drop resistor mod for tranny?
Old Feb 10, 2006 | 10:10 AM
One Crazy Max's Avatar
how is it done. i look in the faqs and the how-tos and the stickies and could not find how to do it. and is it only for the track or can i drive it daily like that?? thanks in advance for any help.
Old Feb 10, 2006 | 11:48 AM
cmon guys. no one knows what im talking about. im sure somebody does. anything???
Old Feb 10, 2006 | 11:58 AM
Jime's Avatar
http://jime.homeip.net/DR%20Mod.html
Old Feb 10, 2006 | 12:10 PM
jvienneau's Avatar
Great way to trash your tranny and axles.
Old Feb 10, 2006 | 12:36 PM
maximaman10's Avatar
If you do this mod make sure you ad a Transmission cooler. After doing it if it triggers you CEL you should get new transmission shift solonoids because your line pressure soloniod is more than likely wore out. I did this mod on my car and wired it to a switch in side so I can use the mod when I want. When using it it would trigger my CEL. After changing the soloniods the CEL doesn't come on any more when using it.
Old Feb 10, 2006 | 01:26 PM
Turiman's Avatar
now that you looked out jime's page you can consider this other way in the pic, i done it with the help of my friends pablo & elias, btw the switch was like $14 pesos (thats like $1.3 dlls) in a electronic store here in mexicali
Old Feb 10, 2006 | 06:29 PM
pmohr's Avatar
No more Maximas...
Oh really, how's that?
You're not hurting your tranny, and especially not your axles with this mod.
Old Feb 10, 2006 | 07:03 PM
lilaclucymaxima's Avatar
Team Ramrod
and you have proof of this?
Old Feb 10, 2006 | 09:54 PM
streetzlegend's Avatar
where is the solonoid located?
Old Feb 11, 2006 | 12:59 AM
On the valve body just under the pan. They are about $200. shipped, then you have to get a pan gasket and trans fluid to change the trans oil. It is worth it. There are 5 soloniods. 1 for ( 4 )for each gear and 1 for the oil pressure (line pressure). I found it worth every penny. I did mine at 100,861 miles, and it still runs like new.
Old Feb 11, 2006 | 08:27 AM
well i gotta drop my pan anyway because my gasket is bad, once the pan is down i have access to the solonoids?
Old Feb 11, 2006 | 12:03 PM
Yes, you will have to remove the valvebody to put them on. Copy and paste these, they should help.
http://www.vqpower.com/v2/modules.ph...howpage&pid=60 https://maxima.org/shoptalk/sub_m...er/index.shtml
maxima-junky
Oct 7, 2015 06:13 PM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
ballerchris510
Sep 23, 2015 08:46 PM
