cleaned tb and iacv....what's the residue?
Old Jan 30, 2006 | 04:22 PM
goobergo's Avatar
Cookin' with Gas!
Well Today I set out to clean my throttle body and my IACV and was able to clean both; however, I noticed when I took off the IACV that inside the opening when you pull off the IACV thqt leads to the engine there was a dark grainy residue all over inside, I am guessing since previous owner installed a worthless injen cai there is a possible leak in one of the seals and it is or was pulling in dirt and grime or is this normal. help me out because I am quite confused as to what this could be and am guessing it is probably tearing the crap out of my motor.
Old Jan 30, 2006 | 04:46 PM
Trajiksmax's Avatar
Proud Maxima Owner
Doesn't sound good. I don't think that is a good thing to have anything grainy anywhere in your engine. Have a Stillen Ram kit makes me wonder what mine looks like. Think I know what I'm doing this weekend. I'll keep you posted on what's inside.
Old Jan 30, 2006 | 05:14 PM
njmodi's Avatar
Do I get a tax break?
Are you sure it's not just normal gunk (oil vapors, exhaust gases, etc.) that get recirculated into the intake).
Old Jan 30, 2006 | 05:18 PM
triumphD6's Avatar
Found the same when I clean my TB and IACV. I managed to clean alot of it out, and use a modified wet/dry vac to suck the remainder out, but it was unnecessary. My mechanic told me it was just unburned fuel deposits and whatnot (what njmodi said), and they will burn before they ever get to the injectors, and its nothing to worry about. Won't clog anything. Nonetheless, it should still be cleaned as good as possible because becasue it still restricts airflow.
Old Jan 30, 2006 | 05:20 PM
goobergo's Avatar
Cookin' with Gas!
I'm not sure which is why I asked the question, a picture with my digital would not have shown anything I didn't already explain. Is it possible for normal buildup to accumulate inside there? If so what would the build up be?
Old Jan 30, 2006 | 05:22 PM
njmodi's Avatar
Yes - it's normal for some build-up - but I'm not sure what your build-up looks like Thats the point of cleaning out the TB and IACV - so that you can remove all that grime.
Treatments like seafoam help clean out the intake and combustion chamber (see fluids and lubricants forum).
Old Jan 30, 2006 | 06:14 PM
96blackmaxSE's Avatar
boost me.....
Its normal...Its most likely from the EGR (emissions stuff) basically it burns excess oil vapors gas, etc...
the dark gunky looking stuff is just carbon build up, it is normal for all cars, dont worry about it...
but, if you are worried about it, do a compression test to make sure
Old Feb 9, 2006 | 06:02 AM
Juicey's Avatar
This ORG has saved me $$$$$$$$
In the Hayes manual it says to replace the IACV gasket when you fool with it. Any opinion from anyone?
Old Feb 12, 2006 | 05:21 PM
WhiteMaxima9600's Avatar
Dont sweat it, it's normal.. mine has the same stuff in it, a little stubborn to start cold in cold weather... but that's it
Old Feb 12, 2006 | 05:59 PM
MDeezy's Avatar
another vote for carbon building or various gunk.
Old Feb 12, 2006 | 06:33 PM
i30ds's Avatar
Armed and Dangerous
Didnt replace mine when I cleaned my iacv... BUT I did replace it when I put on my mevi.
Old Feb 12, 2006 | 06:35 PM
MDeezy's Avatar
you could buy gasket maker for ~$5. take off your TB and give it a good clean, and make a gasket for both.
Old Feb 12, 2006 | 06:39 PM
i30ds's Avatar
Armed and Dangerous
The residue is normal. Notice the rubber hose that goes from the front valve cover to the resonator? Thats part of it right there. Have an oiled air filter? Thats part of it right there. Egr is right next to iacv... This is the biggest part right there. Here is the build up I cleaned out of my intake manifold around the egr hole:
Old Feb 12, 2006 | 07:02 PM
MDeezy's Avatar
damn thats massive
Old Feb 12, 2006 | 07:16 PM
i30ds's Avatar
Armed and Dangerous
I know, it looks like someone scrapped their brush pipe ans rolled the resin up on my work bench.
Old Feb 12, 2006 | 07:33 PM
goldtooth's Avatar
looks like a turd. lol
Old Feb 12, 2006 | 07:38 PM
triumphD6's Avatar
i had a lot of residue in mine, but not that much. it's nothing to worry about, but good that you cleaned it. Especially with that massive obstruction.
Old Feb 12, 2006 | 08:06 PM
i30ds's Avatar
Armed and Dangerous
Well, it didnt really matter because I did this while I was installing my mevi so a whole new intake manifold went on anyways. I just wanted to clean the egr crap out of the old one so I could roll it up and take a pic for you guys. There was so much egr crap that the egr tube was almost blocked all the way.
Old Feb 12, 2006 | 09:03 PM
Kevo268's Avatar
Are we supposed to replace/clean the egr valve as scheduled maintainence
Old Feb 12, 2006 | 10:43 PM
goldtooth's Avatar
ive been wanting to clean my egr valve, but i dunno where it is and the stickies are useless to me.....
* > me
Old Feb 13, 2006 | 10:29 AM
tbergma1's Avatar
I put a small filter on the breather tube that comes off the head. This way none of that crap gets in mine. I plugged up the whole on the intake. I have been running this way for years. Just make sure you hook it back up when you smog.
Old Feb 13, 2006 | 11:57 AM
nismos14's Avatar
§è~® f®ÈÄk
Isn't it carbon build-up?
Old Feb 13, 2006 | 12:07 PM
tbergma1's Avatar
sho nuff........
Old Feb 13, 2006 | 02:08 PM
I have the egr code on my ecu, is it due to build up of that junk you think??
Old Feb 13, 2006 | 02:13 PM
tbergma1's Avatar
Yep, I heard that you cant clean it and just have to replace it. Anybody else here that?
Old Feb 13, 2006 | 04:28 PM
l3ftonm3's Avatar
man that looks like black tar opiu... or resin from wee... I mean a lot of residue from the egr valve. I really should clean mine out and see if I can smok... throw it away.
Old Feb 13, 2006 | 04:34 PM
i30ds's Avatar
Armed and Dangerous
The egr tube is connected on the back of the intake manifold on the right hand side. It has two bolts and a gasket. The tube runs down to the rear exhaust manifold where it is connected with two bolts and a gasket. Cleaning the egr hole on the intake manifold would is practically impossible with out removing the intake manifold. I mean how would you get the resin ***** out? You can however remove the egr tube and then clean that out with a wire brush... Thats what I did and about half my residue ball on my work bench is from the egr tube alone. Seeing that it was almost completely clogged, I would not be suprised if once it got completely blocked up that a code or two would be tripped.
Old Feb 13, 2006 | 04:38 PM
i30ds's Avatar
Armed and Dangerous
When I was installing my mevi I told my friend that I would give him $20 if he loaded that egr resin ball in his weed pipe and took just one big hit... he told me to go fucc myself.
Old Feb 14, 2006 | 11:36 AM
tbergma1's Avatar
Is there any performance loss if this gets plugged up?
Old Feb 14, 2006 | 08:17 PM
triumphD6's Avatar
no, its not carbon build-up. It is oil/fuel deposits. This is all on the intake side . . . carbon is a by-product produced from the combustion, so you would only find carbon deposits on the pistons/heads, or anywhere in the exhaust. It wont damage the engine, but it will take away from the performance because it still obstructs airflow, so its not good.
Old Feb 14, 2006 | 08:19 PM
i30ds's Avatar
Armed and Dangerous
If anything, you will run better with the egr pluged up. How well do you think exhaust gas is going to combust in your engine? The only bad thing is you could get a CEL which is bad for emissions checks.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
