Please help me
Old Jun 9, 2001 | 09:15 PM
Tekgirl
Hi, I'm new to the list and I need some help before I go to the dealer or mechanic. I don't know much about cars, but I'm sure somebody could help me understand whats wrong w/ my Max.
I have a terrible smell coming from the air vents inside the car. It smells like urine and is absolutely horrible.
It seems to disapate if I turn on the AC. It smells most of the rest of the time. I don't mind paying to fix the problem, I just don't know what would cause it.
Any help would be greatly appreciated.
Thanks in advance,
tekgirl.................
Old Jun 9, 2001 | 09:20 PM
Yellowbrother's Avatar
Thanks in advance,
mister d.b.m. is the man to ask....
Old Jun 9, 2001 | 09:24 PM
Tekgirl
Thanks, but I don't know what you mean. Could you explain?
Thanks............
Old Jun 9, 2001 | 09:39 PM
shumax's Avatar
I have had this problem....
There is a collection tray for the EVAP cooler. It collects the excess run off water. Sometimes it 'sits't there to long and starts to stink. I simply had to take mine out...scrape the crap off and then replace it....problem solved. You can do this if you have a shop manula, or take it to an independent shop...
Good luck
SHUMAX
Old Jun 9, 2001 | 09:59 PM
Tekgirl
Re: I have had this problem....
SHUMAX,
Thank You. That makes sense because I have seen alot of condensation dripping from the car. I'm an idiot with cars and the only thing I did was check the puddle to make sure it wasn't some kind of other fluid. By the way, what is an EVAP cooler?
Thanks for you patience and kind response,
Tekgirl
Old Jun 10, 2001 | 11:30 AM
Daniel B. Martin's Avatar
... I have a terrible smell coming from the air vents inside the car. It smells like urine and is absolutely horrible.
It seems to disapate if I turn on the AC. It smells most of the rest of the time. I don't mind paying to fix the problem, I just don't know what would cause it. ...
It's a good idea to read the Chilton or Haynes repair manuals even if you have no intention of servicing your own car. It will teach you the names of things and how to distinguish between big expensive jobs and inexpensive minor jobs. This knowledge will help you be a knowledgeable consumer. In blunt language, it helps you avoid being an easy target for a ripoff artist.
The unpleasant odor from the air vents is usually caused by mold and mildew. This problem can be attacked by chemicals made for the purpose. I've heard that DWD2 works well.
http://www.texasdistribution.com/
Click on Do It Yourself to see how DWD2 accesses the evaporator fins.
AIR REPAIR A/C Evaporator Treatment is a similar product.
http://www.keep-it-kool.com/treat/treatment.html
I've never had the odor problem, and have never used these products. Therefore this is offered as a point of information, not a personal recommendation.
Fresh air enters the car's climate control system through intake openings at the base of the windshield. If the odor in your car really is urine (rather than mildew) there is a possibility that some miscreant did this deliberately by peeing on your windshield.
Old Jun 10, 2001 | 04:52 PM
this was mister d.b.m. i was refering to....listen to his advice....he knows his shiit...
Old Jun 10, 2001 | 05:18 PM
enticiveblkmax's Avatar
hey dbm, does spraying lysol in the vents below the winshield help eliminate the foul smells also. i remember reading that somewhere but havent had the chance to try it yet. do you have any input on this? by the way, you really kick ***.
Old Jun 11, 2001 | 07:24 AM
Originally posted by enticiveblkmax
hey dbm, does spraying lysol in the vents below the winshield help eliminate the foul smells also. i remember reading that somewhere but havent had the chance to try it yet. do you have any input on this? ...
If the problem is mold and mildew on the evaporator core you will get best results by applying a chemical treatment directly at the site of the problem. The Haynes repair manual suggests removing the blower motor resistor assembly and spraying an aerosol product through that opening. See Haynes, page 3-14.
Old Jun 11, 2001 | 07:31 AM
Hi, I'm new to the list ...
Because you are a newbie you didn't know this. It is helpful to choose a meaningful Subject line. In this case Terrible smell coming from air vents would have been a better choice than Please help me.
