Performance MEVI v OOVI
Old Feb 13, 2006 | 12:42 PM
packerZ's Avatar
Is there any significant difference in power produced by one over the other?? I read where MEVI seems to produce more power in higher RPM ranges (5K-6.5K?? While OOVI was more of a balanced "across the board" power to about 5.5K. Am I understanding this correctly? Also, MEVI is supposed to be slightly easier (less add-on components needed) to install on VQ30/ 4th generation...true?? Would a MEVI be a better choice if turbocharging was a possible "future wild hair" ?? Thank you for your input and reasons behind your choice. Doug
Old Feb 13, 2006 | 12:44 PM
konak85's Avatar
You should start browsing around the advanced performance forum.
Old Feb 13, 2006 | 12:47 PM
packerZ's Avatar
Thanks, I have...not too many people take the time to answer questions, there. Just trying to get some general input v hard-core tech issues...
Old Feb 13, 2006 | 12:57 PM
Nissan 6's Avatar
Dude its stickied in the all motor forum and search. There 43423423 threads on them.
Old Feb 13, 2006 | 01:00 PM
90stanza's Avatar
Go to the allmotor section and look around there if you can't find what you need then PM someone
Old Feb 13, 2006 | 01:18 PM
NCSU_MAX's Avatar
Maximoneypit
Hey Doug, to answer your question yes the 00VI will produce more HP than the MEVI. Here's the link http://forums.maxima.org/showthread.php?t=424641. The nice thing about the MEVI however is that it is a direct replacement for the stock USIM vs. the 00VI which will take some modifying. As for forced induction Im not really sure - I would assume the same results would hold as that of NA but I would definitely ask the guys in the FI forums; they really know their stuff. good luck
edit: heres another page that probably has some useful links
http://forums.maxima.org/showthread.php?t=345720
edit #2: you will need to extend the rev limiter to benefit either of these 2 applications since thats where alot of the extra power is made.
Old Feb 13, 2006 | 01:26 PM
packerZ's Avatar
Thank you all, so very much.... let's just forget it OR does anyone else want to get in on "look for it"?? OK, I've looked but I'll be sure to wait for your next posts so I can tell you its all in the stickies/already posted... "look for it" Afterall, EVERYTHING has been posted, hasn't it
Old Feb 13, 2006 | 01:41 PM
BigLou93SE's Avatar
The 00vi should be better for boosted apps as well. StephenMax dynoed on a MEVI and 00vi setup with his S/C, and there was a very noticable increase.
As for the extended rev limiter, it will not be needed with the 00vi AS BADLY as if you went for the MEVI instead. With the MEVI, you lose power down low, but gain up high. This will actually yield you little to no gain in quarter mile times alone. However, with an extended rev limiter, you can take advantage of the powerband which continues past our stock rev limiter.
With the 00vi, you can take advantage of gains up high, but retain your stock (or close) torque band down low. This allows you to run this IM setup efficiently without the need for an ecu, however, that would help drastically.
As said before, there is much more customization in the 00vi conversion, rather than the true bolt on that the MEVI consists of.
Old Feb 13, 2006 | 01:46 PM
nismos14's Avatar
§è~® f®ÈÄk
Never heard of the OO vi.........
Old Feb 13, 2006 | 01:49 PM
lilaclucymaxima's Avatar
Team Ramrod
Everything you asked has been posted more than once
Old Feb 14, 2006 | 06:09 AM
packerZ's Avatar
Thank you Big Lou! This is the type of feedback asked for...I guess SOMEONE is willing to help instead of joining in on the flamewagon. How 'bout if ya don't want to help; just go on to another post...nobody needs, or asked for, "cute"/garbage replies. Yeah folks!, some questions may have been covered (and read! but someone else may be trying to get more specific in-put, user opinions or a different angle. If you really, REALLY, feel the post isn't worthy of YOUR "educated" input... save your time and effort typing useless comments and go on, please.
Thanks again, BIG LOU.
Old Feb 14, 2006 | 06:13 AM
MaximaEvolution's Avatar
theres no better way to find out answers then to give the .Org the $20 bucks to be able to SEARCH
Old Feb 14, 2006 | 11:37 AM
NCSU_MAX's Avatar
Maximoneypit
I tried to help
Old Feb 14, 2006 | 12:38 PM
packerZ's Avatar
Originally Posted by NCSU_MAX
I tried to help
You are correct my friend!! I was rather peeved at the time and overlooked your kind response...I am guilty of getting too focused on the useless responses (I really do wish more members would only choose to respond if they feel the post is worthy of their helpful and intelligent response. My bad! I thank you both you and Big Lou. Doug
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
Dasmith
Sep 23, 2015 08:28 PM
