putting in y/b pipe... replace 02 sensors?
Old Feb 10, 2006 | 11:48 AM
tikiboom's Avatar
I need an intervention
Im probably going to get my budget y/b pipe within the next month so i was wondering if i should change the o2 sensors. Car has 130k miles on it and although i do have maintenance records for it, they say nothing about getting any o2 sensors replaced.
Old Feb 10, 2006 | 12:15 PM
speed racer's Avatar
You don't have to get any O2 sensors when changing the Y-pipe. It is encouraged since you already have the pipe out, but not required. I didn't changed my O2 sensors when replacing the y-pipe and they still in great working condition. But if you have the extra money why not.
Old Feb 10, 2006 | 01:38 PM
t6378tp's Avatar
Turbo 3.5
I did not replace the o2 sensor either and it works fine .. but the guy at the exhaust shop did say if I had extra dough to just put new ones in since everything was already out
Old Feb 10, 2006 | 04:29 PM
The Deal's Avatar
Well I got the O2 code so im gonna be replacing the Y when I change the O2s lol.... Hey nothing would suck more than having it all out and not doing it, only to throw a code a week later... if u got the loot do it.
metal_god98SE's Avatar
I second that...agreed
Old Feb 10, 2006 | 06:03 PM
JSMax's Avatar
Sold
It's almost always a pita to remove those o2 sensors due to the placement, and the heat. Most times they are rusted on. My opinion and when I get my y-pipe, new sensors are going in.
Old Feb 10, 2006 | 06:58 PM
tikiboom's Avatar
well im lucky budget is like a 20 min drive from my house so i guess ill have them stick new o2 sensors in there.
IIRC theres 2 of them in the ypipe right?
And also, where can you buy these from and is any brand ok?
Old Feb 10, 2006 | 07:21 PM
AsthmaMax11's Avatar
O2 sensors aren't cheap. (especially OEM ones!)
I wouldn't replace them unless you have a CEL. They really aren't that hard to replace, you can get a tool from Autozone that will easily get them loose.
Old Feb 10, 2006 | 07:50 PM
tikiboom's Avatar
holy crap you werent kidding
cheapest i found on oxygensensors.com was $63
damn
Old Feb 10, 2006 | 08:09 PM
MaximaSE96's Avatar
Maxima Owner
no codes...no replace...but that me
Old Feb 10, 2006 | 08:27 PM
mastajonjon's Avatar
damn
You think that's bad...I had to get one from the dealer for $140 cause it was the only place that had the oems in stock...It's fine if you don't replace them, but MAKE SURE you do not strip them while taking them out You'll blow a hole in ur wallet if you do...had some dude put ma Y in and da guy stripped them...prolly cuz he didn't use PBlaster before he took them off...anyways, they're not cheap like u saw so be careful...
Old Feb 10, 2006 | 08:45 PM
tikiboom's Avatar
i can barely afford the y/b pipe as it is, so ill wait for the CEL
Old Feb 11, 2006 | 06:06 AM
Cosmo459sx's Avatar
If it is the downstream sensor that is throwing the code it is not imperative to replace it since its primary function is a backup incase of an upstream sensor malfunction. However, it is nice to not have the check engine light on 24/7.
mrc00l88
Jan 25, 2024 01:14 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
sc10692
Aug 9, 2015 09:37 AM
