BS or truth or close
Old Feb 2, 2006 | 01:55 PM
tbergma1's Avatar
I heard that for every 100lbs you cut from your car has the same effect of adding 10hp to your engine.
Any thoughts?
Old Feb 2, 2006 | 01:58 PM
VIP Maxima
for what car? i call BS
Old Feb 2, 2006 | 02:00 PM
tbergma1's Avatar
97 max. what would you say? how many HP for 100lbs.
Old Feb 2, 2006 | 02:14 PM
the_3d_man's Avatar
Put a spoiler and loud muffler on it that gets you at least 50HP.
It's not rocket science. You loose weight, your horsepower to weight ratio goes up... it's like 7th grade math you can figure it out. By the way.. it's a lot easier to add 10HP than it is to loose 100 lbs.
and it turns out thats dropping 100 lbs gives you the same HP/weight ratio that adding 6.5HP would give.
Old Feb 2, 2006 | 02:40 PM
Dubbya's Avatar
VK56 Inside
You could drop a hundred pound off the maxima pretty easy.
Light Weight wheels (save about 30 lbs)
CF hood (save about 20-25 lbs)
Light Weight Battery (save about 15 lbs)
Thats 70lbs right there.
Old Feb 2, 2006 | 02:44 PM
amimaxima
I think it goes for every 100 pounds you take off your car its about a tenth of a second off your 1/4 mile time. idk if there is any truth behind this, but thats just what i've heard
Old Feb 2, 2006 | 02:48 PM
RockfordMax's Avatar
Back from the dead
but once you get that stuff done (interior etc) your stuck unless you start removing windows and replacing with lexan or getting lightwight body panels.... Lets just say there's a limit to how much weight you can lose, and the closer to the limit the more money you spend on it. Horsepower is the same, but the limit is much higher.
Old Feb 2, 2006 | 02:49 PM
Back from the dead
and on our cars 100lbs is pretty much = to .1 second... some time reading in the advanced performance forums helps
Old Feb 2, 2006 | 02:52 PM
the_3d_man's Avatar
I think it goes without saying that 200 bucks for a Y-pipe will give more benefits for 1/10 of the price. Unless you don't care about AC, Music etc...
Weight loss is the last step to making car quicker.
Old Feb 2, 2006 | 03:18 PM
Back from the dead
Agreed. When youve spent a year's worth of pay to make your car fast, and STILL cant break 12, then its time to start cuttin
Old Feb 2, 2006 | 03:25 PM
86maxima96's Avatar
I Broke OT
depending on what it is. there are a few quick things like pull the spare, CF hood, and the things Dubbya said. but smaller things like composite parts and such are usually to fine tune everything.
Old Feb 2, 2006 | 03:26 PM
ImmaSquashYou's Avatar
yup, thats what i've been told, but then i'm thinking, i think i'd rather keep my ac n heat rather than just to be a few tenths of a second faster. I got my bike for that...-= )
Old Feb 2, 2006 | 03:33 PM
amimaxima
I tested this out just now
my friend has a 2001 audi s4 2.7 twin turbo automatic
he is 260 pounds
we ran the car on a g timer
with ryan drivin he ran a 14.72 (stock)
I ran a 14.56 ( I'm 100 pounds 160 pounds less than ryan)
next ryan ran a 14.50 with the spair tire out the floor mats our the wood trunk line and the trunk floor mat also we drained the wiper fluid and took the air filter out and we took out the 6 disc changer tray
and then I drove the car with everything removed as listed above and I have a 14.30
all of this was on a 1/4 tank of gas or less
Old Feb 2, 2006 | 03:36 PM
MaximaEvolution's Avatar
like what the 3d man said... as you lose weight your power:weight ratio decreases.
Power:Weight = The reason why hondas can be so quick with such little modifications. They thank the laws of physics everytime they get to a light.
Thats why motorcycles fly like F-18's . They have in the neighborhood of 180 bhp and the bike itself weighs only about 450lbs. If you put a 250lb guy on the bike that makes the Power:Weight ratio less than 3.5:1
In comparison, the stock 4th Gen's Power:Weight is just about 15:1
Hope that answers your question
I like to ramble, 'case ya hadn't noticed
Old Feb 2, 2006 | 03:39 PM
amimaxima
Im sorry I dont mean to hijack this thread but I would also like to know if packing your intercooler with ice before you run the 1/4 mile will help you et time
Old Feb 2, 2006 | 03:42 PM
start a new thread, amimaxima
Old Feb 2, 2006 | 03:44 PM
amimaxima
good idea i'll start it in the supercharged/turbo section
Old Feb 3, 2006 | 09:09 AM
95VQ's Avatar
I always prefer to lose the weight first. More power only improves acceleration and top speed. Losing weight improves acceleration, agility and braking. It'll also improve fuel mileage since your not wasting as much energy from lugging around extra mass. I'd start with reducing weight on any rotating parts (wheels, pulleys, flywheel,...) since you get more benfit out of it than reducing weight on nonrotating parts.
Old Feb 3, 2006 | 09:23 AM
f550maranello2's Avatar
if anything 100lbs takes off about (and i say that very loosely) .1 on the quarter mile
Old Feb 3, 2006 | 09:27 AM
MDeezy's Avatar
If your building a track car, strip it out and add power.
If your car is your daily driver, then add bolt on till your happy or sacrifice what you can, A/c etc.
Old Feb 3, 2006 | 09:28 AM
y sacrifice ac... for weight?..... it doesnt take anything off the motor it runs with the clutch disengaged when not using it
Old Feb 3, 2006 | 09:43 AM
MorpheusZero's Avatar
Then all you need is a VQ35DE... best weight reduction of all.
I hate to nitpick, but all your ratios are backwards. the bike's power:weight would be 1:3.5. Decreasing weight increases your power:weight.
Old Feb 3, 2006 | 09:45 AM
|Bijan|'s Avatar
UCF Lexus
oh god maxima tuner math
Old Feb 3, 2006 | 09:50 AM
Dubbya's Avatar
VK56 Inside
Already did it. 35lbs of weight reduction.
Old Feb 3, 2006 | 09:51 AM
Dubbya's Avatar
VK56 Inside
Dropping all the AC components saves a lot of weight. Think about everything that is involved.
Old Feb 3, 2006 | 09:52 AM
|Bijan|'s Avatar
UCF Lexus
I know youre referring to FERRARI guy, but Ive thought a looooooot about it
Old Feb 3, 2006 | 09:55 AM
Dubbya's Avatar
VK56 Inside
If mine wasnt a daily driver the ac would have been gone long ago.
FunLovinMaxima's Avatar
From: a charming town in Connecticut first settled in the 1600s
Something to consider:
the popular power mods typically have their greatest effect relatively high in the power band. Theoretically, weight reduction would result in a uniform performance increase across the power band.
Practically, however, as has been stated above, it is a heck of a lot easier to bolt something on than to drop enough weight. (Especially on a daily driver.)
Old Feb 3, 2006 | 09:56 AM
|Bijan|'s Avatar
UCF Lexus
I think I could handle it - just not 100% sure if I want to yet.
If you had a beater would you take off PS pump/belt too?
Old Feb 3, 2006 | 09:58 AM
Dubbya's Avatar
VK56 Inside
Duno. I would have to try it and see how much of a PITA it would be. My friends 86 Corolla doesnt have p/s and that thing is a heck of a lot lighter than a Maxima.
Old Feb 3, 2006 | 10:00 AM
Dubbya's Avatar
VK56 Inside
I dont see why you people think that. Weight reduction is easy to a certain point. I think the weight reductions I listed above are harder to acheive than say headers.
Old Feb 3, 2006 | 10:45 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by animaxima
I'm 100 pounds
.. either you're a female.. or...
Old Feb 3, 2006 | 11:41 AM
Dubbya's Avatar
VK56 Inside
or Ken......but seriously I think he ment 100lbs lighter.
Old Feb 3, 2006 | 11:46 AM
NmexMAX's Avatar
dot dot dot ...
... read it again...
he is 260 pounds .........................( I'm 100 pounds 160 pounds less than ryan)
Old Feb 3, 2006 | 11:50 AM
Dubbya's Avatar
VK56 Inside
well well then. i stand corrected. talk about a lightweight.
Old Feb 3, 2006 | 12:00 PM
amimaxima
yes im 100 pounds
Old Feb 3, 2006 | 01:00 PM
tbergma1's Avatar
OK, what is a good lightweight batter cost, where do you get one?
My battery is weak now and might as well lop another 15lbs or so off the car.
Old Feb 3, 2006 | 01:35 PM
Dubbya's Avatar
VK56 Inside
Oddesy is the best one that I have found.
http://www.motorcyclebatteriesusa.co...sp?battery=159
A few maximas use that one. I plan on getting one when the Never Start I have finally pisses me off.
Old Feb 3, 2006 | 06:21 PM
Ninos_Maxima's Avatar
be the change u want2C
yes im 100 pounds
i can curl you with one arm
Old Feb 3, 2006 | 09:26 PM
Eyemfaster's Avatar
i know braille makes some lightweight batteries too.
