Mystery Coolant Leak
Old Feb 11, 2006 | 05:20 PM
boostedka's Avatar
For the past couple weeks or so my maxima is leaking coolant down the front of the motor and getting worse, but I can't find exactly where it's coming from. It seems to be dripping in between the AC compressor and the block but I can identify the actually leak itself. Is there any coolant lines of some kind that run into the front side of the block? Any help is appreciated.
Old Feb 11, 2006 | 06:09 PM
1996blackmax's Avatar
The water pump is on that side. It may be time to replace it. It is located under the timing chain cover.
Old Feb 11, 2006 | 10:24 PM
nismos14's Avatar
§è~® f®ÈÄk
Good luck with that :cry:
Old Feb 12, 2006 | 03:13 PM
WhiteMaxima9600's Avatar
I have the same leak, and it's the water pump. Check for dampness around the little black waterpump/timing chain cover. It's located just behind the alternator underneath the belt tensioner.
Old Feb 12, 2006 | 04:49 PM
ryant35's Avatar
I had the same leak, stealer said it was the water pump, $700 later the leak was gone. I just didn't have the time to change it myself.
Old Feb 12, 2006 | 06:57 PM
boostedka's Avatar
Well I don't have 700 dollars so I guess I'll be figuring out how to do it in my garage. It'll be a learning experience I guess. If anyone has any helpful tips on doing this, let me know, thanks
Old Feb 12, 2006 | 07:07 PM
I paid $550 at one of my local dealers. The first one said $700, and I kept going. There were some shops that were a lot less, the problem was that they did not know much about the car. One shopt kept telling me I had a timing belt.
This is actually not an easy task to do. There have been a few people here though that have done it.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
foodmanry
Sep 24, 2015 12:02 PM
Hdnseek
Sep 9, 2015 05:55 AM
