Stock suspension / Higher miles...
Old Jan 25, 2006 | 09:52 AM
ds03's Avatar
Not looking to upgrade to aftermarket or anything, so what "improvements" can be made to an older stock suspension? At 122k, the Max's ride isn't what it used to be, so I'm sure there are some worn parts (bushings, etc.)that could be replaced to bring her back close to original ride? Anyone here "upgrade" in this fashion (cost effective... i.e. without swaping out struts)?
Old Jan 25, 2006 | 09:55 AM
|Bijan|'s Avatar
UCF Lexus
bushings, motor mounts, and mzmtg's rear strut mounts...
contact org user; mzmtg
Old Jan 25, 2006 | 10:03 AM
rsly33's Avatar
Bushings alone arent going to bring back stock ride. Your struts are probably blown, just get some tokico blues or some low mile used in the for sale section.
Old Jan 25, 2006 | 10:28 AM
njmodi's Avatar
Do I get a tax break?
to that.
You don't have to put on an agressive aftermarket setup. Some Tokico blues on your stock springs, with fresh mounts, strut bearings and spring isolators will help your ride tremendously.
Other factors like worn bushings (LCA, swaybar), endlinks, ball-joints, tie-rod ends, will also affect ride quality and should be inspected.
Old Jan 25, 2006 | 11:21 AM
max95q's Avatar
If you are not looking to upgrade, I hate to say this but.........Monroe struts.
Old Jan 25, 2006 | 01:42 PM
ds03's Avatar
Thanks for the input. If the struts need changed, then so be it. I'll check out a few of these options and see what makes sense.
Old Jan 25, 2006 | 04:50 PM
goldmax's Avatar
I agree. If you want a near stock ride without buying stock struts, go Monroe. Virtually everything else is stiffer. I went with Illuminas and hated the ride. Handled great, but the constant jitter on rough roads drove me insane. Replace the mounts, tie rod ends and have someone check the lower control arms...they may be getting worn out. If your front brakes and rotors are worn out/warped, replace them with stock ones...absolutely the quietest and best riding I've tried. Don't even think about cross drilled or slotted if you hate noise.
Good luck!
Old Feb 23, 2006 | 05:53 PM
rudebwoyjr's Avatar
If you have an SE and like a smother ride, try your local salvage yard for some GXE/ GLE coil springs.
Old Feb 23, 2006 | 06:27 PM
RA030726's Avatar
I'm nutty for Nissans
^^ rear only.
get the tokico blues, they are as close to stock as you can get. stock struts are tokico. dont buy that monroe garbage.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
jaydot901
Sep 29, 2015 01:18 PM
