whp, with mods there usally around 185-190.. There are some freaks out there running 200+/whp in a 3.0N/A..
Old Jan 23, 2006 | 05:28 PM
ethnic6's Avatar
hows that possible?
Old Jan 23, 2006 | 05:31 PM
Nismo's Avatar
your going to be getting rather large variables in HP. Its like comparing a bone stock 4th gen to Hlh501's car and everything in between which is + or - few hundred HP.
Old Jan 23, 2006 | 05:34 PM
99grnmaxgxe's Avatar
Originally Posted by ethnic6
hows that possible?
Y-Pipe, Supercharger, and Mevi/00Vi would help.
Old Jan 23, 2006 | 05:35 PM
brad kay
okay..
weight of your car has nothing to do with how much horsepower you put to the ground, it only affects how fast that much horsepower will get you down the track..
what the 4th gen makes at the crank (190 hp) is different than what it will put down to the wheel once you take parasitic drivetrain loss into account. As a general rule rear wheel drive cars lose more than front wheel drive cars, and all wheel drive cars lose the most percentage-wise. Also, automatic trannies tend to cause more of a loss than manual, again percentage-wise off the original crank hp number. I'm really not sure what the vq30 puts down to the wheel bone stock, but if you calculate based on an average front wheel drive drivetrain loss percentage, you can figure you'll put down around 170 whp..
Old Jan 23, 2006 | 05:41 PM
ethnic6's Avatar
huh... I didn't know that u lose more percentage if ur car is a rear wheel or a all wheel drive, thats extra info for me... if anyone has had a dyno test I'm curious to know how much gain u got off of ur car along with if ur car is bare boned stock or if u've moded it... I'm just trying to get an average WHP knowledge whether w/ mods or just plain stock, because my car has an intake that the previous owner installed but the exhaust is all stock
Old Jan 23, 2006 | 05:59 PM
Nismo's Avatar
^^ refer back to post #4
Old Jan 23, 2006 | 06:00 PM
NmexMAX's Avatar
dot dot dot ...
This would make perfect sense. If the vehicle in question is rear wheel drive, the power needs to travel further along the driveshaft in order to get to the wheels--->ground. AWD needs to give all 4 wheels power, so therefore it's distributed through all 4 wheels rather than 2. FWD is the most 'effecient', since the engine/tranny/drive wheels are all pretty close to each other, and the power doesn't need to travel so far. But FWD has its issues and that's an entirely different ball of wax.
On my 3.5L I've gained over 30 whp with bolt ons for under 1000$. But the 3.0L is different, not by much.
Gather your thoughts and then post because your posts are a little hard to understand. I don't even think you know what you're asking.
Try this for more info...
RWD and AWD loses more power b/c the engine has to distribute its power to all four wheels (AWD) and through a driveshaft (RWD).
Old Jan 23, 2006 | 06:02 PM
D@mn NmexMAX, you beat me to it.
Old Jan 23, 2006 | 06:06 PM
ethnic6's Avatar
I guess I just want to get a general view of how much power a Max has WHP wise. thats why I'm asking for either bare bone stock WHP, moderate moded WHP, or a serious mod like a 3.5L upgrade WHP
sorry if anyone misunderstood
Old Jan 23, 2006 | 06:07 PM
NmexMAX's Avatar
dot dot dot ...
Seconds ahead... same time 7:00
Originally Posted by 99grnmaxgxe
you beat me to it.
Old Jan 23, 2006 | 06:10 PM
ethnic6's Avatar
and just curious, how much HP do u lose when u have a RWD or an AWD percentage wise?
Old Jan 23, 2006 | 06:18 PM
NmexMAX's Avatar
dot dot dot ...
. . And
http://www.forums.maxima.org/showthread.php?t=190509
Old Jan 23, 2006 | 07:36 PM
nismos14's Avatar
§è~® f®ÈÄk
Please try reading the links in this thread, you are just asking repetitive questions and its getting annoying.
Old Jan 23, 2006 | 08:10 PM
MaximaSE96's Avatar
Maxima Owner
my stock dyno was 178 hp and 185 tq want the graph
Old Jan 23, 2006 | 08:21 PM
NmexMAX's Avatar
dot dot dot ...
Better yet, the run file
Old Jan 23, 2006 | 08:23 PM
MaximaSE96's Avatar
Maxima Owner
wish i had it....only have the graph...ill be sure to get the runfile just for u when i go back this summer
Old Jan 23, 2006 | 08:39 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
why not drop a set of jwt cams in ?
Old Jan 23, 2006 | 08:49 PM
nismos14's Avatar
§è~® f®ÈÄk
$ 2,000
Old Jan 23, 2006 | 09:37 PM
NmexMAX's Avatar
dot dot dot ...
Because he can't even grasp the concept of dynos ....... yet..
Old Jan 23, 2006 | 09:51 PM
MorpheusZero's Avatar
FWD drivetrain loss is probably around 10-12%, RWD is probably around 12-15%, AWD is probably closer to 20-25%.
If you're auto, then add about 5-7% on top of that.
Old Jan 24, 2006 | 05:59 AM
ethnic6's Avatar
that is true, all I know is that it measures the WHP and torque, but I'm not all too clear about reading the graph itself...
Old Jan 24, 2006 | 08:39 AM
devilz05's Avatar
Shift_3.0
Holy crap, what a drop in both hp and torque above 5000 RPMs. Are most cars like that, or is that just the result of an untuned engine?
Old Jan 24, 2006 | 09:45 AM
Nismo's Avatar
non VI will do that to you
Old Jan 24, 2006 | 11:26 AM
NmexMAX's Avatar
dot dot dot ...
Typical of Amercian A32's.
Old Jan 24, 2006 | 12:16 PM
devilz05's Avatar
Shift_3.0
My old civic didnt have VI, and im pretty sure about that, but the torque and hp numbers did not dip like that
Wait, I just realized I had VTEC, lol.
Old Jan 24, 2006 | 01:35 PM
ethnic6's Avatar
whats VI and is a drop above 5000 RPMs that bad?
Old Jan 24, 2006 | 03:19 PM
NmexMAX's Avatar
dot dot dot ...
whats VI
It's a Vital Intelligence system.
It depends..
If it were 5000 feet, it could be catastophic to your health.
Nor 75% of the tq of the Maxima. The USDM was designed for tq via long runners.
Old Jan 24, 2006 | 03:46 PM
MaximaSE96's Avatar
Maxima Owner
USDM intake manifolds blow horse *****........00VI is what i need....or atleast an MEVI...but then i lose all my torque which comes in handy for auto-x....but thats just a base line dyno to give u an idea on power loss....
Old Jan 24, 2006 | 04:52 PM
Nealoc187's Avatar
SLOW
Geez this thread is... wow. Some of you guys need to start expanding your reading on the .org a little bit, starting with the dyno section and maybe some threads about engine mods... then when you are feeling bold go check out the all motor section (but don't post a thing until you've read all you can in there).
Old Jan 24, 2006 | 05:09 PM
NmexMAX's Avatar
dot dot dot ...
Some of you guys need to start expanding your reading on the .org a little bit, starting with the dyno section and maybe some threads about engine mods... then when you are feeling bold go check out the all motor section (but don't post a thing until you've read all you can in there) .
We've been telling the original poster all along. But Quoted for truth...
Old Jan 24, 2006 | 05:28 PM
MaximaSE96's Avatar
Maxima Owner
i :heart: NmexMAX but in a totally .org humor sort of way
Old Jan 24, 2006 | 05:31 PM
NmexMAX's Avatar
dot dot dot ...
Yeah that's not creepy at all.
Old Jan 24, 2006 | 05:33 PM
MaximaSE96's Avatar
Maxima Owner
haaaa haaaa...y yall got to pick on my bone stock dyno....all of urs would have looked like that too
