View Poll Results: Top 3 gauge choices (multiple choices)
Air / Fuel
57
39.86%
Ammeter
4.20%
Voltmeter
50
34.97%
EGT
9.79%
Water Temp
46
32.17%
Oil Temp
41
28.67%
Trans Temp
25
17.48%
Oil Pressure
81
56.64%
Fuel Pressure
34
23.78%
Boost
60
41.96%
Multiple Choice Poll. Voters: 143. You may not vote on this poll
most useful gauges? your educated opinions
I didnt want to steal max88q's thread about gauge pods so ill just start this one.
I am heavily considering getting at least 2 gauges, and i wanted to ask all of you experienced guys your opinions on the most useful, informative gauges. The first things that occured to me were air/fuel and fuel pressure, but ive seen a lot of voltmeter and water temp gauges as well. also, what hardware is necessary for those gauges? i hear you can connect some electronic ones direct, and others need some sort of control module? thanks for the input.
def get a volt meter, i cant tell u how many times its saved my ***, since ive blown up like 8 alternators. a/f is just a pretty guage, its never exact and its pretty damn annoying when ur driving on the highway. i would say oil press and voltmeter. i mean unless u have some type of FI i would get a nitrous guage or a boost guage, possibly a pyrometer or wideband maybe? it all depends on what u are lookin to do with the guage and what mods u have should determine what kinda guages u get.
I would have to agree with these guys on the oil pressure guage. Water Temp is essential of course as well. Depending on your driving type and any trans/engine mods you have I would say that has a lot to do with it as well. I would like to see a more detailed Oil Temp and Water Temp guage as well. Sometimes it's the small differences that can have a lasting effect.
thanks,
lameo
thanks,
lameo
more info
thanks guys this is why i love maxima.org
im hoping with some birthday $ from this saturday i can hook up a new intake and add a new muffler. thats as much as i can go right now in the performance mod category. i was also reading a post about someone putting together an external temp lcd readout in their dud panel space (like the cruise control size space) and i figured i can try that as well as a duplicate for the intake. but i like that air temp idea. thanks for the suggestions im always open for more.
Originally Posted by NmexMAX
Voltmeter just simply taps into electrical, Oil pressure ( Mechanical) you need an adaptor such as this ( some say you can get these at home depot much cheaper, but it gives you an idea):
http://www.courtesyparts.com/Merchan...Category_Code=
Air/fuel ratio hooks up to your o2 sensor, I actually tapped mine into the o2 wiring on the back of my ECU. Obivously I went with a triple gauge pod, see my 4th gen domain for pics. Hope this helps
I love the look of the tripple guages, but I wouldnt have much functionality for it.
I've had situations where I wished I had a volt meter. I'm going to get oil pressure, A/F, and voltage. . . in the future.
I would go for oil pressure #1 water temp #2 ammeter or voltmeter #3 for a NA car ( I have voltage displayed on my passport anyway)
Boost #1 EGT #2 forced induction
A/F gauges are useless, unless it's wideband. I would still feel better with EGT over A/F
couldnt have said it better...especially uf u track race oil pressure and water temp are very nice to have....if u have an auto i would also suggest Trans Temp
Originally Posted by Kof
It depends on your personal needs and what mods you have on your max.
It depends greatly on whether your're N/A or have Forced Induction. Obviously you're going to want a boost/vacuum gauge if you're running a turbo or supercharger. Tranny temp is most critical on automatics.
I was planning to put Oil Pressure, Automatic Transmission Temperature, and Voltage gauges on my car before the accident.
if you boost...the three basics are oil pressure, air/fuel (if you dont have an afc), and a boost. EGT would be next in line, but with some basic knowledge of AF control, it's not needed. A secondary temp gauge is good too. And if you are real serious about performance, a wide-band O2 and air/fuel setup.
the one guage I wish I had is oil temp. especially for those in cold climates, oil temp is the most important metric in reducing engine wear -- thick, cold oil does not adequately lubricate/protect. I'd like to know when my oil gets to a reasonably high temp so I know when i can step on it without trashing my main bearings. oil temp does not track coolant temp, and is affected by ambient temp and driving conditions. in fact, I don't believe your oil will ever reach 100c (the temp at which operating oil viscosity is typically specified) unless you are running at highway speeds for a while. many of us would be shocked to know that we are driving around with >90wt oil in our engines most of the time because the oil temp is too low.
why are you buying guages? your car is stock. everything you listed is completely useless and complete rice unless you have mods that require you to monitor those readings.
I have a $10 plug in (cig lighter) volt meter digital readout with green,red,yellow warning lights. Never haver to unplug it, cig lighter turns off with ignition. I tested it against multimeter on terminals to check accuracy, same readings. Got it at Wallmart near batteries, easier than wiring one up and doesn't take away from triple gauge pod spots. You can put another gauge where that one would have been but still have volts.
Originally Posted by incognito903
sorry if my planning or scheduling confused you.
of course i wouldnt buy unnecessary monitors.
it is my understanding that more information is typically a good thing.
i noticed that many performance-oriented vehicles have these gauges, likely for a reason.
Like I30Mike said; an a/f reading from a narrow band o2 is useless and wont tell you anything. fuel pressure is another one, how is knowing your fuel pressure going to help you? you also mentioned a voltmeter and a water temp guage. voltmeters are useless, the signs of a failing battery or alternator are pretty easy to see and diagnose without the need for a guage, and water temp; do you drive your car hard? do you really need to know exactly what your water temp is? is the stock temp guage really not enough for you?
If you cant answer the question of; "why do you need these guages" then there is NO reason for you to have them.
vlasic it seems that if someone were to know less that you about a particular subject, you react to them as if they were idiots. i find this very childish, especially since none of us were born knowing everything, least of all everything about auto gauges. i said i considered buying gauges and wanted to know the use of them didnt I? the question is not so much why, but also when. asking the question, the time was clearly in the future. but when in the future? probably when im boosted was what people told me, and thats what i wanted to know. i asked about use, and a lot of people said there is no use unless you have certain parts or do certain things. thats what i wanted to find out. just as youve considered buying some performance parts or different exterior modifications, are you trying to infer that youve bought them all? the word consider does not mean finalization it means the opposite. are people not allowed to weight the pros and cons of things before they get them? that is all i was asking by making the thread. i guess you mean everyone in here who isnt running boost or nitrous or autocrossing and has gauges or commented on gauges are complete morons and dont know what theyre talking about. i didnt know about gauges so i asked. you learn things by researching and asking questions. i figured the people here would be much more specific and to the point than some review inclined to have you purchase the device. i figured thats what the org allows us to do ask other people for input. so thanks people that had some helpful things to say. and vlasic im done with your condescension i dont care how many posts u have or what u have on your car u werent born knowing everything and youre on the f****** internet so grow up and stop trying to be tight
You came on here asking for help and opinions, I gave you mine and I answered everything you asked but now your crying about it. I guess you would have been happier if I told you to just buy one of each then?
Originally Posted by smotz
Hey what gauages would be useful to someone running nitrous (wet).
I didnt call anyone in here an idiot, nor did I respond to them like htey were idiots
